rockford67
Posted: Thu Jul 21, 2011 8:13 am Post subject: Firewall |
Hey Builders,
Was there any specific instruction on installing a firewall in the pulsar xp? Mine seems to have an aluminum one, but I MUST have something proven to be fire rated. My inspector suggests that a lot of glass planes used fibrefax on the firewall which may suffice, and with the aluminum on top would be fine, however, I can't seem to find anything in the manuals and logs describing any specific application. What did most of you do?
The standard acceptable firewall here is Stainless steel. My plan is to add a stainless layer over top of the aluminum one as it appears to be bonded in and I'd prefer not to remove it. Of course, if there is fibrefax behind as part of the original fuse kit then I'm good too...
Any thoughts?
Chris
| | - The Matronics Pulsar-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Pulsar-List |
sonja.englert(at)juno.com Guest
Posted: Thu Jul 21, 2011 9:18 am Post subject: Firewall |
I have a stainless steel firewall. It would make sense to remove the aluminum, it does nothing but add weight.
Sonja
____________________________________________________________
Mortgage Rates at 2.37%
$250,000 loan for $650/month. See New Payment - No SSN Rqd. Save Now!
http://thirdpartyoffers.juno.com/TGL3131/4e285f2b989ac1256best06duc
pulsar331(at)sbcglobal.ne Guest
Posted: Thu Jul 21, 2011 9:57 am Post subject: Firewall |
I used Fiberfax with aluminum over it. The aluminum not only slows down any fire damage but keeps the Fiberfax clean and in place. It seemed to be a pretty popular way to go back when Pulsars were being built (sorry Tom) so yours may already have it installed behind the aluminum.
N331BP
Pulsar XP
To: pulsar-list(at)matronics.com
Sent: Thu, July 21, 2011 12:13:16 PM
Subject: Firewall
--> Pulsar-List message posted by: "rockford67" <cphorsten(at)yahoo.ca (cphorsten(at)yahoo.ca)>
Hey Builders,
Any thoughts?
Chris
http://forums.matronics.com/viewtopic.php?p=347314#347314
< -Matt Drall============
rockford67
Posted: Thu Jul 21, 2011 7:47 pm Post subject: Re: Firewall |
| sonja.englert(at)juno.com wrote: | I have a stainless steel firewall. It would make sense to remove the aluminum, it does nothing but add weight.
Sonja
http://thirdpartyoffers.juno.com/TGL3131/4e285f2b989ac1256best06duc |
Sonja,
I'm going to see what behind the aluminum first, and if its fibrefax leave it alone if that's okay with my inspector. If not, I'll probably pull it off as you suggest. I might shave a couple pounds off in the process.
C
esalehto(at)yahoo.com Guest
Posted: Fri Jul 22, 2011 8:48 am Post subject: Firewall |
Hi Chris,
I have fibrefax and stainless steel top of that.
-Esa
Sent: Thursday, July 21, 2011 11:13 AM
Subject: Firewall
Hey Builders,
Any thoughts?
Chris
http://forums.matronics.com/viewtopic.php?p=347314#347314http://www.matronics.com/Navigator?Pulsar-Li>
