earth shield earthing
JOHN TIPTON
PostPosted: Thu Nov 17, 2011 12:08 am    Post subject: earth shield earthing Reply with quote
Hi Guys (Bob)
How do you attach the shield of the co-axle cable, of say the wire going out to your wing tip strobe tubes that require the shield to be connected (only) to ground at the strobe power unit - do you simply unravel some of the braid twist it and push it into a AMP ring connector and crimp up ?
Best regards
JOHN TIPTON
PostPosted: Thu Nov 17, 2011 12:15 am    Post subject: earth shield earthing Reply with quote
Hi Guys (Bob)
Best regards
PostPosted: Thu Nov 17, 2011 3:12 pm    Post subject: earth shield earthing Reply with quote
At 02:09 AM 11/17/2011, you wrote:
Hi Guys (Bob)
Here's a couple of techniques.
http://www.aeroelectric.com/articles/pigtail/pigtail.html
http://www.aeroelectric.com/articles/Shield_Grounds/
http://www.aeroelectric.com/articles/shldwire/shldwire.html
What kind of wire was supplied with your strobes? If
it's foil shield, then there will be a bare 'drain
wire' included in the makeup over the shield. You
ground the shield by putting a terminal on this wire.
[img]cid:.0[/img]
 Filesize:  137.91 KB
 Viewed:  4890 Time(s)
JOHN TIPTON
PostPosted: Fri Nov 18, 2011 12:33 am    Post subject: Re: earth shield earthing Reply with quote
Hi Bob
Yes: that's the one:
Many thanks
