ZTRON LABS ZL-BP4/8
bakerocb
PostPosted: Fri Oct 28, 2011 1:36 pm    Post subject: ZTRON LABS ZL-BP4/8 Reply with quote
10/28/2011
Hello Bob Nuckolls, I am interested in your reaction to this product:
http://www.ztronlabs.com/products/bp8/brochure.pdf
Thank you,
'OC' Baker Says: "The best investment we can make is the time and effort to
gather and understand knowledge."
PostPosted: Sat Oct 29, 2011 6:28 am    Post subject: ZTRON LABS ZL-BP4/8 Reply with quote
I have no doubt that they perform as
advertised. But unlike the legacy breaker/
fuse + switch combinations, the features
give rise to new questions.
First, what deficiencies in the design,
installation, maintenance and cost of ownership
for breaker/fuse+switch are eliminated or at
least mitigated by the new product? In
other words, are there demonstrable, compelling
performance gains for adopting this product?
Are they more reliable? In other words, has
history offered cases where the B/F+S combination
has failed to perform it's intended task?
Are the new devices less likely to repeat any
such events assuming they exist? Their
parts-count is higher . . . and certainly part
vulnerable to external stimulus for which
DO-160 was crafted to explore.
If not a reliability trade-off, then are
they less expensive to own, operate and
service? $190 for eight controlled positions
works out to nearly $25 per position. Certainly
competitive with B+S but not with F+S
configurations.
Convenience? Hmmm . . . you cut a big
hole in the panel to mount a big electro-
whizzy that shares form, fit and function
with no other product like it. Suppose
you only need 6 of the positions . . . or
need 9? These controls do not offer the
flexibility of multi-function toggles
with spring loading and progressive
transfers.
Unlike the toggle with immediately recognizable
position, these devices use lights. Are
they sunlight viewable?
This device is not a drop-in replacement
for all protected and controlled circuits
in the airplane . . so your almost sure
to have alternative hardware tucked away
on the panel anyhow.
Then there is the question as to how well
the designers understand the legacy aircraft
environment. Maybe they didn't do DO-160
verification but were they cognizant of the
design tools and processes that go to passing
a DO-160 verification?
Everyone needs to make up their own mind
as to what features of reliability, convenience,
cost and STYLE goes to meeting personal
design goals on their project. I'll suggest
that there are few technical and even fewer
economic incentives for adapting such a
product to an OBAM aircraft. But when it
comes to style, there's no accounting for
taste.
PostPosted: Sat Oct 29, 2011 7:23 am    Post subject: Re: ZTRON LABS ZL-BP4/8 Reply with quote
A fuse holder costs much less and models are available to hold up to 20 fuses.
http://www.amazon.com/Bussman-holder-Truck-electrical-application/dp/B0026BK6GY/ref=sr_1_10?ie=UTF8&qid=1313369427&sr=8-10
I have had trouble operating capacitance type switches when my fingers are cold and dry or when wearing gloves. If one of those 8 switches goes bad, the whole unit will have to be removed for repair or replacement. If the company goes out of business, it will be a challenge to fill the hole in the panel with some type of replacement. An aircraft builder has the skills to replace a fuse or switch, but might not be able to repair electronic switches. There are nice looking discrete illuminated switches available.
Joe
Joe Gores
