Primary Comm Radio
Goto page 1, 2  Next
kearney
PostPosted: Sun Aug 07, 2011 10:35 am    Post subject: Primary Comm Radio Reply with quote
Hi
I am in the final stages (yeah right!) of wiring my panel. I have a GNS430W and an SL30 amongst other toys. I am wondering which will be most used from a comm perspective. I plan to have a flip / flop on the stick and would like to make the right choice as to which radio is connected to the switch.
Any comments / opinions?
Cheers
Les
#40643 [quote][b]
robin(at)PaintTheWeb.com
PostPosted: Sun Aug 07, 2011 10:45 am    Post subject: Primary Comm Radio Reply with quote
430W.
Robin
Sent from Android phone
Probably while driving
On Aug 7, 2011 11:42 AM, "Les Kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
Hi
Cheers
Les
#40643
tp://forums.matronics.com
fehdxlbb(at)gmail.com
PostPosted: Sun Aug 07, 2011 10:51 am    Post subject: Primary Comm Radio Reply with quote
As a datapoint, I use the SL30 for ATC since I don't know the frequencies
ahead of time and have to twist them in anyway. This free's up the G530 for
AWOS and UNICOM since I look up those frequencies from the database rather
than twisting them in.
Don't have any flip\flop buttons on the yoke, so can't comment on that
point.
Hope that helps.
Jim
-----Original message-----
Sent: Sun, Aug 7, 2011 18:39:33 GMT+00:00
Subject: Primary Comm Radio
Hi
Cheers
Les
#40643
Strasnuts
PostPosted: Sun Aug 07, 2011 10:55 am    Post subject: Primary Comm Radio Reply with quote
Les,
I am with Robin,
I have the 430W and the SL30. I have my Com1 Nav1 on the 430W.
Sean
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
PostPosted: Sun Aug 07, 2011 11:07 am    Post subject: Primary Comm Radio Reply with quote
I do just the reverse. Comm 2 is always my WX comm. Here is why:
430W
Transmit power:
10 watts minimum; 16 watts minimum (GNS 430A)
SL30
Transmit power 8 watts (carrier power)
My G900X has dual 16 Watt comms. Nice to have J
My 8A with a 430/SL30 has 1 - 16 Watt Comm & 1 - 8 Watt Comm. Use the 16 for all your primary communication IMHO.
Robin
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of fehdxlbb(at)gmail.com (fehdxlbb(at)gmail.com)
Sent: Sunday, August 07, 2011 11:50 AM
Subject: Re: Primary Comm Radio
As a datapoint, I use the SL30 for ATC since I don't know the frequencies ahead of time and have to twist them in anyway.  This free's up the G530 for AWOS and UNICOM since I look up those frequencies from the database rather than twisting them in.
Don't have any  flip\flop buttons on the yoke, so can't comment on that point.
Hope that helps.
Jim
From: Les Kearney <kearney(at)shaw.ca (kearney(at)shaw.ca)>
To:
rv10-list(at)matronics.com (rv10-list(at)matronics.com)
Sent:
Subject:
Primary Comm Radio
Hi
Cheers
Les
#40643
[/b][/quote] = the many List utilities such as List Un/Subscription,[/b][/quote][/b][/quote] //www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List[/b][/quote] =================[/b][/b][/quote] -> http://forums.matronics.com[/b][/quote] =================[/b][/b][/quote]                              -Matt Dralle, List Admin.[/b]http://www.matronics.com/contribution[/quote] =======================[/b] [/quote]
~?ރg(ӍӇqzn
rene(at)felker.com
PostPosted: Sun Aug 07, 2011 11:16 am    Post subject: Primary Comm Radio Reply with quote
I guess just to be different……I have it the other way around. I use the SL30 for all my primary comm and the 430 for my primary navigation. I have the sl30 hooked to my Grand Rapids and I can push freqs from the GRT system to the sl30. I have a freq flip/flop on my sick hooked to my SL30…….
I think it may depend more on how you plan on integrating and using your EFIS, etc. I really thought I was going to use my EFIS more to control the radios than I really have. I think my old age is catching up with me and I just go to looking up freqs and putting them in the radio instead of using the efis to look them up and push them over.
Rene' Felker
N423CF
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Les Kearney
Sent: Sunday, August 07, 2011 12:31 PM
Hi
Cheers
Les
#40643
dmaib(at)mac.com
PostPosted: Sun Aug 07, 2011 12:20 pm    Post subject: Primary Comm Radio Reply with quote
I have the SL-30 functioning as COMM 1 and the 430W as COMM 2. I do push VOR freqs from my Chelton into the SL-30 sometimes, but that is not a major factor for me. I can't tell you any particular reason I made that decision back during the build, but I am glad I did. (It is entirely possible that Stein recommended that setup, I just don't remember) The SL-30 is a really great radio IMHO. The ability to monitor two comm freqs as well as two VORs off of one radio is awesome. My VOR needles on the Chelton point to the primary VOR as well as the secondary or standby VOR in the SL-30. I have the flip-flop switch on my stick set up for COMM 1. My stack is set up with the SL-30 above the 430W, so maybe that is why I made the decision. Bottom line, it is probably not too important unless your EFIS setup makes one radio or the other preferable.
David Maib
40559
Flying
On Aug 7, 2011, at 2:30 PM, Les Kearney wrote:
Hi
Cheers
Les
#40643
coop85(at)verizon.net
PostPosted: Sun Aug 07, 2011 12:22 pm    Post subject: Primary Comm Radio Reply with quote
I have my 480 set up as comm 1 and the SL 30 as radio 2. Both excellent radios, I end up using the 480 as primary mostly because it is hooked to the better of my 2 antennas. I used the Bob Archer foil for comm 2 and while effective it's not quite as good so I use it mostly for ATIS and local traffic comm.
Marcus
Sent from my iPad
On Aug 7, 2011, at 2:30 PM, "Les Kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
Hi
Cheers
Les
#40643
Kellym
PostPosted: Sun Aug 07, 2011 1:12 pm    Post subject: Primary Comm Radio Reply with quote
Not sure why you bought the optional extra power on the 430, but for the
majority of folks with a standard 430 the power output with it and the
SL30 will be identical at 8 watts.
430W
Transmit power:
SL30
Robin
Kelly McMullen
KCHD
Bob Turner
PostPosted: Sun Aug 07, 2011 1:30 pm    Post subject: Re: Primary Comm Radio Reply with quote
I have sl-30 #1, G-420 #2. Not sure there is any real reason to prefer one over the other, although a minor point: G-420 has an inhibit input so the receiver is off when transmitting on the SL-30, to prevent any feed thru if it happens to be selected on the audio panel. I don't think the SL-30 has such an input (?).
Bob Turner
RV-10 QB
PostPosted: Sun Aug 07, 2011 1:53 pm    Post subject: Primary Comm Radio Reply with quote
The difference in receive & transmit between the 430W & SL30 is noticeable
30-80 miles out.
Robin
Kellym
PostPosted: Sun Aug 07, 2011 2:36 pm    Post subject: Primary Comm Radio Reply with quote
Of course, when you are pushing 16 watts of a 430A vs 10 watts of a
standard 430W. 8 watts of the sL30 vs 10 watts of standard 430 is not a
meaningful power difference. Any detectable difference would have to be
explained in antenna differences.
On 8/7/2011 2:50 PM, Robin Marks wrote:
The difference in receive& transmit between the 430W& SL30 is noticeable
30-80 miles out.
Robin
Kelly McMullen
KCHD
rbibb
PostPosted: Sun Aug 07, 2011 2:37 pm    Post subject: Primary Comm Radio Reply with quote
I believe any comm. radio would have an inhibit input line on it lest the
overwhelming power from a transmit antenna just a few feet away would
overwhelm the input of the second radio if not damaging it.
Richard Bibb
RV-10 very slo but gaining momentum build
amekler
PostPosted: Sun Aug 07, 2011 4:47 pm    Post subject: Primary Comm Radio Reply with quote
I'd go with what radio sounds better as my primary.
My 2 cents.
alan
dmaib(at)mac.com
PostPosted: Sun Aug 07, 2011 5:16 pm    Post subject: Primary Comm Radio Reply with quote
There may be a power difference between the radios, but at 2 1/2
years and 400 hours, I have not been aware of any difference between
the two. If anything, the SL-30 seems to be the stronger of the two,
but not significantly. Perhaps that could be antenna issues on my
airplane? At any rate, 400 hours with lots of IFR and no comm issues
at all using the SL-30 as primary. I feel like the radios that Garmin
bought from UPS (SL-30, 480, and GTX-330?) are superior. No
scientific reasons, just my feelings.
David Maib
40559
Flying
noticeable
30-80 miles out.
Robin
Tim Olson
PostPosted: Sun Aug 07, 2011 8:08 pm    Post subject: Primary Comm Radio Reply with quote
Mine is just like David's....the SL-30 is Nav1/Com1, and the
GNS480 is Nav2/Com2. I think it does make sense to plan it
partly around your EFIS. The SL-30 is about the easiest
to integrate for many people, and in David's and my case,
you can use the standby NAV to effectively have it draw
TWO NAV radio needles on the EFIS....so if your other
Nav/Com/GPS has one, it's like having 3 in the plane. The
SL-30 is the perfect fit for us Chelton users, because it
allows our EFIS to populate the frequencies for both ILS/Nav
and COM, right from the Chelton Database. It's a great
radio and even manually entering freqs it's what we use
for our primary radio. The ability to monitor a 2nd comm
freq is awesome. I can do the same on the GNS480, but I
do it all the time on the SL-30. Even flying to OSH, I was
talking to the guys in my flight on ACTV, and listening
to Fisk on STBY. Since my GNS480 has the same ability,
being an apollo product, it's like having 4 COM's and 4
NAV's in the plane.
Then, as others have said, I tend to do all my radio
work on the SL-30, and on the GNS480 that leaves me free
to tune in ATIS, call flightwatch work with FSS, or
whatever, and I'm not punching buttons on it all the
time. I can also use the 480 to pull up NRST VOR,
NRST Airport, and all the other good stuff since it has
an internal database.
Regarding transmit power, I don't even know off hand
what the transmit powers are anymore of my 2 radios,
but in 750+ hours of flying, both of the radios have
been flawless with belly mounted COM antennas. Ground,
Tower, ATC, and everyone else, has always had no
trouble talking to me, and I've had the airplane in
so many places that it's pretty much proven itself.
Tim Olson - RV-10 N104CD
David Maib
40559
Flying
> Hi
> Cheers
> Les
> #40643
> href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
> href="http://forums.matronics.com">http://forums.matronics.com
> href="http://www.matronics.com/contribution">http://www.matronics.com/contribution
kearney
PostPosted: Sun Aug 07, 2011 8:51 pm    Post subject: Primary Comm Radio Reply with quote
Hi
Thank you to all that expressed an opinion on this thorny question. It
sounds like a split deciusion from those who are flying. Perhaps I need to
break out the magic eight ball...
Cheers
Les
Tim Olson
PostPosted: Mon Aug 08, 2011 4:06 am    Post subject: Primary Comm Radio Reply with quote
Or more appropriately, break out the magic manuals and learn
about the EFIS system you choose, and the rest of your stack,
to learn which plan makes sense for YOUR plane, and YOUR
avionics.
On 8/7/2011 11:48 PM, Les Kearney wrote:
Hi
Cheers
Les
kearney
PostPosted: Mon Aug 08, 2011 6:42 am    Post subject: Primary Comm Radio Reply with quote
I am already doing that. I have a TON of reading to go through!
Cheers
Les
johngoodman
PostPosted: Tue Aug 09, 2011 1:18 pm    Post subject: Re: Primary Comm Radio Reply with quote
Just a quick comment - I have a 430W and an SL-40. Aerotronics put together the panel and they set up the comm flip flop on the stick to change the PS9000EX, not the radios. I hadn't thought about it until now, but if you're listening to two different frequencies, those are most likely the ones you want to transmit on.
John
Goto page 1, 2  Next
Page 1 of 2
