paul.r.kuntz(at)gmail.com Guest
Posted: Fri Jul 15, 2011 9:33 pm Post subject: ELT antenna placement |
I'm installing a 121.5/406 MHz ELT in my homebuilt project.� The installation instructions tell me to put the ELT whip antenna at least 3 feet from my VHF radio antenna.� Is this really necessary?� There is the possibility of manually activating the ELT in the air in the event of an emergency, while continuing to communicate with the VHF radio, but I'm thinking that the more likely scenarios will be to operate one or the other, but not both.� That is, the ELT becomes a factor only in the case of a true emergency, in which case I would first squawk emergency and communicate the situation by VHF voice (flying the airplane first, of course).� Then, activate the ELT (one button press) if a forced landing appears inevitable, but I'm probably done talking on the radio at that point.
Is the concern simply the presence of another vertically oriented conductor in relatively close proximity to the antenna in use, thus influencing its performance?� Even if both the ELT and the VHF radio are active at the same time, is 3 ft of separation important?
At any rate, it would be more convenient from an installation perspective to put them closer together.� Any advice?
Paul Kuntz
email(at)jaredyates.com Guest
Posted: Sat Jul 16, 2011 12:42 am Post subject: ELT antenna placement |
In one prior case, we had an airplane that was transmitting ground control voice (121.9) over 121.5. We attributed it to resonance on the elt antenna, which was in a non standard location for that type, closer than normal to the vhf com. After moving the elt antenna back a couple of feet the bleed over stopped. This type of problem might be something to consider in your decision.
On Jul 16, 2011, at 1:28, Paul Kuntz <paul.r.kuntz(at)gmail.com (paul.r.kuntz(at)gmail.com)> wrote:
[quote]I'm installing a 121.5/406 MHz ELT in my homebuilt project. The installation instructions tell me to put the ELT whip antenna at least 3 feet from my VHF radio antenna. Is this really necessary? There is the possibility of manually activating the ELT in the air in the event of an emergency, while continuing to communicate with the VHF radio, but I'm thinking that the more likely scenarios will be to operate one or the other, but not both. That is, the ELT becomes a factor only in the case of a true emergency, in which case I would first squawk emergency and communicate the situation by VHF voice (flying the airplane first, of course). Then, activate the ELT (one button press) if a forced landing appears inevitable, but I'm probably done talking on the radio at that point.
Is the concern simply the presence of another vertically oriented conductor in relatively close proximity to the antenna in use, thus influencing its performance? Even if both the ELT and the VHF radio are active at the same time, is 3 ft of separation important?
At any rate, it would be more convenient from an installation perspective to put them closer together. Any advice?
Paul Kuntz
bakerocb
Posted: Sat Jul 16, 2011 3:10 am Post subject: ELT antenna placement |
7/16/2011
Hello Paul, You wrote: "Is this really necessary?"
After 6 years plus of construction and many hours of preparation for the
first flight in my KIS TR-1 experimental amateur built aircraft I was unable
to taxi out of the apron area because every time I keyed my number one VHF
com radio to request taxi clearance from ground control the ELT transmitter
was activated -- very frustrating.
The problem was caused by proximity and orientation of the antennas of the
two devices. I eventually relocated the ELT antenna -- problem solved.
OC
PS for Bruce: Knowledge of 14 CFR 91.207 (f) (4) permitted me to disable the
ELT and complete the first flight as plannned.
Time: 10:33:48 PM PST US
Subject: ELT antenna placement
Paul Kuntz
Posted: Sat Jul 16, 2011 4:13 am Post subject: ELT antenna placement |
I agree, I've seen comm radios set of a nearby ELT on several
occasions. It's not uncommon at all.
I'd keep those antennas away from each other.
Dave Saylor
AirCrafters
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
On Sat, Jul 16, 2011 at 4:06 AM, <bakerocb(at)cox.net> wrote:
Quote: |
7/16/2011
OC
Paul Kuntz
Kellym
Joined: 10 Jan 2006 Posts: 1705 Location: Sun Lakes AZ
Posted: Sat Jul 16, 2011 6:30 am Post subject: ELT antenna placement |
Another risk is that many ELT transmitters are poorly shielded from
strong adjacent RF. Flying near a TV or FM transmitter antenna can cause
the oscillator of the ELT transmitter to radiate harmonics, which then
are picked up by your com radio, breaking squelch and causing poor
reception. My plane used to suffer from this syndrome until I moved one
of the VHF antennas to the belly.
Dave Saylor
AirCrafters
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
On Sat, Jul 16, 2011 at 4:06 AM,<bakerocb(at)cox.net> wrote:
> 7/16/2011
> OC
> From: Paul Kuntz<paul.r.kuntz(at)gmail.com>
> Thanks,
> Paul Kuntz
KCHD |
Posted: Sat Jul 16, 2011 6:54 am Post subject: ELT antenna placement |
At 07:10 AM 7/16/2011, you wrote:
Saylor <dave.saylor.aircrafters(at)gmail.com>
It would appear to be the only option. It
may be very $difficult$ to fix what appears
to be a design bug internal to the ELT.
The earliest ELT's used a spring-loaded
mass to close an activation switch in response
to g-forces of a crash. No doubt modern ELTs
use the solid-state acceleration sensors
for this task . . . which produce VERY tiny
signals requiring a lot of circuit gain.
This type of circuitry offers a high risk
of vulnerability to RF interference. This
may be an area where qualification of the
device to standard DO-160 (good for part
23) stresses was insufficient to stand off
the extra-ordinary vulnerabilities of these
kinds of circuits. A lot of hardware we
did for the military and for Part-25 and up
applications was exposed to really nasty
RF radiation . . . 200 volts/meter or more
. . . during qualification. No doubt this
extra step in qualification would have exposed
vulnerabilities that are now plaguing customers.
> Paul wrote:
> I'm installing a 121.5/406 MHz ELT in my homebuilt project. � The
> feet from my VHF radio antenna. � Is this really necessary? � There is the
> but not both. � That is, the ELT becomes a factor only in the case of a true
> situation by VHF voice (flying the airplane first, of course). � Then,
> performance? � Even if both the ELT and the VHF radio are active at the same
> put them closer together. � Any advice?
Give it a try . . . but with a Plan-B for moving
one or both of the antennas to achieve demonstrably
necessary separation. I suspect that not all ELT
products are victim to the hypothesized vulnerability
I cited above. There are no grave performance issues
that would arise from antenna proximity issues so if
you "get away Scott free" with your desired configuration,
you're good to go.
Posted: Sat Jul 16, 2011 7:19 am Post subject: ELT antenna placement |
cause the oscillator of the ELT transmitter to radiate harmonics,
which then are picked up by your com radio, breaking squelch and
causing poor reception. My plane used to suffer from this syndrome
until I moved one of the VHF antennas to the belly.
Interesting! I hadn't thought of that scenario. Unlike
transceivers where the antenna is connected to a receiver
input circuit 99.9% of the time, the ELT antenna is
permanently connected to the output circuitry of a
transmitter's power output stage.
A strong analog TV station impressed on the ELT
antenna could be conducted into the non-linear,
transistor junctions where the TV signal could
produce inter-modulation products that spread over
a very wide spectrum. Now that we're all-digital
in the off-air TV world, I suspect probability
is reduced. I'm aware of no other "trash rich"
high power signals that would produce this
effect today.
This is a phenomenon that was never explored
by DO-160 although I've read some military
qualification test protocols that do look for
inter-modulation mixing and re-radiation of
foreign energies coming down the antenna feedline.
BobsV35B(at)aol.com Guest
Posted: Sat Jul 16, 2011 7:49 am Post subject: ELT antenna placement |
Good Morning Paul and Jared,
Way out of my area of expertise, but it is my understanding that having another vertical metal element close to the transmitting or receiving antenna makes the combination very directional. Rarely a problem when close to the station but could reduce the range capability at some angles from the aircraft.
Happy Skies,
Old Bob
In a message dated 7/16/2011 3:42:58 A.M. Central Daylight Time, email(at)jaredyates.com writes:
Quote: | In one prior case, we had an airplane that was transmitting ground control voice (121.9) over 121.5. We attributed it to resonance on the elt antenna, which was in a non standard location for that type, closer than normal to the vhf com. After moving the elt antenna back a couple of feet the bleed over stopped. This type of problem might be something to consider in your decision.
Quote: | I'm installing a 121.5/406 MHz ELT in my homebuilt project. The installation instructions tell me to put the ELT whip antenna at least 3 feet from my VHF radio antenna. Is this really necessary? There is the possibility of manually activating the ELT in the air in the event of an emergency, while continuing to communicate with the VHF radio, but I'm thinking that the more likely scenarios will be to operate one or the other, but not both. That is, the ELT becomes a factor only in the case of a true emergency, in which case I would first squawk emergency and communicate the situation by VHF voice (flying the airplane first, of course).� Then, activate the ELT (one button press) if a forced landing appears inevitable, but I'm probably done talking on the radio at that point.
Paul Kuntz
Kellym
Posted: Sat Jul 16, 2011 4:06 pm Post subject: ELT antenna placement |
It was particularly obnoxious in Phoenix, where the VFR transition over
Sky Harbor has you aimed right at an antenna farm that has 80 percent of
all broadcast stations for the area, distance less than 7 nm. Probably a
few million watts being radiated between the FM and TV stations
transmitters there. As soon as I disconnected the ELT coax from the ELT,
I could fly right up within a mile of those towers with no problem, but
with it connected, as soon as I got within 10 nm constant squelch break
and weak reception both on KX155 and on KX170(McCoy conversion). Had it
happen elsewhere, but not where it caused problems when I had to be in
communication with approach inside Class B airspace. Fixed as soon as I
removed one of Comant 121 antennas from top of fuselage and replaced
with Comant 122 on belly. I've heard of many other ELT installs having
same problem. As you say, I don't think there were a lot of requirements
for RF interference back in 1973 when the TSO was originally written.
effect today.
KCHD |
Posted: Sat Jul 16, 2011 5:51 pm Post subject: ELT antenna placement |
Thanks for all the feedback.� Seems like the prudent approach will be to accept the ELT installation instructions and mount the ELT at the specified 3+ feet of separation from the VHF antenna.� I'd rather do that now than face the potential for troubleshooting and installation rework later.
Paul Kuntz
On Sat, Jul 16, 2011 at 7:51 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
[quote]--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
--> AeroElectric-List message posted by: Dave Saylor <dave.saylor.aircrafters(at)gmail.com (dave.saylor.aircrafters(at)gmail.com)>
occasions. �It's not uncommon at all.
� It would appear to be the only option. It
� may be very $difficult$ to fix what appears
� to be a design bug internal to the ELT.
� The earliest ELT's used a spring-loaded
� mass to close an activation switch in response
� to g-forces of a crash. No doubt modern ELTs
� use the solid-state acceleration sensors
� for this task . . . which produce VERY tiny
� signals requiring a lot of circuit gain.
� This type of circuitry offers a high risk
� of vulnerability to RF interference. This
� may be an area where qualification of the
� device to standard DO-160 (good for part
� 23) stresses was insufficient to stand off
� the extra-ordinary vulnerabilities of these
� kinds of circuits. �A lot of hardware we
� did for the military and for Part-25 and up
� applications was exposed to really nasty
� RF radiation . . . 200 volts/meter or more
� . . . during qualification. No doubt this
� extra step in qualification would have exposed
� vulnerabilities that are now plaguing customers.
� Give it a try . . . but with a Plan-B for moving
� one or both of the antennas to achieve demonstrably
� necessary separation. I suspect that not all ELT
� products are victim to the hypothesized vulnerability
� I cited above. There are no grave performance issues
� that would arise from antenna proximity issues so if
� you "get away Scott free" with your desired configuration,
� you're good to go.
�Bob . . .
-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
http://forums.matronics.com
le, List Admin.
