		arplnplt(at)gmail.com Guest
				 Posted: Mon Aug 08, 2011 6:13 am    Post subject: High EGT readings |
				I just finished my 40 hour phase I this weekend and noticed for the last few hours that my #1 and #2 EGT temp readings are a bit higher than the rest during low power settings.  Would this be a sign of failing probes or something else?
 Dave Leikam
		Kelly McMullen
				 Posted: Mon Aug 08, 2011 6:37 am    Post subject: High EGT readings |
				Not likely anything is wrong. you may want to download and graph what data you have, but you aren't going to have uniform balance at all power settings. If you have a tight spread at your normal cruise, that is about as good as you can hope for.
  Only if something has changed over last flight or two would I be looking for anything.
 On Mon, Aug 8, 2011 at 7:10 AM, David Leikam <arplnplt(at)gmail.com (arplnplt(at)gmail.com)> wrote:
   	  | Quote: | 	 		  --> RV10-List message posted by: David Leikam <arplnplt(at)gmail.com (arplnplt(at)gmail.com)>
  Dave Leikam
 #avg_ls_inline_popup{position: absolute;z-index: 9999;padding: 0px 0px;margin-left: 0px;margin-top: 0px;overflow: hidden;word-wrap: break-word;color: black;font-size: 10px;text-align: left;line-height: 130%;}  [quote][b]
A&P/IA, EAA Tech Counselor
KCHD |
		Tim Olson
				 Posted: Mon Aug 08, 2011 6:56 am    Post subject: High EGT readings |
				This is the problem with today's high res digital Engine Monitors...
 Now days you can SEE the exact number, and it makes you worry about
 things that would never have been a concern if you didn't have a
 string of real numbers in front of you.  of course, now days you
 can use these exacting numbers to see problems coming early
 on too. ... so there is a benefit.   It just takes a bunch of flight
 hours in varied conditions to start to see a real baseline normal.
 Tim Olson - RV-10 N104CD
 On 8/8/2011 9:33 AM, Kelly McMullen wrote:
  	  | Quote: | 	 		   Not likely anything is wrong. you may want to download and graph what
  for anything.
      Dave Leikam
		toaster73(at)embarqmail.c Guest
				 Posted: Mon Aug 08, 2011 9:52 am    Post subject: High EGT readings |
				I just had an experience with this in an RV-6.  The #1 cylinder was reading
 100 deg hotter than the rest in cruise. Turns out to be a deposit on the
 spark plug. It did not show up on mag check until later. SO I think the
 monitor did pick up the issue before the next mag check.  Cleaned plug and
 all is well and temps back into alignment.
 -Chris Lucas
 #40072
		Kelly McMullen
				 Posted: Mon Aug 08, 2011 12:40 pm    Post subject: High EGT readings |
				You can detect that either by in-flight mag check or mag check on the ground. When you go to single mag the EGT should go up about 100 degrees on all cylinders. If it doesn't on one or drops off, that plug is suspect.
 On Mon, Aug 8, 2011 at 10:44 AM, Chris <toaster73(at)embarqmail.com (toaster73(at)embarqmail.com)> wrote:
 [quote] --> RV10-List message posted by: "Chris" <toaster73(at)embarqmail.com (toaster73(at)embarqmail.com)>
  -Chris Lucas
  #40072
KCHD |
		Bob Turner
				 Posted: Tue Aug 09, 2011 3:36 pm    Post subject: Re: High EGT readings |
				I've seen an engine monitor pick up a weak mag or plug that passed the usual runup check. Full power operation is more demanding.
  _________________ Bob Turner
RV-10 QB |
