		tebenkof(at)aol.com Guest
				 Posted: Fri Sep 09, 2011 2:26 pm    Post subject: Exhaust Leak?? |
				Hello,
 I have not been on the list for a few years.  I completed my 701 in
 early 2006.  I am back because this list, at least in those days, had
 enough expertise to answer almost anything. Sometimes even with
 multiple contradictory answers.  So, hoping you experts are still out
 there:  How do you confirm and locate an exhaust leak you suspect is
 there only because you hear it.  And is that likely to be my problem.
 After a grass landing on a moderately rough strip there was a buzzing,
 or perhaps rapid light clapping sound, heard when taxing in.  It
 correlated with RPM.  There were no instrument indications, such as
 egt, of any engine problem.  Is it likely exhaust, or is there
 something else I should be thinking about?
 thanks for any help,
 Jim in Tualatin
  |  | - The Matronics Zenith701801-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		John Bolding
				 Posted: Sat Sep 10, 2011 3:18 am    Post subject: Exhaust Leak?? |
				Make a plug on the end of the exhaust pipe and introduce 20# of compressed
 air, should be able to locate it, will have to turn the prop to bring each
 cyl to TDC to isolate each exhaust circuit. Remove plug wires
 John
		mksoucy(at)yahoo.com Guest
				 Posted: Sat Sep 10, 2011 3:29 am    Post subject: Exhaust Leak?? |
				I would also check your prop closely.
 Sent from my iPod
 On Sep 9, 2011, at 6:23 PM, tebenkof(at)aol.com wrote:
 Hello,
 I have not been on the list for a few years.  I completed my 701 in early 2006.  I am back because this list, at least in those days, had enough expertise to answer almost anything. Sometimes even with multiple contradictory answers.  So, hoping you experts are still out there:  How do you confirm and locate an exhaust leak you suspect is there only because you hear it.  And is that likely to be my problem.  After a grass landing on a moderately rough strip there was a buzzing, or perhaps rapid light clapping sound, heard when taxing in.  It correlated with RPM.  There were no instrument indications, such as egt, of any engine problem.  Is it likely exhaust, or is there something else I should be thinking about?
 Jim in Tualatin
