dhall(at)donka.net Guest
Posted: Sun May 21, 2006 8:33 pm Post subject: 5 point harness |
I think Van's only pushes 4pt safety belts, so if I want 5pt system, when I
should be worrying about installing the brackets for 5pt? I'm working on
fuse bulkheads now...
| | - The Matronics RV7-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV7-List |
lhelming(at)sigecom.net Guest
Posted: Mon May 22, 2006 3:50 am Post subject: 5 point harness |
Yes, the 5-point bracket is much easier to install before you get everything
else finished. Wiring comes to mind here. I almost did not install the
5-point bracket due to my wiring had to be moved to make room. Also,
standing almost on your head while putting it in with the cockpit already
done makes you want to go on diet. And age could be a factor too. At 63 I
am not as flexible as once was. But I got it done just the same. My friend
installed his early on and it was a much simpler task.
Larry in Indiana
Posted: Mon May 22, 2006 5:51 am Post subject: 5 point harness |
Just my experience, I too use the Hooker harness with my 5-point and did
just a bit of filing on the harness to get an easier slip in fit. I did not
have to rework anything with the Van's bracket installation. But, it is a
tight fit and I guess that is better than one that is loose. I installed
mine about 2 years ago and maybe something has changed with the bracket or
the belt since then. Having the belts beforehand could help ensure a
trouble free install. You just need pick the color and come up with the
money sooner.
Indiana Larry
walter(at)tondu.com Guest
Posted: Mon May 22, 2006 6:26 am Post subject: 5 point harness |
If you go with the Hooker Harness, don't just blindly follow Vans
plans. I believe that Vans calls for an AN5 bolt but the HH takes
an AN4 sized bolt. If memory works.
And the earlier you can get this in, the better.
Walter Tondu
http://www.rv7-a.com
Flying!
frank.hinde(at)hp.com Guest
Posted: Mon May 22, 2006 6:43 am Post subject: 5 point harness |
Hey Walter....After I had all my cushions upholstered I realised that
you need to cut a hole in the seat cushion for the ball crusher strap to
pass through...I.e it does not go thru the stick slot, you need to cut
another hole is that correct?
Frank
RV7a...So close to painting I can smell the cyanide!
Posted: Mon May 22, 2006 7:09 am Post subject: 5 point harness |
That's correct. A slot needs to be cut in the seat bottom for the
ball crusher.
Walter Tondu
Flying!
lifeofreiley2003(at)yahoo Guest
Posted: Mon May 22, 2006 2:40 pm Post subject: 5 point harness |
Can someone scan a copy of Van's Crotch Strap Instructions for an RV7A (pdf) to me to review?
Darrell
"Joseph F. Giallo, II" <jgiallo(at)mindspring.com> wrote:
| Quote: | Don,
Your life will be a lot easier if you have the actual belts in hand when
fitting the brackets. I found that following Van's instructions with
their crotch strap kit did not properly fit the Hooker harnesses I
purchased. Re-working this installation is a bear and can be avoided by
having everything at the start......
Joe
Don Hall wrote:
| Quote: | --> RV7-List message posted by: "Don Hall"
begin:vcard
fn:Joseph Giallo
n:Giallo;Joseph
org:North Carolina State University and the University of North Carolina at Chapel Hill;Joint Department of Biomedical Engineering
email;internet:jgiallo(at)mindspring.com
title:Graduate Research Assistant
tel;cell:919-608-1975
note;quoted-printable:Regards,=0A
=0A
Joe Giallo=0A
Graduate Research Assistant=0A
Joint Department of Biomedical Engineering at North Carolina State Univer
sity and the University of North Carolina at Chapel Hill=0A
mobile: 919-608-1975=0A
version:2.1
end:vcard
New Yahoo! Messenger with Voice. [url=http://us.rd.yahoo.com/mail_us/taglines/postman5/*http://us.rd.yahoo.com/evt=39666/*http://messenger.yahoo.com]Call regular phones from your PC[/url] and save big.
davcor(at)comcast.net Guest
Posted: Mon May 22, 2006 3:15 pm Post subject: 5 point harness |
Hi, this is very timely, please copy me too as I've just about finished the rear (706-712) and start on the center section when I get home Friday.
Dave Cordner
N898DC - (rsvd)
Fuse
| Quote: | -------------- Original message --------------
From: Darrell Reiley <lifeofreiley2003(at)yahoo.com>
Darrell
| Quote: | Don,
Joe
begin:vcard
fn:Joseph Giallo
n:Giallo;Joseph
org:North Car olina State University and the University of North Carolina at Chapel Hill;Joint Department of Biomedical Engineering
=0A
Joe Giallo=0A
version:2.1
end:vcard
New Yahoo! Messenger with Voice. [url=http://us.rd.yahoo.com/mail_us/taglines/postman5/*http://us.rd.yahoo.com/evt=39666/*http://messenger.yahoo.com]Call regular phones from your PC[/url] and save big. |
Posted: Wed May 24, 2006 10:20 am Post subject: 5 point harness |
Dave,
Due to no replies regarding an Instruction Sheet from Van's on the Crotch Strap installation I'm starting to think there are no such instructions offered from Van's.
If I come up with something it will be forwarded to you.
Darrell
davcor(at)comcast.net wrote:
| Quote: | Hi, this is very timely, please copy me too as I've just about finished the rear (706-712) and start on the center section when I get home Friday.
Dave Cordner
N898DC - (rsvd)
Fuse
Darrell
| Quote: | Don,
Joe
begin:vcard
fn:Joseph Giallo
n:Giallo;Joseph
=0A
Joe Giallo=0A
version:2.1
end:vcard
retasker(at)optonline.net Guest
Posted: Wed May 24, 2006 12:24 pm Post subject: 5 point harness |
I can do this for the RV9A installation. I didn't respond before
because I assumed that someone with a 7A would. I suspect the
instructions are the same, but I can make no guarantees.
If you want the 9A instructions let me know.
Dick Tasker
Darrell Reiley wrote:
| Quote: | Dave,
Darrell
get home Friday.
Dave Cordner
N898DC - (rsvd)
Fuse
Darrell
*/"Joseph F. Giallo, II" <jgiallo(at)mindspring.com>/* wrote:
Don,
belts in hand when
instructions with
harnesses I
be avoided by
Joe
5pt system, when I
I'm working on
begin:vcard
fn:Joseph Giallo
n:Giallo;Joseph
=0A
Joe Giallo=0A
version:2.1
end:vcard
New Yahoo! Messenger with Voice. Call regular phones from your
PC
<http://us.rd.yahoo.com/mail_us/taglines/postman5/*http://us.rd.yahoo.com/evt=39666/*http://messenger.yahoo.com>
and save big.
New Yahoo! Messenger with Voice. Call regular phones from your PC
and save big.
Posted: Wed May 24, 2006 1:03 pm Post subject: 5 point harness |
Thanks Dick...!
I would love to see the instructions... they should be the same.
Darrell
Richard Tasker <retasker(at)optonline.net> wrote:
[quote]--> RV7-List message posted by: Richard Tasker
Dick Tasker
[quote] Dave,
Darrell
get home Friday.
Dave Cordner
N898DC - (rsvd)
Fuse
Darrell
*/"Joseph F. Giallo, II" /* wrote:
Don,
belts in hand when
instructions with
harnesses I
be avoided by
Joe
5pt system, when I
I'm working on
begin:vcard
fn:Joseph Giallo
n:Giallo;Joseph
=0A
Joe Giallo=0A
version:2.1
end:vcard
PC
and save big.
New Yahoo! Ring'em or ping'em. Make [url=http://us.rd.yahoo.com/mail_us/taglines/postman11/*http://us.rd.yahoo.com/evt=39666/*http://voice.yahoo.com] PC-to-phone calls as low as 1¢/min[/url] with Yahoo! Messenger with Voice.
7A@ABI
Posted: Wed May 24, 2006 1:21 pm Post subject: 5 point harness |
Darrell,
I bet Van’s would email the .pdf file of the instructions if you request it via email.
Sam
_________________ Sam Evans
RV7-A
O-360 C/S |
Posted: Wed May 24, 2006 2:11 pm Post subject: 5 point harness |
Yes they will... in a week or two. They are swamped!
Darrell
sjevans <sjevans(at)cox.net> wrote:
[quote] Darrell,
Sam
