pnicholson
Posted: Sat Sep 17, 2011 3:06 pm Post subject: Brake Line Purge valve |
Good afternoon,
after opening the "brake line purge valve" on my pre-fligh
inspection, the valve would not re-seat and continued to leak air.
This created issues, as after taxing, I had little pressure left to
get the gear up (the gear and main pressure came up fairly quickly in
flight). Afterwards, we disconnected the airlines and removed the
blue bottle. Cleaned/flushed it all up, checked it with air, and it
still leaked. On dis-assembly, it appears that the valve seat and
mating parts are corroded. Air also appears to be leaking, albeit
less, out the valve opener (dial). So, are there replacement parts or
mods available?
Phil Nicholson
CJ6A
C-FEPN
Posted: Sun Sep 18, 2011 7:55 am Post subject: Brake Line Purge valve |
Contact me off list. We have a stainless steel mod to correct this problem. You can use this mod ONLY if the valve in your QL-17 snot valve is the type which is NOT welded to the bottle. Give me a call 509-826-4610.
Best
Doug On Sep 17, 2011 4:08 PM, "Philip Nicholson" <pednicholson(at)gmail.com (pednicholson(at)gmail.com)> wrote:> --> Yak-List message posted by: Philip Nicholson <pednicholson(at)gmail.com (pednicholson(at)gmail.com)>
| Quote: | Good afternoon,
| Quote: | flight). Afterwards, we disconnected the airlines and removed the
| Quote: | mating parts are corroded. Air also appears to be leaking, albeit
> mods available?
Phil Nicholsre, and much much more:
MATRONICS WEB FORUMS -
nics.com/contribution">http://www.matronics.com/contribution
