RotaxEngines-List Digest: No. of blades vs. prop diameter
BARRY CHECK 6
PostPosted: Mon Nov 14, 2011 6:43 pm    Post subject: RotaxEngines-List Digest: No. of blades vs. prop diameter Reply with quote
John:
The rule of thumb for an aluminum prop is 2" per blade.�
So, reduce by 2" going from a 2 blade to a 3 blade and another 2" going to a 4 blade.
NOW! �The pitch INCREASES 1" above MAX when going from a 2 blade to a 3 blade...
So, if you were at 60" of pitch on a 2 blade you go to a 61" on a three blade and then a 63" on a 4 blade.
The other rule of thumb is: �You will loose 50 RPM for every inch of increase pitch and gain 50 RPM for every inch of decrease in diameter.
The ONLY final test is TEST - TEST - TEST.
Barry
On Mon, Nov 14, 2011 at 2:26 PM, John Goodings <goodings(at)yorku.ca (goodings(at)yorku.ca)> wrote:
[quote]--> RotaxEngines-List message posted by: John Goodings <goodings(at)yorku.ca (goodings(at)yorku.ca)>
We are currently using a 68" 3-blade GSC prop on our Zodiac 601HD with R912S. �We are happy with it, but the ground clearance is not great for grass strips. �I saw a recent reference to a Warp Drive 4-blade prop. �If we went to a 4-blade prop, by how much would the prop diameter be reduced?
John & Peter Goodings, C-FGPJ, CH601HD with R912S, Carp/Ottawa/Toronto.
om" target="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
-List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
http://forums.matronics.com
le, List Admin.
