plugs
wise(at)txc.net.au
PostPosted: Sat Jul 09, 2011 3:32 pm    Post subject: plugs Reply with quote
G’Day All,
I am about to order 3 sets of the auto conversion harnesses and plugs for myself and a couple of mates.
I have flown the 18 T in rain and wonder what the effect of flying in rain and all the front plugs getting pretty wet.
I once had a mini, and whilst I pretty well sealed the dizzy with a tennis ball, if the plugs got too wet it would run like a woolly goat.
Thanks and cheers,
Chris.
cjpilot710(at)aol.com
PostPosted: Sat Jul 09, 2011 4:13 pm    Post subject: plugs Reply with quote
Please! What is a "dizzy" AND just how on earth does "woolly goat" run?
Although I try to avoid rain, I have flown my auto converted M-14p light rain with no problem.
Jim "Pappy" Goolsby
In a message dated 7/9/2011 7:33:19 P.M. Eastern Daylight Time, wise(at)txc.net.au writes:
G’Day All,
Thanks and cheers,
Chris.
="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List
ms.matronics.com/">http://forums.matronics.com
tp://www.matronics.com/contribution">http://www.matronics.com/contribution
wise(at)txc.net.au
PostPosted: Sat Jul 09, 2011 5:10 pm    Post subject: plugs Reply with quote
G’Day Jim,
Dizzy is slang for a distributor, which on the Austin Healy, MGA and Mini cooper that I had many years ago, and when they got wet in a downpour the dammed car would miss and all sorts.
We solved that by punching holes for the plugs wires in a tennis ball which we fitted over the distributer and would be a tight fit for the plug wires and this stopped the water from playing havoc with the distributer.
But if happened to be caught in a down pour and the plugs got to wet, then one faced the same problem.
I am going to fit a set of Barrett pistons to a engine that we are building as well as the Barrett plug conversion kit which I have already ordered.
Then some smart Alec told me that they “play up� in the rain which we all try and avoid but at times we do so.
I was coming back from a show about 2 ½ months ago and whist visibility was not too bad, 3 of us had to fly thru showers of pouring rain.
Thanks for the reply and cheers,
Chris.
PS How are Doug and his wife coming along?
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of cjpilot710(at)aol.com
Sent: Sunday, 10 July 2011 9:41 AM
To: yak-list(at)matronics.com
Subject: Re: plugs
Jim "Pappy" Goolsby
G’Day All,
Thanks and cheers,
Chris.
====================================="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List====================================ms.matronics.com/">http://forums.matronics.com====================================tp://www.matronics.com/contribution">http://www.matronics.com/contribution====================================
radiopicture
PostPosted: Sat Jul 09, 2011 5:27 pm    Post subject: plugs Reply with quote
I have also observed mere atmospheric humidity degrading the performance of plug wires that were old and dried out. In the dark, even if the wires haven't been exposed to water, you can see the arcing.
On Jul 9, 2011, at 9:04 PM, Chris Wise wrote:
G’Day Jim,
Then some smart Alec told me that they “play up” in the rain which we all try and avoid but at times we do so.
Chris.
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of cjpilot710(at)aol.com (cjpilot710(at)aol.com)
Subject: Re: plugs
Jim "Pappy" Goolsby
In a message dated 7/9/2011 7:33:19 P.M. Eastern Daylight Time, wise(at)txc.net.au (wise(at)txc.net.au) writes:
G’Day All,
Thanks and cheers,
Chris.
Cliff.Coy
PostPosted: Sat Jul 09, 2011 6:57 pm    Post subject: plugs Reply with quote
All I can say is that if you want to keep the ignition system that was designed and produced for the engine and replace the wires with new silicone wires, I've got plenty of it.
Cheers,
Cliff
On Sat, Jul 9, 2011 at 21:24, Eric Wobschall <eric(at)buffaloskyline.com (eric(at)buffaloskyline.com)> wrote:
G’Day Jim,
Chris.
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)] On Behalf Of cjpilot710(at)aol.com (cjpilot710(at)aol.com)
To: yak-list(at)matronics.com (yak-list(at)matronics.com)
Subject: Re: plugs
Jim "Pappy" Goolsby
G’Day All,
Thanks and cheers,
Chris.
 ====================================="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List====================================ms.matronics.com/">http://forums.matronics.com====================================http://www.matronics.com/contribution====================================
Clifford Coy
Border Air Ltd.
629 Airport Rd.
Swanton, VT 05488
802-868-2822 TEL
802-868-4465 FAX
Skype: Cliff.Coy
radiopicture
PostPosted: Sat Jul 09, 2011 7:03 pm    Post subject: plugs Reply with quote
I had no problem with the stock ignition harness on either of my Yak-52s.
On Jul 9, 2011, at 10:53 PM, Cliff Coy wrote:
[quote]All I can say is that if you want to keep the ignition system that was designed and produced for the engine and replace the wires with new silicone wires, I've got plenty of it.
Cheers,
Cliff
G’Day Jim,
Chris.
Subject: Re: plugs
Jim "Pappy" Goolsby
G’Day All,
Thanks and cheers,
Chris.
Clifford Coy
Border Air Ltd.
629 Airport Rd.
Swanton, VT 05488
802-868-2822 TEL
802-868-4465 FAX
Skype: Cliff.Coy
0[b]
tigeryak18t
PostPosted: Sat Jul 09, 2011 8:17 pm    Post subject: plugs Reply with quote
I don't understand why it makes a difference flying into,rain or not. The motor is more efficient and you don.t get wet.
I have regularly flown under heavy rain condition with my 18T without noticing any difference.
No problem of water playing with whatsoever. By the way don.t tell it to you motor it doesn't know about Taino....
The only problem flying into rain is that it will damage your original blade.the drops of water becomes very harmfull for a wooden blade.
For the rest we have installed the Dennis automotive conversion kit with the anti moisture plate for the magneto on our 52 and it has solved a moisture problem with an old original harness. We also have flown the 52 under rain condition without any problems?
So I can confirm that sometime you can get a drop in magneto because of humidity with an old original harness and that installing Dennis automotive kit with the plate solved our problems, Yes.
Thank you Dennis!!!
Didier Blouzard+33(0)6 2424 3672
Le 10 juil. 2011 à 05:01, Eric Wobschall <eric(at)buffaloskyline.com (eric(at)buffaloskyline.com)> a écrit :
[quote]I had no problem with the stock ignition harness on either of my Yak-52s.
Cheers,
Cliff
On Sat, Jul 9, 2011 at 21:24, Eric Wobschall <[url=mailto:eric(at)buffaloskyline.com]eric(at)buffaloskyline.com (eric(at)buffaloskyline.com)[/url]> wrote:
G’Day Jim,
Chris.
From: [url=mailto:owner-yak-list-server(at)matronics.com]owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)[/url] [mailto:[url=mailto:owner-yak-list-server(at)matronics.com]owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)[/url]] On Behalf Of [url=mailto:cjpilot710(at)aol.com]cjpilot710(at)aol.com (cjpilot710(at)aol.com)[/url]
To: [url=mailto:yak-list(at)matronics.com]yak-list(at)matronics.com (yak-list(at)matronics.com)[/url]
Subject: Re: plugs
Jim "Pappy" Goolsby
In a message dated 7/9/2011 7:33:19 P.M. Eastern Daylight Time, [url=mailto:wise(at)txc.net.au]wise(at)txc.net.au (wise(at)txc.net.au)[/url] writes:
G’Day All,
Thanks and cheers,
Chris.
Clifford Coy
Border Air Ltd.
629 Airport Rd.
Swanton, VT 05488
802-868-2822 TEL
802-868-4465 FAX
Skype: Cliff.Coy
0="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List
Didier Tiger YAK18T
Member of Commemorative Air Force
French Wing
CJ6XXK
PostPosted: Sat Jul 09, 2011 10:48 pm    Post subject: Re: plugs Reply with quote
Are you in Australia??
Daniel
wise(at)txc.net.au
PostPosted: Sat Jul 09, 2011 11:35 pm    Post subject: plugs Reply with quote
Hi Daniel,
Yes I am.
Cheers,
Chris
CJ6XXK
PostPosted: Sun Jul 10, 2011 12:24 am    Post subject: Re: plugs Reply with quote
Let me know if you want a hand with anything.
Daniel
dsavarese0812(at)bellsout
PostPosted: Sun Jul 10, 2011 5:09 am    Post subject: plugs Reply with quote
Thank you Didier. I am now offering CNC machined front cover plates in
a "Deluxe" kit or they can be purchased as a separate item as well.
Available on my web site.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (cell)
Skype: Yakguy1
www.yak-52.com
Thank you Dennis!!!
Didier Blouzard
+33(0)6 2424 3672
> Yak-52s.
>> *All I can say is that if you want to keep the ignition system that
>> Cheers,
>> Cliff
>> see the arcing.
>>> G’Day Jim,
>>> pouring rain.
>>> Chris.
>>> *From:*owner-yak-list-server(at)matronics.com
>>> <mailto:owner-yak-list-server(at)matronics.com>[mailto:owner-yak-list-server(at)matronics.com
>>> <mailto:owner-yak-list-server(at)matronics.com>]*On Behalf
>>> Of*cjpilot710(at)aol.com <mailto:cjpilot710(at)aol.com>
>>> *Sent:*Sunday, 10 July 2011 9:41 AM
>>> *To:*yak-list(at)matronics.com <mailto:yak-list(at)matronics.com>
>>> *Subject:*Re: plugs
>>> goat" run?
>>> Jim "Pappy" Goolsby
>>> Time,wise(at)txc.net.au <mailto:wise(at)txc.net.au>writes:
>>> G’Day All,
>>> Thanks and cheers,
>>> Chris.
>>> *="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List*
>>> *ms.matronics.com/ <http://ms.matronics.com/>">http://forums.matronics.com*
>>> *tp://www.matronics.com/contribution">http://www.matronics.com/contribution*
>>> *http://www.matronics.com/Navigator?Yak-List*
>>> *http://forums.matronics.com*
>>> *http://www.matronics.com/contribution*
>>> style="color: blue; text-decoration: underline; ">http://www.matronics.com/Navigator?Yak-List
>>> blue; text-decoration: underline; ">http://forums.matronics.com
>>> style="color: blue; text-decoration: underline; ">http://www.matronics.com/contribution
>> et="_blank">http://www.matronics.com/Navigator?Yak-List
>> _blank">http://www.matronics.com/contribution
>> Clifford Coy
>> Border Air Ltd.
>> 629 Airport Rd.
>> Swanton, VT 05488
>> 802-868-2822 TEL
>> 802-868-4465 FAX
>> Skype: Cliff.Coy
>> href="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List
>> href="http://forums.matronics.com/">http://forums.matronics.com
>> href="http://www.matronics.com/contribution">http://www.matronics.com/contribution
> ums.matronics.com">http://forums.matronics.com
kregg(at)balancemyprop.co
PostPosted: Sun Jul 10, 2011 2:05 pm    Post subject: plugs Reply with quote
I also have custom machined sparkplug wire to magneto cover listed on my
ebay store. High quality CNC machined aluminum, and you can purchase wires
from Kingston.
Kregg
Victory Aero LLC
2502 John Montgomery Dr.
San Jose, CA 95148
408-836-5122
www.balancemyprop.com
okanoganlew(at)gmail.com
PostPosted: Sun Jul 10, 2011 2:19 pm    Post subject: plugs Reply with quote
Guys, I watched Bud & Ross Granley perform an incredible aerobatic routine at the Arlington Fly-In this last weekend.  Bud flys a Yak 55 & Ross a Yak 18T with M14P engines.  I took a close look & saw that they both had auto spark plug conversions with silicon plug wires.  Seem that they are very confident with that conversion!!
Paul Lewis
On Sun, Jul 10, 2011 at 6:06 AM, A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote:
[quote]--> Yak-List message posted by: "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)>
Thank you Didier.  I am now offering CNC machined front cover plates in a "Deluxe" kit or they can be purchased as a separate item as well.  Available on my web site.
Dennis
A. Dennis Savarese
[url=tel:334-285-6263]334-285-6263[/url]
[url=tel:334-546-8182]334-546-8182[/url] (cell)
Skype: Yakguy1
www.yak-52.com
Thank you Dennis!!!
Didier Blouzard
[url=tel:%2B33%280%296%202424%203672]+33(0)6 2424 3672[/url]
Le 10 juil. 2011 à 05:01, Eric Wobschall <eric(at)buffaloskyline.com (eric(at)buffaloskyline.com) <mailto:eric(at)buffaloskyline.com (eric(at)buffaloskyline.com)>> a écrit :
*All I can say is that if you want to keep the ignition system that was designed and produced for the engine and replace the wires with new silicone wires, I've got plenty of it.
Cheers,
Cliff
On Sat, Jul 9, 2011 at 21:24, Eric Wobschall <eric(at)buffaloskyline.com (eric(at)buffaloskyline.com) <mailto:eric(at)buffaloskyline.com (eric(at)buffaloskyline.com)>> wrote:
   see the arcing.
   G’Day Jim,
   pouring rain.
   Chris.
   *From:*owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)
   <mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)>[mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)
   <mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)>]*On Behalf
   Of*cjpilot710(at)aol.com (cjpilot710(at)aol.com) <mailto:cjpilot710(at)aol.com (cjpilot710(at)aol.com)>
   *To:*yak-list(at)matronics.com (yak-list(at)matronics.com) <mailto:yak-list(at)matronics.com (yak-list(at)matronics.com)>
   *Subject:*Re: plugs
   goat" run?
   Jim "Pappy" Goolsby
   Time,wise(at)txc.net.au (wise(at)txc.net.au) <mailto:wise(at)txc.net.au (wise(at)txc.net.au)>writes:
       G’Day All,
       Thanks and cheers,
       Chris.
       *="http://www.matronics.com/Navigator?Yak-List">[url=http://www.matronics.com/Navigator?Yak-List*]http://www.matronics.com/Navigator?Yak-List*[/url]
       *tp://www.matronics.com/contribution">[url=http://www.matronics.com/contribution*]http://www.matronics.com/contribution*[/url]
   *[url=http://www.matronics.com/Navigator?Yak-List*]http://www.matronics.com/Navigator?Yak-List*[/url]
   *[url=http://www.matronics.com/contribution*]http://www.matronics.com/contribution*[/url]
Clifford Coy
Border Air Ltd.
629 Airport Rd.
Swanton, VT 05488
[url=tel:802-868-2822]802-868-2822[/url] TEL
[url=tel:802-868-4465]802-868-4465[/url] FAX
Skype: Cliff.Coy
rget="_blank">http://www.matronics.com/Navigator?Yak-List
le, List Admin.
brian(at)lloyd.com
PostPosted: Sun Jul 10, 2011 2:27 pm    Post subject: plugs Reply with quote
On Sun, Jul 10, 2011 at 3:16 PM, Paul Lewis <okanoganlew(at)gmail.com (okanoganlew(at)gmail.com)> wrote:
Automotive technology tends to be at least an order of magnitude more modern than aviation technology.
Paul Lewis
Dennis
A. Dennis Savarese
Skype: Yakguy1
www.yak-52.com
Thank you Dennis!!!
Didier Blouzard
Cheers,
Cliff
   see the arcing.
   G’Day Jim,
   pouring rain.
   Chris.
   *Subject:*Re: plugs
   goat" run?
   Jim "Pappy" Goolsby
       G’Day All,
       Thanks and cheers,
       Chris.
Clifford Coy
Border Air Ltd.
629 Airport Rd.
Swanton, VT 05488
Skype: Cliff.Coy
le, List Admin.
Brian Lloyd, WB6RQN/J79BPL
3191 Western Dr.
Cameron Park, CA 95682
brian(at)lloyd.com (brian(at)lloyd.com)
+1.767.617.1365 (Dominica)
+1.916.877.5067 (USA)
