Posted: Sun Jul 10, 2011 1:11 pm Post subject: Stits repair |
I am trying to repair a chafed spot on a wing, due to a storm blowing a tarp around. I cleaned off the Poly Tone with MEK, cemented and shrunk a patch in place. I applied the Poly Brush, and when the first coat was dry I noticed a bare spot about 1" square. Tried again, and the bare spot was still there. Cleaned with MEK, and tried again. Cleaned with thinner, and tried again. Still have a bare spot that seems to repel Poly Brush. Anybody have a reason and a solution? The rest of the patch is fine. The whole thing is about 4" square.
Bill Sullivan
Windsor Locks, Ct.
FS 447
Mike Welch
Posted: Sun Jul 10, 2011 3:08 pm Post subject: Stits repair |
Bill, try letting the Poly Brush "air out' some, letting some of the MEK vapors
escape. Maybe a slightly richer solution of the P. Brush will keep the MEK from
'washing' the repair. Or, as an alternative, if you have any Poly Tak available,
try a quick coat of that and see if it works.
Mike Welch
Date: Sun, 10 Jul 2011 14:09:16 -0700
Subject: Stits repair
Bill Sullivan
Windsor Locks, Ct.
FS 447
http://forums.matronics.com
Posted: Sun Jul 10, 2011 3:25 pm Post subject: Stits repair |
Mike- I let it air out (gas off) for 3 days, and still had the problem. I will try a coat of Poly Tak. Thanks. I'll let you know. I just checked it- the spot is the size of a nickle.
--- On Sun, 7/10/11, Mike Welch <mdnanwelch7(at)hotmail.com> wrote:
Subject: RE: Stits repair
Date: Sunday, July 10, 2011, 7:05 PM
Mike Welch
Bill Sullivan
Windsor Locks, Ct.
FS 447
get=_blank rel=nofollow>http://www.matronics.com/Navigator?Kolb-List
=nofollow>http://forums.matronics.com
blank rel=nofollow>http://www.matronics.com/contribution
| [quote][b]
rickofudall
Posted: Sun Jul 10, 2011 3:30 pm Post subject: Stits repair |
Bill, Why not just take the patch off and put on another? No sense beating your brains out. You've gotten some kind of contamination on the cloth that prevents it from wicking up the chemicals. Fiberglass will do the same thing if you get a drop of sweat on it (or any water, for that matter) and the resin will not penetrate.
Rick Girard
On Sun, Jul 10, 2011 at 4:09 PM, william sullivan <williamtsullivan(at)att.net (williamtsullivan(at)att.net)> wrote:
| Quote: | I am trying to repair a chafed spot on a wing, due to a storm blowing a tarp around. I cleaned off the Poly Tone with MEK, cemented and shrunk a patch in place. I applied the Poly Brush, and when the first coat was dry I noticed a bare spot about 1" square. Tried again, and the bare spot was still there. Cleaned with MEK, and tried again. Cleaned with thinner, and tried again. Still have a bare spot that seems to repel Poly Brush. Anybody have a reason and a solution? The rest of the patch is fine. The whole thing is about 4" square.
Bill Sullivan
Windsor Locks, Ct.
FS 447
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
Posted: Sun Jul 10, 2011 4:25 pm Post subject: Stits repair |
that is from oil contamination. Car painters call them fish eyes. It has worked itself through the weave and would be hard to rinse away.Auto paint shops sell (or did) a surfactant that you drip with a measuring eyedropper into the paint you are applying that will overcome most problems.
BB
On 10, Jul 2011, at 7:23 PM, william sullivan wrote:
[quote]Mike- I let it air out (gas off) for 3 days, and still had the problem. I will try a coat of Poly Tak. Thanks. I'll let you know. I just checked it- the spot is the size of a nickle.
--- On Sun, 7/10/11, Mike Welch <mdnanwelch7(at)hotmail.com (mdnanwelch7(at)hotmail.com)> wrote:
From: Mike Welch <mdnanwelch7(at)hotmail.com (mdnanwelch7(at)hotmail.com)>
Mike Welch
From: williamtsullivan(at)att.net (williamtsullivan(at)att.net)
Bill Sullivan
Windsor Locks, Ct.
FS 447
| [b]
Posted: Sun Jul 10, 2011 4:26 pm Post subject: Stits repair |
Rick- I had thought of contamination, maybe some kind of clear oil?- but the Poly Tak under that area seems to be holding normally. Maybe, like you said, sweat. I am going to try the "fill it with Poly Tak" method first. It is a 4" x 4" patch over a chafed spot about 2" long by 1/2" high. No big deal to take it off if I have to. Thanks.
Bill Sullivan
--- On Sun, 7/10/11, Richard Girard <aslsa.rng(at)gmail.com> wrote:
Subject: Re: Stits repair
Date: Sunday, July 10, 2011, 7:28 PM
Rick Girard
Bill Sullivan
Windsor Locks, Ct.
FS 447
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
| [quote][b]
