				 Posted: Sat Nov 05, 2011 10:00 am    Post subject: Anyone had success with Matronics Fuel Flow Pulsation Damper |
				Has anyone installed this:
 http://www.matronics.com/fuelchec/damper.html
 to reduce the inaccuracies caused by mounting the fuel flow transducer
 too close to the  boost pump?
 I definitely have the problem though it's not really that bad given that
 the boost pump is on only for short periods relative to long cross
 country trips.  The error is in a conservative direction and so far is
 insignificant.
 ..but I'd still like to reduce the inaccuracy if I can do it without
 relocating the thing.
 Bill
		jkreidler
  Joined: 13 Feb 2008 Posts: 151 Location: Sheboygan Falls WI
				 Posted: Sun Nov 06, 2011 5:07 am    Post subject: Re: Anyone had success with Matronics Fuel Flow Pulsation Da |
				Bill, we installed it and really did not notice a difference on fuel flow accuracy.  Ultimately the solution was as Robin said to relocate the fuel flow sensor to between the servo and the spider.  Rock solid and accurate since then.
 The other thing we notice when using the pulsation dampener was that we started getting low fuel pressure warnings.
 Bottom line, we removed it.  It is still on the shelf, if you want to give it a try let me know.
 I actually feel kind of bad posting this since Matronics does so much for our RV-10 community.  Others might have had better success, just my experience.
 Thanks, Jason
  _________________ Jason Kreidler
4 Partner Build - Sheboygan Falls, WI
Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler
N44YH - Flying - #40617 |
