rdmac(at)swbell.net Guest
Posted: Thu May 18, 2006 6:22 pm Post subject: Gap Seal Affect |
I'm getting ready to look into sealing the gap between the
elevator and stab. on my model 7 and was wandering what affect it had on the
flying characteristics.
Does it make it more pitch sensitive or just give you more pitch authority?
I read in the archives that sealing the gap gives you more pitch authority
but does it also make it more pitch sensitive? And what about speed does it
help out any there too...Opinions and comments please.
Roger Mac
janderson412(at)hotmail.c Guest
Posted: Thu May 18, 2006 6:38 pm Post subject: Gap Seal Affect |
Most of the 5s and up seem to have a forward CofG configuration due to heavy
engines, it helps getting the a/c to stall.
From: "Donna and Roger McConnell" <rdmac(at)swbell.net>
Subject: Gap Seal Affect
Date: Thu, 18 May 2006 21:21:06 -0500
Roger Mac
Need more speed? Get Xtra Broadband (at)
http://jetstream.xtra.co.nz/chm/0,,202853-1000,00.html
Graeme Toft
Posted: Fri May 19, 2006 1:25 am Post subject: Gap Seal Affect |
Hi Roger, I'll echo Michels sentiments here also. I couldn't believe the
difference after filling the control surface gaps on my model 1. I think the
greatest benefit for me was the confidence it gave me in landing because I
new the responce from both elevators and the rudder would be there when
needed the most. Before my 1V is complete I will definetly be filling gaps
because in comparison to the model 1, they are much larger between elevator
and rudder and I feel a lot of authority can be gained by applying a simple
fix.
Graeme -----
Original Message -----
Sent: Friday, May 19, 2006 4:24 PM
Subject: SV: Gap Seal Affect
> From: Donna and Roger McConnell [rdmac(at)swbell.net]
Hello Roger,
Before I gap sealed my model 3, I couldn't do a 3-points landing, the
plane would stall and touch the ground with the main gear first, even when
I was with the stick in my stomach. Now, it's just perfect.
I don't notice any more sensibility in the pitch, only that little extra
authority when the stick is entirely pulled and the plane is near stall
speed.
Michel
Version: 7.1.392 / Virus Database: 268.6.1/343 - Release Date: 18/05/2006
asq1(at)adelphia.net Guest
Posted: Fri May 19, 2006 2:33 am Post subject: Gap Seal Affect |
My experience with the 4-1200 Soob was exactly the same. Larry Huntley
davedawe(at)msn.com Guest
Posted: Fri May 19, 2006 2:35 am Post subject: Gap Seal Affect |
Any photos showing gap seal installed
| Quote: | From: "John Anderson" <janderson412(at)hotmail.com>
Subject: RE: Gap Seal Affect
Date: Fri, 19 May 2006 14:36:22 +1200
heavy
the
Roger Mac
morid(at)northland.lib.mi Guest
Posted: Fri May 19, 2006 3:04 am Post subject: Gap Seal Affect |
You probably won't notice an iota of difference in cruise, but with mine
there was a definite increase in the flare performance.
Deke
the
| Quote: | flying characteristics.
authority?
| Quote: | I read in the archives that sealing the gap gives you more pitch authority
it
| Quote: | help out any there too...Opinions and comments please.
Roger Mac
bmwebb(at)cox.net Guest
Posted: Fri May 19, 2006 3:06 am Post subject: Gap Seal Affect |
My experience has been positive, as well. Although, I didn't notice a huge
change, it did give me some more authority at low speeds.
Sealing gaps in control surfaces does not change flutter characteristics.
Some testing years ago (working from a faded memory here), showed that gaps
contribute to something like 30% control effectiveness loss. Nature abhors a
vacuum, and seeks low pressure. So the leak from one side to the other
affects the ability of the control to do its job.
I did not notice any sensitivity increase on my 2. I used thick laminating
film from the office supply store, and applied it like the pics on
Sportflight.com. Very easy to do, took all of 30 minutes to apply, and is
virtually invisible.
If you do run into sensitivity issues, you can correct that with CG changes.
Moving the CG forward "softens" the elevator, and aft makes it more
sensitive and gives more authority. Too far forward, and you might not be
able to raise the nose at low speeds. Too far aft, and it will get so
sensitive as to be uncontrollable.
Bradley
Posted: Fri May 19, 2006 3:18 am Post subject: Gap Seal Affect |
Michel,
I meant to ask you a while back on this subject: how is your CG? Mine
is(was) a bit nose heavy, and I think that is why I couldn't 3 point with
flaps. The gap seals have helped, but to get the tail wheel down, it's still
tough.
I'm in the midst of an engine change, so my CG is somewhere near the
elevator at the moment. But I am going to try to get it further aft when
done.
Bradley
Posted: Fri May 19, 2006 3:56 am Post subject: Gap Seal Affect |
I gap sealed my rudder, for the same reasons that you stated. Seems to be
ok. At least, I haven't noticed any adverse effects.
I didn't mention the effects of CG on the Yaw axis. I assume it could make
the tail squirrelly with aft CG. Good point.
Bradley
Posted: Sat May 20, 2006 12:14 am Post subject: Gap Seal Affect |
Tomorrow on Sport flight...
Date: Fri, 19 May 2006 08:04:59 -0230
>heavy
>the
authority?
it
> Roger Mac
>_________________________________________________________________
Discover fun and games at (at) http://xtramsn.co.nz/kids
Jim Shumaker
Posted: Sat May 20, 2006 4:33 pm Post subject: Gap Seal Affect |
Yes, I put up a picture a few months ago.
Jim Shumaker
heavy
To:
the
authority?
it
_________________ Jim Shumaker |
jeburke94je(at)hughes.net Guest
