andynfultz(at)bellsouth.n Guest
Posted: Sat Jul 23, 2011 7:35 pm Post subject: Stripped Threads ? |
[quote] Have any of you STRATUS guys ever had to deal with stripped threads on any of the case bolts? Bought my engine in 2000 and since got it mounted and ran it on the ground a few times. Started flying June 14, 2011. At 42 hours flight time I noticed an oil leak on the lower right side of the engine, from the front looking aft. The oil was coming from the lower case bolt head. Tried to tighten and it did not tighten. Threads stripped in the case, obviously done at STRATUS when the engine was assembled. Has anybody else had this or similar problems. Planning to install a helicoil, but would you go ahead and helicoil all the case bolts or just hope that none of the others strip on reassembly of the engine? Thanks.
Andy F.
| | - The Matronics Stratus-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Stratus-List |
d3dw(at)sbcglobal.net Guest
Posted: Sun Jul 24, 2011 4:53 am Post subject: Stripped Threads ? |
Yeah, Andy, I had the same issue. I just helicoiled the two I discovered and that solved it for me. I think I would test the threads to see how they seem to hold. don 450 hours
To: stratus-list(at)matronics.com
Sent: Sat, July 23, 2011 10:33:22 PM
Subject: Stripped Threads ?
DIV { MARGIN:0px;}
Andy F.
[b][b]
Posted: Tue Jul 26, 2011 6:53 pm Post subject: Stripped Threads ? |
Thanks Guys for the replies. I will just fix the one I know about now and hope none of the rest are weak. Hopin' to be back in the air soon. Blue skies.
Andy F.
[quote] --
