Dan.Beadle(at)hq.inclines Guest
Posted: Wed May 17, 2006 7:35 am Post subject: Antennas |
I am building RV8. I am trying to figure out all the antenna placements
before closing up the wings.
Here is my current plan. I would appreciate feedback.
* Com antenna on belly - poor reception on the ground, but only
have to go short distances. Good in air because it is looking down at
station. Needs to be vertical for a bit to match the polarization of
the ground station.
* Nav antenna in one wing. Combines GS antenna thru a spliter.
Compromise over a good external antenna, but no drag. (Bob Archer)
* Marker beacon antenna in other wing tip.
* Transponder - little short antenna coming out the belly.
* ELT - should be on top - maybe just ahead of Vert Stab.
* GPS - under canopy on panel eyebrow.
We are planning GNS430, Grand Rapids EFIS with GPS, Garmin XPndr and
Audio Panel. Is this a good antenna match for this equipment?
rv8ch
Posted: Wed May 17, 2006 8:33 am Post subject: Antennas |
| Quote: | * Com antenna on belly - poor reception on the ground, but only
the ground station.
On my RV8 I didn't have room for the ELT antenna on top
of the fuselage in front of the VS. The canopy slides
all the way back to the VS. I put it just under the
VS like this:
http://www.rv8.ch/article.php?story050226171858929
The rest of your locations are pretty much the same place I
have either put my antennas or plan to.
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
_________________ Mickey Coggins
http://www.rv8.ch/ |
Hopperdhh(at)aol.com Guest
Dan,
I have my comm and transponder antennas on the bottom of the airplane as you
say. I am amazed at how well the comm antenna works. My runway is inside
Grissom's class D, and I am always able to contact the tower about 3 miles
away before I take off.
I am having very good results with a VOR antenna under the canopy in my
RV-7A. Mine is a homemade dipole with white no. 22 wire fastened to the canopy
with 4 small suction cups -- a little cheesy, but free and it probably
outperforms the wingtip mounted antennas. Maybe you could mount a commercial
VOR/Glideslope antenna under the canopy also.
I also have the GPS antenna on the glare shield under the canopy and it
works very well. I am using a BNC bulkhead fitting (BNC to BNC) with the
portable antenna from the back of the Garmin 295 sitting on the mounted fitting --
fitting vertical, antenna horizontal. A short (about 6 inch) piece of RG-400
connects the bottom side of the fitting to the panel mounted 295. Perhaps a
little cheesy, but again -- basically free.
An external ELT antenna is best, but few RVs use them. Quite a bit of drag
at 200 mph! Putting the ELT antenna under the empennage fairing as some are
doing is basically no antenna at all. I have mine in the baggage compartment
and aimed away from metal as much as possible -- definitely a compromised
location -- that wouldn't work on an 8. It should be close to the ELT, so
wingtips are out. This is a hard one!
I don't think it matters what antenna is used with what equipment, except in
the case of GPS where the antenna has an internal amplifier. In that case I
think the antenna should be the same brand as the receiver. All the passive
antennas will work as well with one brand of equipment as with another brand.
All IMHO, of course.
Dan Hopper
Walton, IN
RV-7A -- Flying about 170 hours now
In a message dated 5/17/2006 11:38:45 A.M. Eastern Daylight Time,
Dan.Beadle(at)hq.inclinesoftworks.com writes:
<Dan.Beadle(at)hq.InclineSoftworks.com>
frank.hinde(at)hp.com Guest
Posted: Wed May 17, 2006 8:56 am Post subject: Antennas |
Just a thought but to avoid a long wiring run out to a wingtip why not
put the marker beacon glued to the lower cowl.
I should be able to just get a 40" piece of stripped coax along there.
Frank
RV7a..almost painting
| Quote: | * Marker beacon antenna in other wing tip.
BobsV35B(at)aol.com Guest
Posted: Wed May 17, 2006 10:25 am Post subject: Antennas |
In a message dated 5/17/2006 10:38:45 A.M. Central Standard Time,
Good Morning Dan,
I might look carefully at your GPS antenna location. It would probably work
acceptably, but I am not sure it would meet the requirements for IFR
certification without flight testing.
The guidance for antenna placement is located in an AC. I believe it is
AC-138. You may not have full 360 degree coverage. As long as you have that high
powered 430, it would be a shame to get less than optimum performance.
You might also consider that there will be an upgrade soon that will allow
the 430 to receive WAAS signals. For WAAS reception, you have to have a good
line of sight to the south as the WAAS satellites are located over the equator.
Heading north, that may be a problem.
Just something to think about.
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
Brookeridge Air Park LL22
Downers Grove, IL 60516
630 985-8503
gmcjetpilot(at)yahoo.com Guest
Posted: Thu May 18, 2006 2:27 am Post subject: Antennas |
| Quote: | Subject: Antennas
| Quote: | *Com antenna on belly - poor reception on the ground, but
>only have to go short distances. Good in air because it is
>looking down at station. Needs to be vertical for a bit to match
>the polarization of the ground station.
Dan I would disagree in that you are NOT guaranteed poor
reception (or transmission) on the ground. I had my COM on
the belly of my RV-4 and never had a big problem, even at
large towered airports. I do find buildings or hangers are the
biggest impediment. I fly large jets and only one airport (LGA)
do I have to switch to the #1 radio (antenna on top) to talk to
ground/clearance, and that is only when I am in alley way. One
of those scary alley ways that where made for piston planes
55 years ago not jets with larger wing spans.
| Quote: | Subject: Re: Antennas
>Quite a bit of drag at 200 mph! Putting the ELT antenna under
>the empennage fairing as some are doing is basically no
>antenna at all... Dan Hopper
Dan: You have to qualify what you mean about quite a bit of
drag. I disagree that is quite a bit.
From my calculations at 200 MPH the drag penalties are:
ELT = 1/8 to 3/16 th mph MAX
COM = 0.25 to 0.30 mph MAX
Transponder = 0.06 to 0.10 mph MAX
Total is less than 2/3 rds mph.
The above are from my own calculations. I dusted off my
mechanical pencil and aerodynamics book (yes I was an
engineer for a large aircraft manufacture at one time.)
To back up my numbers here is a quote:
"There is a recent article in Plane & Pilot which
features the Socata Trinidad. Interesting enough,
the engineers at Socata actually quantified the
cruise speed impact of each antenna:"
ADF - .75 knots
G/S - .32 knots
VOR - .59 knots
ELT - .16 knots
This is for a Aerospatiale-Socata TB-20 with a listed
184 mph cruise and 192 mph top speed so these
drag penalties are equivalent for a fast amateur built
experimental aircraft.
If you assume 1/2 of a VOR is about equal to a COM
than 0.25 to 0.30 mph drag at 200 mph is reasonable.
The ELT is almost exactly what I calculated.
The exaggerate rumors and urban legend of antenna
drag are probably spread by people who want you to
use wing tip antennas, which perform poorly. Not to
mention the long (heavy) coax runs that result in more
signal loss. The wing tip antennas also are more
troublesome to install.
For all you racers and go fast guys, here is an idea that
worked for me very well for years on my RV-4. I made it
so I could remove the belly COM and VOR antenna in a
matter of minutes. I would replace the COM with an
antenna in the cockpit for races and performance contest.
The VOR was also on the belly under the horizontal
stabilizer. With nut plates it came off with two screws
and the coax was secured inside the fuselage with a
lanyard and then the hole was taped over. To put them
back on took as long as it took to remove, a few minutes.
If you want to pick you the 2/3 rds to 3/4 MPH, its an idea.
Cheers George RV-4/RV-7
Posted: Thu May 18, 2006 5:48 am Post subject: Antennas |
Great information. I am convinced about using external Com antenna.
Where do you suggest I mount an externally mounted VOR antenna?
Vertical Stab seems obvious choice, but antenna cable length is about
the same as in wingtip.
Dan
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Thu May 18, 2006 6:09 am Post subject: Antennas |
On May 17, 2006, at 8:33 AM, Dan Beadle wrote:
| Quote: | We are planning GNS430, Grand Rapids EFIS with GPS, Garmin XPndr and
Sounds fine to me.
Brian Lloyd 361 Catterline Way
brian-yak AT lloyd DOT com Folsom, CA 95630
Antoine de Saint-Exupry
_________________ Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery |
Posted: Thu May 18, 2006 7:09 am Post subject: Antennas |
In a message dated 5/18/2006 9:50:16 A.M. Central Standard Time,
Dan.Beadle(at)hq.InclineSoftworks.com writes:
Dan
Good Morning Dan,
If you are going to use an external VHF Nav antenna, consider using a set of
blades. They have superior reception patterns and one set can be used to feed
two nav receivers and two glide slopes by using an appropriate splitter.
Nice looking, no wires to stick in folks eyes, handle icing conditions well
and have relatively low drag.
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
630 985-8503
Posted: Thu May 18, 2006 9:41 am Post subject: Antennas |
George,
I went thru the calculations a couple of years ago and came up with somewhat
larger numbers than that. At least that's how I remembered it. I guess I
was mistaken!
I do agree with OC that we don't know how the airplane will end up in a
crash. Its not that unlikely that an RV will be on its top (again IMHO). The
convenience of an easy installation for the ELT in the baggage compartment of
my -7 is what drove my decision as much as anything. At the time, I was in a
hurry to get it in the air, and figured that it was a temporary location for
the antenna until I figured out the best place. Still trying to figure that
one out!
Dan Hopper
RV-7A Flying since July 2004
In a message dated 5/18/2006 6:29:51 A.M. Eastern Daylight Time,
gmcjetpilot(at)yahoo.com writes:
| Quote: | From my calculations at 200 MPH the drag penalties are:
Gilles.Thesee(at)ac-greno Guest
Posted: Thu May 18, 2006 9:56 am Post subject: Antennas |
Hi gmcjetpilot and all,
ADF - .75 knots
G/S - .32 knots
VOR - .59 knots
ELT - .16 knots
Glad you took the Socata TB-20 Trinidad as an example. It is a French
airplane and its performance is very well known.
It takes a Trinidad a 250 hp engine to cruise at 155 knots TAS (75 % power).
Your 1.82 knot cruise speed impact on this large draggy spam can amounts
to more than 3 % of the Trinidad total drag. That means about 6.5 hp
just to carry your antennas in the breeze.
Our MCR-4S four seater has a 100 hp engine and cruises at 140 knots TAS.
(75 % power).
Total drag is much lower. Those same antennas would spend 4.8 hp on our
MCR. Much more significant when compared to the 75 hp cruise setting.
I'd say something on the order of 2 to 3 knots for an MCR. 3 knots or 5
km/h is something we can easily see on the ASI or when flying formation.
That is the difference we currently measure between clean and dirty MCRs.
Of course there is no point in hiding antennas on a Pitts or a Cessna,
but small and sleek airplanes will really benefit.
And it is so easy to do, so why not try ?
Gilles Thesee
Grenoble, France
http://contrails.free.fr
brian
Posted: Thu May 18, 2006 9:46 pm Post subject: Antennas |
On May 18, 2006, at 6:40 AM, Dan Beadle wrote:
Antenna cable length at 108 MHz is really not an issue.
Posted: Fri May 19, 2006 6:38 am Post subject: Antennas |
| Quote: | From: Gilles Thesee <Gilles.Thesee(at)ac-grenoble.fr>
TAS (75 % power). Your 1.82 knot cruise speed impact on
this large draggy spam can amounts to more than 3 % of
the Trinidad total drag. That means about 6.5 hp just to
cher monsieur
Your HP values are way off, and I'll prove my point with
analytical values and flight test data, beg your attention.
Here is the calculations for one COM at 200 mph:
Area: 2.88 in-sq (.04 ft-sq)(assume 20"x3/16" bent-whip w/ base)
Cd: 0.50 ( Fluid Dynamic Drag, by Hoerner, fig 13, pg 3-9)
Drag: 1.02 lbs
HP req: 0.54
HP act: 0.68 (assume prop efficency 0.80)
Speed penalty: 0.25 mph (0.22 kts)
0.68 HP not 3 HP. This is what I am talking about.
If I used 3.75 in-sq the drag would be 0.89 HP/ 0.33 mph lost.
These numbers are WAY conservative.
Remeber the TB-20 Airplane Flight Manual (AFM) placed the
penalty of the VOR (about twice a COM antenna in frontal area)
at 0.59 kts (.68 mph). Half is .34 MPH. This is what I got. This
is equal to less then 1 HP not 6.5 HP. If you had a VOR and COM
(like 3 COM's) we have about 2.1 to 2.7 HP MAX.
I agree IF you can get rid of this drag great, but we need
antennas. A metal plane is limited in where the antennas can go.
| Quote: | Our MCR-4S four seater has a 100 hp engine and cruises at 140
knots TAS. (75 % power). Total drag is much lower. Those same
antennas would spend 4.8 hp on our MCR. Much more significant
I don't know what a MCR-4S. It does not matter drag is drag, but
if it is fiberglass than by all means hide your antenna's. However
I only fly metal airplanes, fiberglass is for hot tubs and boats.
(I am kidding, joke, ha ha).
Clearly a metal plane like a RV can not hide antennas like a
composite plane. It is just not a big deal, (read on).
| Quote: | I'd say something on the order of 2 to 3 knots for an MCR. 3 knots
or 5 km/h is something we can easily see on the ASI or when flying
formation. That is the difference we currently measure between clean
and dirty MCRs.
When I took off my COM and VOR whiskers the speed differnce was
NIL or negligible. However from flight test it did appear I picked up a
some speed. Of course measuring such a small change is hard with
flight test that has errors. Analytically I know its good for about 1/3rd
mph. Flight test back up the calculations. Drag is not that large.
An antenna is just not that big of a deal. Now 5 or 10 antennas
would get your attention, but one antenna or two antenna, no.
YOUR MCR-4S:
Drag is a function of airspeed. With your 140 kt cruise, your speed
loss is about 1/8th MPH for one COM. With frontal area, coefficient
of drag conservatively assumed, calculated drag is very straight
forward. Your 2 to 3 kts is off by a factor of 16 to 24 too high.
For your 140 kt (160 mph plane) one COM the calculations:
Area: 2.88 in sq (0.04 ft sq) (assume 20"x3/16" bent whip w/base)
Drag: 0.66 lbs
HP req: 0.28
HP act: 0.36 (assume prop efficency 0.80)
Speed penalty: 0.11 mph (0.095 kts)
That is hard to read on the IAS. IT IS NOT THAT BAD
Even if I assumed a large frontal areal say 3.75 in-sq,
speed lost = .14 mph, it is no big deal.
Even with 2 or 3 antennas we are talking about small losses.
Losses yes, but not the huge amounts that people assume.
ce n'est pas une affaire, un problme
| Quote: | but small and sleek airplanes will really benefit.
I appreciate your opinion and I guess any plane can benefit from less
drag. However in a metal plane antenna placement it pretty limited
to external locations. Again the drag from on COM, Tpx or VOR is
about 3/4 - 1 mph tops on a 200 mph plane, or I should say a 199 mph
plane.
It does not matter if it is a RV-7, MCR-4S, Cessna or Pitts, DRAG is
DRAG. However if fiberglass HIDE AWAY. However if it is good to
bury the antennas why does the Lancair Columbia and Cirrus aircraft
sprout external antennas? http://www.cirrusdesign.com/
I suggest you can experiment and temporarily mount antennas on the
airframe and fly. I have done this. It just is not a big deal.
Cheers George
robh(at)hyperion-ef.us Guest
Posted: Fri May 19, 2006 7:10 am Post subject: Antennas |
In order to gain certification something must be done to make the composite
structure electrically conductive in order to deal with a lightning strike.
So, unlike experimental composite aircraft, the certificated variety have a
metallic mesh, Al or Cu, imbedded in the laminate. This precludes mounting
antennas internally.
Best regards,
Rob Housman
A070
Airframe complete
Irvine, CA
Posted: Fri May 19, 2006 7:17 am Post subject: Antennas |
Rob Housman a crit :
Hi Rob,
Aren't we talking about experimental aircraft ?
By the way, why should aluminum RVs be able to hide antennas and not
compsite airplanes ? Wingtips, fin cap, etc...
Gilles Thesee
Grenoble, France
Posted: Fri May 19, 2006 7:42 am Post subject: Antennas |
Dear Monsieur gmcjetpilot,
Thank you for your message.
I was quoting your numbers :
ADF - .75 knots
G/S - .32 knots
VOR - .59 knots
ELT - .16 knots
The total speed reduction is indeed in the vicinity of 1.82 knot. We
ought to include one COM antenna.
Oh, you really should check
http://contrails.free.fr/index_en.php
| Quote: | Clearly a metal plane like a RV can not hide antennas like a
They do have plastic wingtips and fin tops.
NIL or negligible.
What type airplane ? No wonder if it is some aluminum box with short
wings and a big engine
| Quote: | With your 140 kt cruise, your speed
How come ? With a speed loss of 0.3 kt at 155 kt, the same antenna
would lose only 0.1 kt at 140 ?
Just like weight reduction, small gains add to small gains, and in the
end it makes quite a difference. That's how Michel Colomban's two seater
and the MCR01 need only an 80 hp engine to CRUISE at 155 kt TAS.
Those who indulge in the "ce n'est pas une affaire" attitude are
achieving much lower speeds.
| Quote: | However if it is good to
They are designed by, ahem, aircraft engineers. Many of them have the
same "pas une affaire" background.
The industry doesn't believe in the existence of drag. Especially in the
land of cheap gas and big engines.
airframe and fly.
No need. I just have to watch similar airplanes with their antennas
sticking out, and receding in my slipstream
Oh, and by the way, do you really count the Cirrus in the sleek airplane
category ?
Gilles Thesee
Grenoble, France
Posted: Fri May 19, 2006 7:51 am Post subject: Antennas |
Gilles, see the bottom of my reply to George's message - he is asking why
Cirrus and Columbia have external antennas..
Best regards,
Rob Housman
A070
Airframe complete
Irvine, CA
endspeed(at)yahoo.com Guest
Posted: Fri May 19, 2006 8:40 am Post subject: Antennas |
Monsieur:
I noticed you live in Grenoble. Ah, I remember the
great Jean-Claud Killy and the 1968 Winter Olympic
Games. Is that correct? Il y a quarante annee's?
C'est impossible! How is the skiing there these days?
Magnificent, n'est pas?
Bob Sultzbach
--- Gilles Thesee <Gilles.Thesee(at)ac-grenoble.fr>
wrote:
point with
attention.
ADF - .75 knots
G/S - .32 knots
VOR - .59 knots
ELT - .16 knots
of 1.82 knot. We
antennas like a
on).
speed differnce was
> NIL or negligible.
the same antenna
small losses.
assume.
gains, and in the
155 kt TAS.
attitude are
and Cirrus aircraft
of them have the
antennas on the
> airframe and fly.
their antennas
category ?
Gilles Thesee
Grenoble, France
browse
Subscriptions page,
FAQ,
Admin.
Posted: Fri May 19, 2006 11:37 am Post subject: Antennas |
Rob,
Understand.
Gilles Thesee
Grenoble, France
Posted: Fri May 19, 2006 12:17 pm Post subject: Antennas |
| Quote: | Monsieur:
Hi Bob,
You're correct. Were you there during those golden days of French skiing ?
I wasn't in Grenoble at the time, but I followed Jean-Claude Killy's
downhill at a TV store before going to school.
Killy is still around, he is a member of the International Olympic
Committee.
Skiing is great here, but building took sooo much time !
Amicalement,
Gilles
