WRShank(at)spoerrprecast. Guest
Posted: Tue Oct 18, 2011 7:25 am Post subject: EI clock chime |
Bob and all, I have a EIectronics Intermational clock that will ground a line when it reaches 0:00. I would like to hook a chime to the line and run it to my audio panel. Other than EI’s tone generator, is there an easy way to do this?
Bill Shank RV6
Posted: Tue Oct 18, 2011 7:57 am Post subject: EI clock chime |
At 10:36 AM 10/18/2011, you wrote:
| Quote: | Bob and all, I have a EIectronics Intermational clock that will ground a line when it reaches 0:00. I would like to hook a chime to the line and run it to my audio panel. Other than EI’s tone generator, is there an easy way to do this?
"Easy" is difficult to quantify. How handy
are you with the soldering iron? In the
audio systems chapter of the 'Connection
I illustrated a variety of tone generators
that could be adapted to various functions
in the well appointed airplane.
The SIMPLEST solution is an 8-pin PIC
uController with some pretty rudimentary
software. This approach could do about
any sort of 'noise' short of a string
quartet. The schematics I illustrated
are less versatile but can be fabricated
from rudimentary parts.
What would you like to tone to sound like?
Bob . . . [quote][b]
james(at)etravel.org Guest
Posted: Tue Oct 18, 2011 8:48 am Post subject: EI clock chime |
Hi Bill,Â
I used this line from the EI clock, but instead take it to a light on the annunciator panel (design as supplied by another lister here). Â It lights up a green 1 x 1/2" or so LED array. Â
James
On 18 October 2011 16:36, Bill Shank <WRShank(at)spoerrprecast.com (WRShank(at)spoerrprecast.com)> wrote:
Â
Â
Bill Shank RV6
ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
tp://forums.matronics.com
Posted: Tue Oct 18, 2011 8:58 am Post subject: EI clock chime |
Bob, I’m thinking a ding dong sound, nothing that would startle you. I will take a look at the Connection tonight. I have no experience soldering boards but would like to learn.
Bill Shank
Sent: Tuesday, October 18, 2011 11:54 AM
Subject: Re: EI clock chime
Bob and all, I have a EIectronics Intermational clock that will ground a line when it reaches 0:00. I would like to hook a chime to the line and run it to my audio panel. Other than EIs tone generator, is there an easy way to do this?
Bob . . . | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 0123456789
Posted: Tue Oct 18, 2011 9:10 am Post subject: EI clock chime |
Hi Bill,Â
James
Â
Â
Bill Shank RV6
Joined: 28 Mar 2008 Posts: 1951 Location: Riley TWP Michigan
Posted: Thu Oct 20, 2011 6:24 pm Post subject: Re: EI clock chime |
| Quote: | | Bob and all, I have a EIectronics Intermational clock that will ground a line when it reaches 0:00. I would like to hook a chime to the line and run it to my audio panel. Other than EI’s tone generator, is there an easy way to do this? |
Here is a circuit by Forrest M. Mims, III that makes a tone when the input goes low.
https://lh4.googleusercontent.com/-USAZBtVHo64/TqDWOf5qJcI/AAAAAAAAAcU/fBvHVErh8Bs/s439/GatedToneSource.gif
Joe Gores
_________________ Joe Gores |
peter(at)sportingaero.com Guest
Posted: Fri Oct 21, 2011 8:32 am Post subject: EI clock chime |
Joe, that's a circuit I might be interested in for another application,
but I don't see a power line? Can the tone be automatically shut off
after (say) 2 seconds?
Peter
Mike Welch
Posted: Fri Oct 21, 2011 8:52 am Post subject: EI clock chime |
Peter,
I'm not Joe, he's much smarter than I am, but the "power line" you're looking for is
inside the drawing labelled " ENABLE (Low= Tone) "
Mike W
Posted: Fri Oct 21, 2011 9:16 am Post subject: EI clock chime |
Vcc is the supply line. Â
On 21 October 2011 17:29, Peter Pengilly <peter(at)sportingaero.com (peter(at)sportingaero.com)> wrote:
[quote]--> AeroElectric-List message posted by: Peter Pengilly <peter(at)sportingaero.com (peter(at)sportingaero.com)>
Joe, that's a circuit I might be interested in for another application, but I don't see a power line? Can the tone be automatically shut off after (say) 2 seconds?
Peter
ric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
MS -
e -
Posted: Fri Oct 21, 2011 10:42 am Post subject: Re: EI clock chime |
I am not really smarter than Mike Welch. But I am better looking.
The 74LS368 is powered by 5vdc connected to pin 16 (labeled Vcc). As for automatically shutting off the tone after 2 seconds, another circuit is required for that. Perhaps something like this "One-Shot Tone Burst" circuit: http://www.eleccircuit.com/one-shot-timer-use-ic-ne555/
My favorite electronics book is "Engineer's Notebook" purchased in 1980. Although some of the ICs are no longer available. http://www.amazon.com/Forrest-Mims-Engineers-Notebook/dp/1878707035
The circuit that you use depends on the signal source, whether it is steady on or a pulse. I agree with Bob N that a microprocessor will do everything. Its circuit has the smallest parts count, will sense inputs and (if they meet certain conditions) will output the desired signal for the required time period. If one does not have a programmer, buying that will make the project more expensive. And it will take LOTS of time to learn how to program. That cost of time and money can be spread over several projects.
Joe
[/u]
grosseair(at)comcast.net Guest
Posted: Fri Oct 21, 2011 10:47 am Post subject: EI clock chime |
I believe "ENABLE" is the ground and "Vcc" is 5VDC. When your clock goes
"low" it connects to ground and makes the circuit to activate the tone.
John Grosse
Michael Welch wrote:
Peter,
Mike W
Posted: Fri Oct 21, 2011 11:15 am Post subject: EI clock chime |
Thanks for that! If I were to put a pot in place of the 220 resistor would I be able to adjust the volume? Also if I wanted to drive a 600 ohm load - ie an aircraft audio system - would I increase the value of all the resistors by a factor of 75, or would that affect the frequency of the output?
Is the actuated by the down going edge, or because there is a potential difference between enable and Vcc? We used to call that ac or dc coupled, not sure if that's the correct use of those terms?
Peter
On 21/10/2011 18:12, James Kilford wrote: [quote] Vcc is the supply line. Â
Posted: Fri Oct 21, 2011 11:22 am Post subject: EI clock chime |
I've found the datasheet for the 74LS368 here, looks like they require only a 5v supply and input voltage, and so I guess only output 5v also - not sure how that will drive my audio panel ...
Peter
Mike Welch
Posted: Fri Oct 21, 2011 11:23 am Post subject: EI clock chime |
John,
Got it!! Thanks for the explanation. Nice easy circuit.
Mike Welch
On Oct 21, 2011, at 1:10 PM, John Grosse wrote:
I believe "ENABLE" is the ground and "Vcc" is 5VDC. When your clock goes "low" it connects to ground and makes the circuit to activate the tone.
John Grosse
> Peter,
> Mike W
Posted: Fri Oct 21, 2011 11:48 am Post subject: Re: EI clock chime |
Re: Gated Tone Source
I would not change the value of any component unless you intend to change the tone frequency. The speaker could be replaced with a pot. And a capacitor between the pot and the aircraft audio system will block DC. Bob's advice is needed here.
Joe
| Quote: | | If I were to put a pot in place of the 220 resistor would I be able to adjust the volume? Also if I wanted to drive a 600 ohm load - ie an aircraft audio system - would I increase the value of all the resistors by a factor of 75 |
Mike Welch
walter.fellows(at)gmail.c Guest
Posted: Fri Oct 21, 2011 12:43 pm Post subject: EI clock chime |
I have been trying to unsubscribe to the list. I follow the instructions by hitting the execute button and it tells me that I don't need to take any other action to unsubscribe. Nevertheless I keep receiving the emails. Please unsubscribe me.
On Fri, Oct 21, 2011 at 12:48 PM, user9253 <fran4sew(at)banyanol.com (fran4sew(at)banyanol.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: "user9253" <fran4sew(at)banyanol.com (fran4sew(at)banyanol.com)>
Joe
Joe Gores
http://forums.matronics.com/viewtopic.php?p=355678#355678
le, List Admin.
#avg_ls_inline_popup{position:absolute;z-index:9999;padding:0px;margin:0px;overflow:hidden;wordWrap:break-word;color:black;font-size:10px;text-align:left;line-height:130%;}#avg_ls_inline_popup div{border-width:3px;border-style:solid;padding:3px;padding-left:8px;padding-right:8px;-moz-border-radius:5px;-webkit-border-radius:5px;}#avg_ls_inline_popup .red{border-color:#D20003;;background-color:#F5D4C1;;}#avg_ls_inline_popup .orange{border-color:#F57301;;background-color:#FFD3B0;;}#avg_ls_inline_popup .yellow{border-color:#EAA500;;background-color:#FEEFAE;;}#avg_ls_inline_popup .green{border-color:#00A120;;background-color:#C3E5CA;;}
Posted: Fri Oct 21, 2011 1:32 pm Post subject: EI clock chime |
Bob, working on the two tone generator in the ‘Connection, what is the resistor that is between the two timers? Is it 220k ?
Bill Shank RV6
