Sticking Starter
jeffrey-j-paris(at)excite
PostPosted: Sat Sep 10, 2011 1:29 pm    Post subject: Sticking Starter Reply with quote
Jabba-Dudes,
Has anyone experienced having your starter motor not engage and whine on start-up? It's been happening as of late, I end up crawling out of the plane to turn the proppeller and my 3300 starts as normal. Any ideas or suggestion?
Thanks for your time and consideration.
Jeff Paris 2 Jab 3300 in the nest Zenith CH601XLB and a Europa Monowheel -still waiting for propeller
cffd(at)pgrb.com
PostPosted: Sun Sep 11, 2011 8:26 am    Post subject: Sticking Starter Reply with quote
I have an older starter. One time the starter spun up but the prop did not move. The gear on the starter motor shaft was just pressed on and became loose. I had a welder just touch the end of the shaft and gear. This weld has worked now for many hours.
Chuck D.
N701TX
Jab 2200
Has anyone experienced having your starter motor not engage and whine on start-up? =C2-It's been happening as of late, I end up crawling out of the plane to turn the proppeller and my 3300 starts as normal. =C2-Any ideas or
suggestion?
