		| Author | Message |
		| cptimm(at)telus.net Guest
				|  Posted: Sat Sep 10, 2011 11:56 am    Post subject: Araldite 420 A |   |
				| Hi All,
 following my recent twisting of the tail-wheel spring-arm I had to remove  the same from the fuselage, which turned out to be a simple task. The Araldite  420 could be softened up in stages with a heat-gun and dug out with an old wood  chisel. I then pulled out the spring-arm after removing the inside bolt, which  was bent as well. Straightening out the twisted
 tail-spring required the use of a strong vise as well as a longish piece of  pipe, but was also fairly easy. I then proceeded to re-assemble everything ,  after proper sanding and cleaning the area, and finally used a very small amount  of Araldite 420 which I had kept in a small glass jar, with a bit of hardener in  a small bottle, mixed it well with some flox, and applied it
 around the spring where it passes through the hole .  Unfortunately,  either the Araldite, or the hardener ( more likely) seems to have expired , and  the glue has not cured and will have to be cleaned out again.
 Can anyone sell a small amount of Araldite and hardener to me, not more  than 50g is needed.
 I will, of course, buy a larger amount.
 Peter Timm,  C-GIET
		| Back to top |  |
		| duanefamly(at)aol.com Guest
				|  Posted: Sat Sep 10, 2011 5:49 pm    Post subject: Araldite 420 A |   |
				| Where are you located?
		| Back to top |  |
