richard.goode(at)russiana Guest
Posted: Tue Oct 04, 2011 7:30 am Post subject: Gearbox "window" |
To set the record straight:
<![if !supportLists]>Ø <![endif]>The idea of the “window” was not to be able to inspect the gearbox in use, but was developed by Sergio Dallan in Italy as part of his oil shut-off system.
<![if !supportLists]>Ø <![endif]>So there was a valve on the oil supply preventing oil coming down to the engine, controlled through a small door in the cowling, with a safety back-up in the form of a “barbers pole” and a light in the cockpit.
<![if !supportLists]>Ø <![endif]>Then, in order to stop any oil that might be in the crank shaft draining down to the cylinders, there was a white mark in the gearbox, visible through the “window” and when the mark lined up, then the crank shaft was in its highest position, and so oil would not drain down into it and then into the cylinders.
<![if !supportLists]>Ø <![endif]>Sergio made a few, and indeed we fitted them to several Sukhois. Generally worked well.
<![if !supportLists]>Ø <![endif]>As I recollect it was simply a thick Perspex disc, with a metal reinforcement around the rim, using the same three bolt holes as the existing metal cover.
<![if !supportLists]>Ø <![endif]>In passing the existence of the cover is an easy way to identify a Series 2 engine.
Richard Goode
Richard Goode Aerobatics
Rhodds Farm
Lyonshall
Herefordshire
HR5 3LW
United Kingdom
Tel: +44 (0) 1544 340120
Fax: +44 (0) 1544 340129
www.russianaeros.com
Posted: Tue Oct 04, 2011 7:51 am Post subject: Gearbox "window" |
Thanks for clearing things up Richard.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (cell)
Skype: Yakguy1
www.yak-52.com
On 10/4/2011 10:26 AM, Richard Goode wrote:
ØThe idea of the “window” was not to be able to inspect the gearbox in
shut-off system.
ØSo there was a valve on the oil supply preventing oil coming down to
cockpit.
ØThen, in order to stop any oil that might be in the crank shaft
ØSergio made a few, and indeed we fitted them to several Sukhois.
ØAs I recollect it was simply a thick Perspex disc, with a metal
ØIn passing the existence of the cover is an easy way to identify a
Series 2 engine.
Richard Goode
Rhodds Farm
Lyonshall
Herefordshire
HR5 3LW
United Kingdom
www.russianaeros.com <http://www.russianaeros.com>
