New/Unused L-29 Rear Canopy
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> L29-List
SD737(at)aol.com
PostPosted: Mon Nov 14, 2011 1:11 pm    Post subject: New/Unused L-29 Rear Canopy Reply with quote
I have a complete rear L-29 Canopy with perfect glass/like new /never used for sale.
Has seal and gauge and all plumbing.
Contact directly off list.
Front Canopy sold.
In a message dated 11/14/2011 12:11:44 P.M. Pacific Standard Time, jonboede(at)hotmail.com writes:
I don't know if Doug Sapp can get you the Oxygen system fitting but he can certainly get you a strut tool, which includes the manometer and control valve.
At the Cold War Air Museum our practice has been to adapt the ground equipment, not the aircraft. In the case of nitrogen, we simply tap the nitrogen nipple (CGA 580) and install a spare Soviet fitting that matches the other end of the hose... Doug can sell you a spare fitting for a couple bucks. If you don't have a Soviet (er, metric) hose, get whatever hose you'd like to fit to your nitrogen bottle and then make a little brass adapter between them.
Typically we take a "nitrogen bottle to Soviet aircraft" hose with us whenever we go to airshows.
Doug sells stuff for the Nanchang CJ-6A, but there's so much commonality between that and most other Red Star aircraft that he should be on your "possible parts source" list. He gets a container full of stuff from China every other month.
His number is 509-826-4610
Jon
PS. I made up an oxygen fitting for my L-39 and the MiGs by using a US hose and making brass fitting to adapt it, just the same as the nitrogen stuff.
> Date: Mon, 14 Nov 2011 11:04:55 -0800
To: l29-list(at)matronics.com
Subject: Re: O2 and N2 Fitting
--> L29-List message posted by: John Fischer <fish(at)aviation-tech.com>
ershire,
I do not know about the L-29, but on my Yak-52, I just took the Russian
valves out of my landing gear, and put in American high pressure
schreader valves.
it was as simple as unscrewing the Russian fittings and screwing in the
new ones.
Good Luck
John Fischer
On 11/14/2011 10:44 AM, ershire wrote:
> --> L29-List message posted by: "ershire"<jsocolof(at)ershire.com>
> Any know where I can get the pressure fitting to service the Russian Oxygen System and Landing Gear Strut Nitrogen?
> http://forums.matronics.com/viewtopic.php?p=357841#357841
tp://www.aeroelectric.com/">www.aeroelectric.com
/ href="http://www.buildersbooks.com/">www.buildersbooks.com
http://www.homebuilthelp.com/">www.homebuilthelp.com
p://www.matronics.com/contribution">http://www.matronics.com/contribution
="http://www.matronics.com/Navigator?L29-List">http://www.matronics.com/Navigator?L29-List
s.matronics.com/">http://forums.matronics.com
- The Matronics L29-List Email Forum -
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> L29-List All times are GMT - 8 Hours
