frank.hinde(at)hp.com Guest
Posted: Wed May 17, 2006 12:35 pm Post subject: Empanage fairings |
Hey all,
The little alu fairings that go under the empanage that are screwed to
the fuse upper angle.
The plans imply that you countersink through the fairing into the skin
and angle. As the fairing is only 25thou thick, the C/S will open up the
hole quite a bit. My tempatation is to dimple the holes for the #6
screws and then C/S the fuse underneath.
The probem is that the C/S would then have to be deeper and I'm a little
nervous of cutting a c/s too far into the angles as these are structural
elements.
What did others do?
Frank
RV7a almost at the paint!
| | - The Matronics RV7-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV7-List |
dan(at)rvproject.com Guest
Posted: Wed May 17, 2006 1:01 pm Post subject: Empanage fairings |
Tinnerman washers.
)_( Dan
RV-7 N714D (907 hours)
http://www.rvproject.com
flyer01(at)adelphia.net Guest
Posted: Wed May 17, 2006 1:36 pm Post subject: Empanage fairings |
I used a #40 drill and dimpled the fairing and countersunk the skin/angle and riveted it on.
---- "Hinde wrote:
Hey all,
elements.
What did others do?
Frank
Posted: Wed May 17, 2006 2:06 pm Post subject: Empanage fairings |
My bad! I thought you meant the empennage fairing, the fiberglass one.
Pretty sure I dimpled the gap cover and c-sunk the fuselage. I'd be very
tempted to rivet it on, but then you can't change the rubber seal easily.
)_( Dan
schybolt(at)verizon.net Guest
Posted: Wed May 17, 2006 3:30 pm Post subject: Empanage fairings |
