Two wires in one d-sub pin
Barry
PostPosted: Sun Sep 18, 2011 5:35 am    Post subject: Two wires in one d-sub pin Reply with quote
Is it ok to crimp two wires in one d-sub pin, as long as the two wires fit into the socket ok.
PostPosted: Sun Sep 18, 2011 5:59 am    Post subject: Two wires in one d-sub pin Reply with quote
Sure . . . but those must be very tiny wires.
What's the situation?
Barry
PostPosted: Sun Sep 18, 2011 6:08 am    Post subject: Re: Two wires in one d-sub pin Reply with quote
I am installing an ADSB box and I need to daisy chain three ground pins with #24 wire. Two #24 wires fit into my pins ok, so instead of splices I wanted to use the pins as the splice. Thanks much Barry
rleffler
PostPosted: Sun Sep 18, 2011 8:41 am    Post subject: Two wires in one d-sub pin Reply with quote
Another solution would be to use a solder sleeve. They come in a variety of sizes. You can get them from SteinAir, ACS, and a variety of other places.
 Filesize:  3.64 KB
 Viewed:  5839 Time(s)
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
PostPosted: Mon Sep 19, 2011 4:46 pm    Post subject: Two wires in one d-sub pin Reply with quote
[img]cid:7.1.0.9.0.20110918123209.044e0820(at)aeroelectric.com.1[/img]
Agreed. In fact it's preferable. Here's another
approach.
[img]cid:7.1.0.9.0.20110918123209.044e0820(at)aeroelectric.com.2[/img]
This technique is pretty much standard practice
in the TC aircraft industry. See:
http://www.aeroelectric.com/articles/pigtail/pigtail.html
 Filesize:  3.64 KB
 Viewed:  5808 Time(s)
 Filesize:  187.64 KB
