SV: VMax - KIS TR-1
hans-chr.erstad(at)c2i.ne
PostPosted: Thu Aug 11, 2011 1:51 pm    Post subject: SV: VMax - KIS TR-1 Reply with quote
John
I have an IO-240 A in my TR-1 with a Prince P-Tip 62x68. Full throttle give 2800 RPM and around 155 kts. 2500 RPM (7.5 psi fuel pressure that according to engine manual should be 70%) give 135-140 kts.
Hans Christian
Fra: owner-kis-list-server(at)matronics.com [mailto:owner-kis-list-server(at)matronics.com] P� vegne av JOHN JACKSON
Sendt: 11. august 2011 16:29
Til: kis-list(at)matronics.com
Emne: VMax - KIS TR-1
Gentlemen
I have a 2-place KIS TR-1 G-BZDR which currently has an IO-240 A1B fitted (125HP) spinning an MT Variable pitch 3-blade prop. The prop has been sent for overhaul and the estimate is too expensive for me. Therefore, I'm looking at downgrading to a fixed-pitch 2-blade wooden prop.
The manufacturer will optimise the prop design to suit my aircraft but needs some information which I don't have and wondered if you guys could help. I used to cruise around at 145Kts at 75% power. However, the prop designer wants to know the theoretical max straight and level speed for the aircraft at full throttle. Anyone have any figures to hand for a TR-1 with an IO-240?
I'll be selling the old VP prop if anyone is interested, it's got 360 hours since new but will need calendar overhaul.
John
href="http://www.matronics.com/Navigator?KIS-List">http://www.matronics.com/Navigator?KIS-List
John Jackson
PostPosted: Sat Aug 13, 2011 6:31 am    Post subject: SV: VMax - KIS TR-1 Reply with quote
Hans Christian
Thank you for the information. How long have you had the P-Tip prop? Have you experienced any problems with it? Have you got a wooden or carbon fibre prop?
John
DIV { MARGIN:0px;} John
Hans Christian
