Split brake line
GrummanDude
PostPosted: Thu May 18, 2006 10:39 pm    Post subject: Split brake line Reply with quote
Here's one for the books.
A customer complained of brake fluid dripping out of the weep holes on the
bottom. I looked all over the brake master cylinders, flex brake lines, etc.
Nothing. Several months ago, I put clean white rags under the pedals to see
if I could find the source of the brake fluid. Nothing.
So, this annual I pulled the pilot's seat, side panels and kick panels. The
brake line is spline along it's seam (that's what it looks like) about 18
inches forward of where it exits the cabin and goes into the wing. This
location is just forward of where it bends to go along the corner of the cabin floor.
Anyone heard of this?
Gary
Gary
AuCountry Aviation
Home of Team Grumman
flyv35b(at)ashcreekwirele
PostPosted: Fri May 19, 2006 5:02 am    Post subject: Split brake line Reply with quote
Nope. Sounds like a real rarity to me. If it was a defective made tubing
it sure took a long time to manifest itself.
Cliff
GrummanDude
PostPosted: Fri May 19, 2006 11:01 pm    Post subject: Split brake line Reply with quote
In a message dated 5/19/06 6:03:36 AM, flyv35b(at)ashcreekwireless.com writes:
Nope.=A0 Sounds like a real rarity to me.=A0 If it was a defective made tu
bing
I jumped to a conclusion based on the way a paper towel, laying against the
underside of the brake line, got soaked. When I removed the section of lin
e
that was leaking, there were aboout a dozen pin holes along the bottom of th
e
line for a distance of about 4 inches. There was no obvious evidence of
corrosion or chafing.
Gary
Gary
AuCountry Aviation
PostPosted: Sat May 20, 2006 5:06 am    Post subject: Split brake line Reply with quote
the
lin
e
th
e
Gary
Where did the pin holes come from if it was from corrosion?
Cliff
PostPosted: Sat May 20, 2006 5:31 am    Post subject: Split brake line Reply with quote
GrummanDude
PostPosted: Sat May 20, 2006 9:48 pm    Post subject: Split brake line Reply with quote
In a message dated 5/20/06 6:07:15 AM, flyv35b(at)ashcreekwireless.com writes:
Cliff
the brake line didn't show any signs of corrosion
Gary
AuCountry Aviation
FLYaDIVE(at)aol.com
PostPosted: Sun May 21, 2006 5:46 am    Post subject: Split brake line Reply with quote
In a message dated 5/21/06 1:49:23 AM Eastern Daylight Time,
TeamGrumman(at)aol.com writes:
> Cliff
No corrosion from the outside. But with a bit of moisture in the brake lines
you can have corrosion forming on the inside.
I'm guessing here ... Since planes sit for a very long time between uses.
And water is heavier than oil ... Or brake fluid.
I'm guessing the pin holes are in one of two places:
1 - Along the BOTTOM of the brake lines, [water settling along the bottom] or
2 - Along the seam of the brake line, if the tubing was ROLLED as opposed to
EXTRUDED. Rolled tubing has to be welded, when you weld you chance the
chemical make up at the location of the weld. This is true no matter how much you
try to use proper weld materials or atmosphere.
Barry
"Chop'd Liver"
