Replace / Repair Rocket Exhaust Pipe & Replace / Repair (?)
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Rocket-List
tc
PostPosted: Fri Jun 24, 2011 8:03 am    Post subject: Replace / Repair Rocket Exhaust Pipe & Replace / Repair (?) Reply with quote
Normal 0 false false false MicrosoftInternetExplorer4 <![endif]--> <![endif]--> st1\:*{behavior:url(#ieooui) } <![endif]--> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} <![endif]-->
N85TP, HR II, completed 1996, now lives at Manassas, VA, Regional.
I'm new guy to Rocket and couple problems showing up on my first annual:
1. Warped flange on the aft left section of the cylinder #6 exhaust pipe -- causing exhaust leak.
It’s the original pipe, believe John Harmon’s early design (have asked him about it) – bad section is on right side of attached photo.
Anybody know if / how I can get replacement part, or maybe a great welder who could remove / replace the flange? Other ideas?
2. Original fiberglass 15” dia. Spinner’s prop hub front plate is damaged; it’s 10 5/8” dia., attached inside spinner with four screws and to Hartzell prop hub with four bolts. Attaching photo. Ideas for who to contact for a replacement?
Tim Carey
- The Matronics Rocket-List Email Forum -
http://www.matronics.com/Navigator?Rocket-List
 Filesize:  155.66 KB
 Viewed:  3528 Time(s)
 Filesize:  42.22 KB
Tim Carey
Dulles Aviation, Inc., Manassas, VA
USAF, Retired
smokyray(at)rocketmail.co
PostPosted: Fri Jun 24, 2011 12:02 pm    Post subject: Replace / Repair Rocket Exhaust Pipe & Replace / Repair (?) Reply with quote
Tim, I removed my original exhaust and installed a Larry Vetterman system, much improved and worth every penny.He may also be able to help with repair,,although once removed my old system had cracks I couldn't see until off airplane. Replacing improved performance as well.
Spinner bulkhead, try aircraft spruce. FYI. A Cessna 310 spinner will R&R perfectly.
Smokey
Formerly HR2
Now RVX
On Jun 24, 2011, at 11:00, careytn(at)comcast.net (careytn(at)comcast.net) wrote:
[quote] Normal 0 false false false MicrosoftInternetExplorer4 <![endif]--> <![endif]--> st1\:*{behavior:url(#ieooui) } <![endif]--> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} <![endif]-->
Tim Carey
<IMG 0194 web size.jpg>
<IMG_0198 (Small).JPG>
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Rocket-List All times are GMT - 8 Hours
