strobe power supply
sportav8r(at)gmail.com
PostPosted: Fri Jul 15, 2011 6:48 am    Post subject: strobe power supply Reply with quote
My decades-old Whelen supply now flashes only one of two tubes even if I reverse the tube cables - looks like one channel is dead. No longer makes the whining sound when operational, either. �Looking to replace with a suitable Whelen supply not made for aviation use but similar energy output.�
Any reason a Whelen CPS 660 or 690 wouldn't work? �Much cheaper on Ebay than any of the aviation power supplies.
-Bill B
Mike Welch
PostPosted: Fri Jul 15, 2011 7:14 am    Post subject: strobe power supply Reply with quote
Boyd,
� That kind of like the strobe power supplies I use.� They are built for the "emergency
vehicle" use (police, fire engines, etc) strobes.� They flash my 'Beech Aircraft' strobe
units just fine!!� The units are made by "Optimax".�
Mike Welch
Date: Fri, 15 Jul 2011 10:45:05 -0400
Subject: strobe power supply
-Bill B
-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
http://forums.matronics.com
n744bh(at)bellsouth.net
PostPosted: Fri Jul 15, 2011 8:30 am    Post subject: strobe power supply Reply with quote
Bill,
Is the strobe that does flash the same one when you reverse the cables? I had a similar problem a couple of years ago and it turned out to be a burned out strobe lamp.
Bill
Glasair SIIS-FT
PostPosted: Fri Jul 15, 2011 8:50 am    Post subject: strobe power supply Reply with quote
Yes, noticed the problem when I replaced an obviously burned out strobe head - the replacement didn't fix the issue. �Swapped cables and verified each strobe head will flash normally, it's a dead channel in the PS, possibly from trying to fire a burned-out strobe head for awhile...
On Fri, Jul 15, 2011 at 12:27 PM, Bill Hibbing <n744bh(at)bellsouth.net (n744bh(at)bellsouth.net)> wrote:
[quote] Bill,
Is the strobe that does flash the same one when you reverse the cables?� I had a similar problem a couple of years ago and it turned out to be a burned out strobe lamp.�
Bill
Glasair SIIS-FT
