sarangan(at)udayton.edu Guest
Posted: Mon Sep 05, 2011 4:56 pm Post subject: corrosion on pitch torque tube |
I found my steel pitch tube (the one that goes on the back of the
cockpit module) has surface corrosion, mostly near the tab weld
joints. I suspect the plating must have been stripped off during the
welding process. The tube is dark brown, almost black, and I am unsure
if that means it is zinc plated or something else. I was thinking of
scrubbing the whole tube in alumiprep (dilute phosphoric acid) and
then painting with zinc chromate primer. I don't have any experience
working with this type of steel, and what effect if any phosphoric
acid has, so I would appreciate any input on this.
Posted: Mon Sep 05, 2011 6:21 pm Post subject: corrosion on pitch torque tube |
Andrew Sarangan wrote:
| Quote: | I found my steel pitch tube (the one that goes on the back of the
Andrew,
In my case, all my steel components (Kit #A194) appeared to be raw w/
a blackened finish...there were a few small areas of surface rust
which I removed w/ fine wetsand paper and solvent...I had a shop
powder coat the steel pieces and I sprayed zinc chromate primer on all
aluminum pieces except for the landing gear.
Fred
jan_de_jong(at)casema.nl Guest
Posted: Tue Sep 06, 2011 12:03 am Post subject: corrosion on pitch torque tube |
I use KBS 3-step system on all steel parts. Adheres amazingly.
Jan de Jong
g-iani(at)ntlworld.com Guest
Posted: Tue Sep 06, 2011 12:58 am Post subject: corrosion on pitch torque tube |
Andrew
If your CS10 is dark brown/black then it will not have been plated. The
steel components were shipped with this oil finish up to about 2002/3 when
Europa started plating them (the gold finish).
The oil finish will prevent some corrosion but a better solution is to clean
and paint the component. As your end caps are already in place try and
ensure you do not get any acid cleaner inside the tube. This will corrode
the MS21047 anchor nut and could make future removal difficult. Almost any
paint system designed for steel will do.
Ian Rickard G-IANI XS Trigear, 350hours
Europa Club Mods Specialist
e-mail g-iani(at)ntlworld.com
asarangan(at)gmail.com Guest
Posted: Wed Sep 07, 2011 8:03 am Post subject: corrosion on pitch torque tube |
I just received the mod 75 kit (autopilot altitude hold) which
included a new CS10 tube. This tube is indeed different from the one I
got back in 2000. It is a golden color, and the weld joint has been
spray coated with what looks like zinc chromate paint.
On Tue, Sep 6, 2011 at 4:55 AM, G-IANI <g-iani(at)ntlworld.com> wrote:
Andrew
