herbgh(at)nctc.com Guest
Posted: Thu Sep 22, 2011 9:13 am Post subject: Geo metro stuff for sale |
guys
Buddy of mine went out of the airplane business...He has a 4 cyl
geo engine...1.3 liter single ohc... abt 80 hp.. He had it equipped
with a Simple Digital System fuel injection and ignition
computer...The SDS system includes all the parts to make the Geo
engine run....Fuel pump, Injector rail,Injectors, Ignition coil
packs...etc...Programming module...The engine and sds system was
running on his airplane..He also has a Belt Redrive from someone in
Kansas as I recall...labeled a Mini Merlin Conversion... All of this
stuff , save the engine, has less than 5 hours...the engine came
directly from a wreck...does not use oil .. miles unknown... also
several other engine parts...head, etc..
all yours for best offer....I recall that he had maybe 4500 bucks
in the whole kaboddle.... Herb
Posted: Thu Sep 22, 2011 5:24 pm Post subject: Geo metro stuff for sale |
The prop hub location may be a consideration. Is mini merlin still in business?
BB
On 22, Sep 2011, at 1:10 PM, Herb wrote:
guys
Buddy of mine went out of the airplane business...He has a 4 cyl geo engine...1.3 liter single ohc... abt 80 hp.. He had it equipped with a Simple Digital System fuel injection and ignition computer...The SDS system includes all the parts to make the Geo engine run....Fuel pump, Injector rail,Injectors, Ignition coil packs...etc...Programming module...The engine and sds system was running on his airplane..He also has a Belt Redrive from someone in Kansas as I recall...labeled a Mini Merlin Conversion... All of this stuff , save the engine, has less than 5 hours...the engine came directly from a wreck...does not use oil .. miles unknown... also several other engine parts...head, etc..
all yours for best offer....I recall that he had maybe 4500 bucks in the whole kaboddle.... Herb
Posted: Thu Sep 22, 2011 5:57 pm Post subject: Geo metro stuff for sale |
Bob
Mini Merlin went out of business.. as I recall... Not sure about
prop diameter...? Likely similar to a 912 ...? Might be a bit
more? Depending on engine mounting... Herb
At 08:21 PM 9/22/2011, you wrote:
in business?
BB
> guys
