Headsets Redux-was "Warning - New Bose Line Power Cable
Speedy11(at)aol.com
PostPosted: Wed Oct 05, 2011 10:36 am    Post subject: Headsets Redux-was "Warning - New Bose Line Power Cable Reply with quote
John,
I concur with all of your comments.
Stan Sutterfield
Long time Bose user
In a message dated 10/5/2011 3:01:15 A.M. Eastern Daylight Time, aeroelectric-list(at)matronics.com writes:
Bought 2 pairs of Beyerdynamic HS 800 headsets by 8/31/11 to make it through the
$200/set trade-in window they offered. Got the BD's and they are a very nice
German-built headset. In the back of my mind, I figured that I would go through
the motions of due diligence comparison and probably buy Bose, then return
the BD HS 800's in the 30 day trial period.
I went to a Bose store to compare headsets with the Bose display simulating cockpit
noise in a single engine piston plane. First, the Bose earcups were not as
generous as the BD cups and were more difficult to get a good seal. I did manage
to get them on correctly. I felt that the Bose head band was awkward in using
a multi-segment, pivoting mechanism and it didn't feel secure on my noggin,
and caused doubt about it's ability to stay on if encountering heavy turbulence
or rapid head movement. The BD uses a traditional spring steel type band,
with slightly more clamp pressure than Bose and felt very secure on my head.
Inspite of Bose specs claiming lighter weight by an ounce, the BD felt lighter
when wearing it. The BD earcup seals also seem to seal around my wire frame sunglasses
more effectively than the Bose.
The actual noise reduction comparison was interesting. When switching back and
forth between brands with the simulated noise on, the Bose was obviously quieter...initially.
After doing this a few times, I noticed that when the BD's were
on for about 3-4 seconds, the noise attenuation would increase from the initial
covering of my ears. BD calls their system Digital Adaptive NR and I attribute
the attenuation lag to that "adaptive" feature. Once internal earcup sensors
adapted to the particular frequencies being sensed and subsequently reduced
the sound level, I found the sound of the BD's more natural than the Bose. The
Bose had less sound, but I found that I prefer a little aural feedback. The
sound level difference between the two is pretty minor, but detectable and in
favor of Bose.
To explain what I mean by aural feedback, I can give you the analog of my choice
in cars. When I was deciding brand and model the last time I bought one, I chose
one that gave me more road feel at the expense of minor cabin noise. I found
that driving a car that isolated me from the road, both in feel through the
steering wheel and tomb-like quiet in the cabin, made me slightly nauseous,
and imparted the feeling of a slight lack of control over the car.
Moving on, the BD electrical cording is high quality and about 6' long. The audio
box is about the same size as Bose but much simpler and BD provides the various
adapters for music players and cellphones to plug right in to the audio box.
I confess that I don't use a cell phone much and I hardly think of an aircraft
cockpit as a concert hall, so having Bluetooth is not much of a selling point
for me.
After my brief comparison, I'd opt for the BD's even without the $200/headset trade-in
for my 24 year old DC's. With it, it was a no-brainer.
Thanks to Gerry Van Dyk for turning me on to the BD's
John
