johnwigney(at)windstream. Guest
				 Posted: Tue Aug 09, 2011 6:25 am    Post subject: Re : Painting Time |
				Hi Lance,
          I do not have any direct experience with the Stewart System.         However, I have spent some time talking with the Stewart people         at vendor stands at Sun N Fun and Oshkosh. A few observations :-
                    - The system is attractive since it uses non hazardous and           non flammable components.
 - The end result of a correct application will have an           excellent gloss.
 - However, word of mouth is that this system is very           unforgiving, i.e. the instructions have to be followed EXACTLY.           It seems that one has to be anal about this.
                  - The exact time between coats, the gun type, the gun air           supply, the gun settings, etc, etc, have to be EXACTLY as           specified. Otherwise you will get poor results.
       A suggestion is to find other kit builders in your area who       have done a spray job recently and follow their advice preferably       using local supplies. Despite needing an airmask I think that most       traditional isocyanate 2 part polyurethanes will be easier to use. If           you choose to use a local spray professional, he will also be           happier with these systems.
            Cheers, John
            N262WF, mono XS, 912S
            Mooresville, North Carolina
             ORIGINAL MESSAGE
      [quote]From: Lance Sandford <sandford(at)melbpc.org.au> (sandford(at)melbpc.org.au)
 Subject: Painting Time
 Hi Fellow Builders/Flyers
 Having finished most of filling/sanding, it is time to look at painting
 systems.
 Has anyone used or heard of results from using the Stewart Systems
 2-pack poly.
 It sounds more user friendly than some of the others.
 All thoughts gratefully received.
 Lance Sandford in Oz
  |  | - The Matronics Europa-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
