yak52
Posted: Thu Oct 27, 2011 5:28 am Post subject: SAIB |
Isn't it interesting how so many of the people who demanded the redesign of so many components of the 601xl now feel free to disregard, delete or change the same redesign they so stridently sought. One can only wonder how(if) they have indicated compliance with the SAIB and understand the consequences of making that entry into their logbooks. [quote][b]
psm(at)att.net Guest
Posted: Thu Oct 27, 2011 5:55 am Post subject: SAIB |
Roger,
I assume you are talking about me with your comment below.
Before the major structure redesign the FAA engineers determined the design didn't meet the ASTM standard for LSA structure requirements and after the redesign it does. This is exactly what I was looking for when I "Demanded" a redesign of the whole aircraft -- not "the redesign of so many components" as you said.
The one item I chose to not include in my plane is definitely not related to the ASTM standard (F2245). It just doesn't address the issue of ham fisted pilots or clumsy people kicking the control stick while jumping into the cockpit.
Each of our planes is different. The upgrade design was an attempt by junior engineers to cover all variations of the Zodiac XL and 650. I think they did a wonderful job since the FAA experts came to the conclusion they met the minimum standard requirements. I am quite pleased with the way the whole process went and even more pleased with the simple fact that there haven't been any more structure failures since the upgrade was implemented.
If it bothers you so much that my plane only has one set of aileron limit stops rather than the two called for in the upgrade I will completely understand if you refuse to ride in my plane.
Paul
XL 20 hours into phase I testing.
On 10/27/2011 6:25 AM, roger lambert wrote: [quote]Isn't it interesting how so many of the people who demanded the redesign of so many components of the 601xl now feel free to disregard, delete or change the same redesign they so stridently sought. One can only wonder how(if) they have indicated compliance with the SAIB and understand the consequences of making that entry into their logbooks. [b]
steve.freeman(at)syntaxds Guest
Posted: Thu Oct 27, 2011 6:20 am Post subject: SAIB |
isn’t it interesting how some people will lob stink bombs without signing their name or offering any real value to the conversation?
Steve Freeman
Isn't it interesting how so many of the people who demanded the redesign of so many components of the 601xl now feel free to disregard, delete or change the same redesign they so stridently sought. One can only wonder how(if) they have indicated compliance with the SAIB and understand the consequences of making that entry into their logbooks. | Quote: | | http://www.matronics.com/Navigator?Zenith-List | 01234567
Afterfxllc(at)aol.com Guest
Posted: Thu Oct 27, 2011 8:52 am Post subject: SAIB |
I have done 12 of these upgrades and I will tell you that the number one useless part of it is the aileron stop that was added. First of all it is so weak it wouldn't stop any damage from someone kicking the stick and IMHO it shouldn't be part of the upgrade as it doesn't allow room to adjust the turnbuckles or safety them so I think cables will become slack as a result. If you match the stops to the aileron stops what's the point? Any damage is going to occur with or without the second stop. I also think there is some reg out there that states only one stop per control but I have never looked it up.
Jeff
In a message dated 10/27/2011 9:56:51 A.M. Eastern Daylight Time, psm(at)att.net writes:
| Quote: | Roger,
Paul
On 10/27/2011 6:25 AM, roger lambert wrote: | Quote: | Isn't it interesting how so many of the people who demanded the redesign of so many components of the 601xl now feel free to disregard, delete or change the same redesign they so stridently sought. One can only wonder how(if) they have indicated compliance with the SAIB and understand the consequences of making that entry into their logbooks.
ef="http://www.matronics.com/Navigator?Zenith-List">http://www.matronics.com/Navigator?Zenith-List
s.matronics.com/">http://forums.matronics.com
p://www.matronics.com/contribution">http://www.matronics.com/contribution
Posted: Thu Oct 27, 2011 9:40 am Post subject: SAIB |
Hi Jeff,
Thank you for your comments about the aileron crank stop. I agree with you completely.
The requirements for installing the upgrade were a bit vague. It was not required to religiously stick to the exact design in the upgrade package. Rather, the idea was to follow the general ideas in the upgrade design and conform to it as appropriate for each airplane.
We should all remember that we build experimental airplanes and each one is a little bit different from each other one. The upgrade package was created because there was a glaring problem with the original design that got too much attention from the NTSB and FAA. From a political perspective, we would not have received so much attention from the government people if not for the fact that the same design was being produced as a factory complete airplane. If only experimental - amateur built versions of this design were in the field I doubt we would have benefited from the reviews conducted by the FAA that led to creation of the upgrade package and verification that it resolved the structural problems.
Even after installing the upgrade we are still flying experimental - amateur built airplanes. I think the upgrade did a great deal to improve the strength of the airframe and will improve the results we all experience in the future. In the long run, though, anyone who wants "Guaranteed" design and construction in their plane should fly a type certificated one.
Paul
Camas, WA
On 10/27/2011 9:49 AM, Afterfxllc(at)aol.com (Afterfxllc(at)aol.com) wrote: [quote] I have done 12 of these upgrades and I will tell you that the number one useless part of it is the aileron stop that was added. First of all it is so weak it wouldn't stop any damage from someone kicking the stick and IMHO it shouldn't be part of the upgrade as it doesn't allow room to adjust the turnbuckles or safety them so I think cables will become slack as a result. If you match the stops to the aileron stops what's the point? Any damage is going to occur with or without the second stop. I also think there is some reg out there that states only one stop per control but I have never looked it up.
Jeff
In a message dated 10/27/2011 9:56:51 A.M. Eastern Daylight Time, psm(at)att.net (psm(at)att.net) writes:
| Quote: | Roger,
Paul
Posted: Thu Oct 27, 2011 10:01 am Post subject: SAIB |
<<. In the long run, though, anyone who wants "Guaranteed" design and construction in their plane should fly a type certificated one.>>
And that is certainly no guarantee either! Don’t get me started! LOL
Steve
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Paul Mulwitz
Sent: Thursday, October 27, 2011 10:38 AM
Subject: Re: SAIB
Hi Jeff,
Paul
Camas, WA
Jeff
Roger,
Paul
Isn't it interesting how so many of the people who demanded the redesign of so many components of the 601xl now feel free to disregard, delete or change the same redesign they so stridently sought. One can only wonder how(if) they have indicated compliance with the SAIB and understand the consequences of making that entry into their logbooks. | 012
yak52
Posted: Thu Oct 27, 2011 12:51 pm Post subject: SAIB |
The Code of Federal Regulation rather explicitly states how maintenance records are to be kept.
A review of the SAIB clearly states:
"For amateur-built and E-LSA owners and operators: Due to shared design characteristics that
amateur-build and E-LSA aircraft have with S-LSA, we strongly recommend compliance with the
drawings and instructions contained in the AMD Safety Directive/Safety Alert and recommend
the following: •
Obtain and install the kit manufacturer’s structural modification kit. The modification kit addresses the structural design changes and operating limitations required to meet a safe condition for operation. Contact the kit manufacturer with any modifications already incorporated to correct the identified unsafe condition to validate safety-of-flight issues
Therefore, if you have not obtained and installed the kit manufacturer's structural modification kit or obtained some waiver from AMD or the kit manufacturer or perhaps obtained an equivalency evaluation from some FAA designated personnel and placed such documentation within your logbook, you may have violated the FAR's maintenance records requirements and potentially subjected yourself to sanction by the FAA, which you have provided the evidence for by identifyng noncompliance in the public record. For those of you with faint hearing, those scratching sounds in the background are the hands of people amending their logbooks to state they complied with the SAIB with now noted exceptions.
Posted: Thu Oct 27, 2011 1:30 pm Post subject: SAIB |
To me the operant words below are “recommend compliance“ and “recommend the following.“
The wording does not compel compliance with phrasing such as “SHALL COMPLY.” This is a subtle but very important distinction in legal documents.
I am not an attorney so do not rely on my interpretation but this is how I view it. Any attorneys want to chime in?
“The Code of Federal Regulation rather explicitly states how maintenance records are to be kept. ”
Forgive me, but the paragraph you have highlighted for review does not state anything about documentation or log book entries. Please correct me if I am wrong.
"For amateur-built and E-LSA owners and operators: Due to shared design characteristics that amateur-build and E-LSA aircraft have with S-LSA, we strongly recommend compliance with the drawings and instructions contained in the AMD Safety Directive/Safety Alert and recommend the following:
For the record I think a person is a fool if they don’t do the upgrade but there is nothing in Roger’s post to indicate any builder is compelled by statute or regulation to do so.
Steve
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of roger lambert
Sent: Thursday, October 27, 2011 1:47 PM
Subject: SAIB
the following:
| Quote: | | http://www.matronics.com/Navigator?Zenith-List | 0123456789
Posted: Thu Oct 27, 2011 2:10 pm Post subject: SAIB |
I agree with you on this one Steve.
In addition, there just isn't any way the FAA can compel experimental aircraft owners to do anything to their airplanes. That is the nature of experimental aircraft.
In my case, there is no entry of any sort in my log books regarding the SAIB. My plane was not certified until after the upgrade was installed. So, there is no maintenance or operating limitation impact of the SAIB on my plane.
It doesn't make a lot of sense to get into silly arguments over the paperwork involved in the upgrade issue. I agree completely that each owner should "Essentially" install the upgrade in their plane. This doesn't mean compliance of every rivet and bolt to the upgrade drawings. It does mean balancing the ailerons, installing the reinforcements for the spars and spar carry through, and other features relating to the airframe strength. Just like everything else in this endeavor, I would expect each plane to be a little bit different from the rest of the fleet both before and after the upgrade is installed.
The only real mistake I think will be made by a significant number of Zodiac owners is to decide not to install the upgrade at all. This is not an option for planes not already certified when the SAIB was issued since the FAA refused to inspect and certify any planes without the upgrade after that point.
Paul
Camas, WA
On 10/27/2011 2:27 PM, Steve Freeman wrote: [quote] <![endif]--> <![endif]-->
"For amateur-built and E-LSA owners and operators: Due to shared design characteristics that amateur-build and E-LSA aircraft have with S-LSA, we strongly recommend compliance with the drawings and instructions contained in the AMD Safety Directive/Safety Alert and recommend the following: •
Steve
From: owner-zenith-list-server(at)matronics.com (owner-zenith-list-server(at)matronics.com) [mailto:owner-zenith-list-server(at)matronics.com (owner-zenith-list-server(at)matronics.com)] On Behalf Of roger lambert
To: zenith-list(at)matronics.com (zenith-list(at)matronics.com)
Subject: SAIB
the following: •
0 1 2 3 4 5 6 7 8 9
0 [b]
passpat(at)aol.com Guest
Posted: Fri Oct 28, 2011 6:33 am Post subject: SAIB |
Just think you have installed the upgrade and flown the airplane for a few years you are the org builder and always did the conditional inspection.
Now you have decided to sell due to health or whatever. The new owner takes it and has a pre buy inspection. He or She uses a A&P for this and the guy is pretty knowledgable
he discovers that some little part has been omitted. Next thing he might do is deem the aircraft un-airworthy due this omission
P
paulrod36(at)msn.com Guest
Posted: Fri Oct 28, 2011 11:30 am Post subject: SAIB |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Roger, as long as it's registered as an A-AB, builders are free to make any alterations they want. I'd agree with them as long as the changes they made weren't too radical, and frankly, the addition of the stick stop really only helps the two-stick, cabled aileron system, and then only for pilots who like to imitate King Kong with the stick.
Paul R
