avionics
pmdental(at)btinternet.co
PostPosted: Sat Oct 15, 2011 11:22 pm    Post subject: avionics Reply with quote
gavanne(at)iconz.co.nz
PostPosted: Sun Oct 16, 2011 8:53 pm    Post subject: avionics Reply with quote
Hi Paul,
Yes a couple of us here in New Zealand have used the mini power panel or Sport Panel as it used to be called, it works well and slides in nicely under the main panel as per the attached photos, I would recommend it for simplicity
Cheers Gavin Lee ZK-EPA #355………….NZ 20……..Australia 6
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Paul & Vanessa Munford
Sent: Sunday, 16 October 2011 8:20 p.m.
To: Europa-List(at)matronics.com
Subject: Fw: avionics
 Filesize:  1.73 MB
 Viewed:  2445 Time(s)
 Filesize:  1.87 MB
richard.churchill-coleman
PostPosted: Thu Oct 20, 2011 11:42 am    Post subject: avionics Reply with quote
Hi Listers,
Sort of linked to the query from Gavin - has anyone used the VP-X Sport or Pro Power solid state switch/circuit breaker units in a Europa or had any thoughts about whether it clashes with any LAA requirements - as a minimum it apparently addresses the trim motor failure mode and OVP protection - if 'legal' my main concern is whether the 1.9lbs weight will net out against the circuit breakers and wiring that would otherwise be required when my Europa will only have a simple VFR fit, no electric flaps and probably no landing light?
Richard C-C
Mono 912S G-RPCC
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Gavin and Anne Lee
Sent: 17 October 2011 05:48
Subject: RE: Fw: avionics
Hi Paul,
----- Original Message -----
From: Paul & Vanessa Munford (pmdental(at)btinternet.com)
To: Europa-List(at)matronics.com (Europa-List(at)matronics.com)
Sent: Friday, October 14, 2011 10:13 PM
Subject: avionics
Hi everyone. Building a NG trigear & need some advice on avionics panel. To simplify matters I was considering using a commercial power panel such as the TRAYMOUNT EXBUS2V, LIGHTSPORT or MINI POWER PANEL as found in Aircraft Spruce catalogue. Does anyone out there have any experience with these units. Thankyou. Paul Munford
