teamgrumman(at)yahoo.com Guest
				 Posted: Mon Apr 16, 2012 10:11 am    Post subject: Notes on installing the Electroair Ignition system |
				First, I've always been a fan of electronic ignitions.  I looked into DIS a LOOOOONG time ago (Remember the '87 Buick Grand National?).
 So, when the time came to install, not one, but two, DIS systems, I was anxious to get started.
 Especially since one was a Real Tiger and the other was an AG Tiger.
 How long does it take:  Realistically, 16-20 hours.
 Why?  you ask?  I spent at least 4 to 6 hours on each plane just looking for a place to put all the pieces and trial fitting everything before I drilled any holes.
 1) Magneto Timing  Housing:  It replaces the right mag.  That part was pretty easy.
      However . . . The lead (wire connection) on the MTH is about a mile long (18 inches?) and I needed to find a place
      somewhere above the accumulation of oil and dirt to mount it.
      Then, of course, the wiring harness from the Controller is really long for a Grumman and I wanted it
      to be where someone could R&R the MTH if necessary.  So the connector had to be accessible.
            Note:  Best Case.  It would be a whole lot better to have the connector right on the MTH housing.
 [b]                     Worst Case
  |  | - The Matronics TeamGrumman-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?TeamGrumman-List |
