transducers
cjhukill(at)cox.net
PostPosted: Sat Aug 06, 2011 6:13 am    Post subject: transducers Reply with quote
The picture in the plans show that the oil and fuel pressure
transducers that attach to the manifold mounted on the firewall have
the transducers pointed down. The transducers that came with my Dynon
are to large in diameter to mount that way. The ones shown look to be
smaller diameter. Does anyone know what transducers are pictured in the
plans and if they are compatible with the Dynon Skyview?
Chris Hukill
n223rv(at)wolflakeairport
PostPosted: Sat Aug 06, 2011 6:41 am    Post subject: transducers Reply with quote
I have the SkyView in my -10. I used their transducers and have them pointed forward. Plenty of room. You are correct, they will not fit vertical. Let me know if you want a picture and I can dig one up.
-Mike Kraus
On Aug 6, 2011, at 9:58 AM, Chris Hukill <cjhukill(at)cox.net> wrote:
The picture in the plans show that the oil and fuel pressure transducers that attach to the manifold mounted on the firewall have the transducers pointed down. The transducers that came with my Dynon are to large in diameter to mount that way. The ones shown look to be smaller diameter. Does anyone know what transducers are pictured in the plans and if they are compatible with the Dynon Skyview?
Chris Hukill
rv10flyer
PostPosted: Sun Aug 07, 2011 6:08 am    Post subject: Re: transducers Reply with quote
I just inst grt fuel/oil pres senders. The plans show either a plug or ftg for hose on top and bottom and senders toward the front. I am not inst oil sw for light/hobbs. If you were it would go on the bottom.
Wayne G.
gnolin(at)sbcglobal.net
PostPosted: Sun Aug 07, 2011 8:27 am    Post subject: transducers Reply with quote
Use a 3/16 aluminum strip between the manifold and the firewall and they will fit. This will restore the manifold to three ports for each activity.
G. Hank Nolin, P.E.
832-640-6284
www.salestaxexemptions.com[url=http://www.salestaxexmptions.com/][/url]
"Science, freedom, beauty, adventure--aviation offers it all."
Charles A. Lindbergh
--- On Sat, 8/6/11, Chris Hukill <cjhukill(at)cox.net> wrote:
Subject: transducers
Date: Saturday, August 6, 2011, 8:58 AM
--> RV10-List message posted by: Chris Hukill <cjhukill(at)cox.net (cjhukill(at)cox.net)>
The picture in the plans show that the oil and fuel pressure transducers that attach to the manifold mounted on the firewall have the transducers pointed down. The transducers that came with my Dynon are to large in diameter to mount that way. The ones shown look to be smaller diameter. Does anyone know what transducers are pictured in the plans and if they are compatible with ht="http://forums.matronics.com/" target=_blank>http://forums.matronics.c &nbsf="http://www.matronics.com/contribution" =======
