donaho1(at)verizon.net Guest
				 Posted: Thu Sep 01, 2011 6:54 am    Post subject: RotaxEngines-List Digest: 2 Msgs -  08/31/11 |
				Hi All, FYI, On Sept 7th. The EAA is having a webinar titled "All
 about oils". I just thought you may be interested. I have "attended"
 several of their webinars and have learned something each time. Lanny
 N598LF   At 10:04 AM 9/1/2011, you wrote:
 Roger,
 I will change back to one of the oils you recommend, and have used the
 motorcycle oils for all but the last 10 or so hours. In fact I believe
 I can hear the difference when starting the engine in the valve
 lifters.  But I wonder why the Mobil 7500 Clean semi synthetic is on
 Rotax's list if it does not have the correct additives to protect
 gears and flat lifters?
 I was using MX4T synthetic, but on a couple of cross country trips I
 could only get 100LL, and when I changed the oil shortly after, I
 could really see the gunk building up in the oil tank.  So I wanted to
 go to a semi-synthetic for that occasional time when 100LL is
 unavoidable.  Thanks,
 Jack
  > I've been using Mobil 1 7500 Clean.  It is readily available and on
  > the Rotax list of approved oils, and has the SL rating.  I assume
  > therefore that it has the right additive package.  Perhaps a rash
  > assumption!!!   Any comment?  Anyone else using this in a 912 UL?  I
  > use it in my aging Toyota Rav4 as well, and it still gets good fuel
  > economy at 170000 miles.  Nice to have the same oil for both.
  > Jack Kuehn
  > ________________________________  Message
  2  _____________________________________
  > Time: 11:38:18 AM PST US
  > Subject: Re: 912 oil
  > From: "Roger Lee" <ssadiver1(at)yahoo.com>
  > Hi Jack,
  > That Mobile 7500 Clean is a car oil and a last ditch
  recommendation if no other
  > is available. You have zero protection for your flat tappet
  lifter and gearbox.
  > There are no additives in this oil to help your engine. It is not
  a motorcycle
  > oil. Get rid of it and use one of these.
  > You have to use a semi synthetic for 100LL and you can use a full
  or semi synthetic
  > for 91 Oct unleaded.
  > These are all motorcycle oils.
  > Amsoil 10-40 or 20-50
  > Mobile 1 Racing 4T  10-40
  > Mobile 1 V-Twin
  > Aero Shell Sport Plus 4  semi  10-40
  > Golden Spectro 4   semi   10-40 or 20-50
  > Roger Lee
  > Tucson, Az.
  > Light Sport Repairman - Maintenance Rated
  > Rotax Repair Center - Heavy Maint. Rated
  > Home 520-574-1080  TRY HOME FIRST
  > Cell 520-349-7056
  |  | - The Matronics RotaxEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
