dpharker(at)worldnet.att. Guest
Posted: Wed May 24, 2006 5:20 am Post subject: AFP Booster Pump and Filter on Firewall |
Working on my 7A fuselage and have the AFP BP/Filter installed per plans.
Seems like too much plumbing inside the cockpit to me. Thinking of placing
the pump and filter on the front of the firewall. Anybody done this or have
a suggested location? Thanks
Don Harker
Gurnee IL
7A fuselage
gerf(at)gerf.com Guest
Posted: Wed May 24, 2006 6:18 am Post subject: AFP Booster Pump and Filter on Firewall |
All the instructions I've seen from AFP say DON'T put it on the
hot side of the firewall. I think heat is the major issue. If
you do put it on the firewall side you will need to install a
shield around it and cool it with a blast tube.
g
<dpharker(at)worldnet.att.net>
per plans.
Thinking of placing
this or have
Don Harker
Gurnee IL
7A fuselage
__g__
Gerry Filby gerf(at)gerf.com
Tel: 415 203 9177
dbris200(at)sbcglobal.net Guest
Posted: Wed May 24, 2006 6:26 am Post subject: AFP Booster Pump and Filter on Firewall |
Mine is in the lower right corner of the firewall. I put a cover over
the top of it and installed a blast tube just in case. It fit very
nicely behind the landing gear (-6). I've never had a problem with it
and it's easy to service the filter.
Dave
Donald Harker wrote:
Don Harker
Gurnee IL
7A fuselage
don.wentz(at)intel.com Guest
Posted: Wed May 24, 2006 7:00 am Post subject: AFP Booster Pump and Filter on Firewall |
I initially had my AFP boost pump and filter forward of the firewall and
had nothing but problems with hot fuel.
After the -7 came out with the pump and filter location near the fuel
selector, I moved mine there and it has worked much better, no more
dead-stick landings due to hot fuel. Kind of a nice thing .
A carefully constructed sealed box with plenty of cool air should work,
assuming you're able to fit it in without restricting access to other
areas under the cowl.
Dw
RV-6 925hrs
Posted: Wed May 24, 2006 7:32 am Post subject: AFP Booster Pump and Filter on Firewall |
I ordered the -7 boost pump/filter mount for my -6A - I like the way it finishes up.....much better than finding a place myself......
Ralph
shempdowling2(at)earthlin Guest
Posted: Wed May 24, 2006 8:16 am Post subject: AFP Booster Pump and Filter on Firewall |
I modified my 6 to put this where the plans state and it really is no
problem.
Shemp/Jeff Dowling
RV-6A, N915JD
265 hours
Chicago/Louisville
RVer273sb(at)aol.com Guest
Posted: Wed May 24, 2006 10:12 am Post subject: AFP Booster Pump and Filter on Firewall |
I have my AFP fuel pump on the front of the firewall
on my RV-4. 6 years and 1450 hrs later I have not
had a single problem. The filter is in the tunnel.
Pump is mounted to a plate that is adel clamped
to the engine mount lower tubes. I have a 1in scat
tube to it for cooling.
Stewart, RV-4
Erich_Weaver(at)URSCorp.c Guest
Posted: Wed May 24, 2006 1:40 pm Post subject: AFP Booster Pump and Filter on Firewall |
I can relate to the desire to avoid all the plumbing. Rather than do all
the aluminum tube bending, I used various AN fittings (Earls Performance
or similar) for the AFP pump (on the cool side of the firewall) to make the
turns along with an appropriate flexible hose. Ok, the cost of the
fittings did add up. It was easy to put together after that though, and I
avoided prolonged bouts of cussing that I am prone to.
Something to consider anyway
Erich Weaver
klwerner(at)comcast.net Guest
Posted: Wed May 24, 2006 2:02 pm Post subject: AFP Booster Pump and Filter on Firewall |
You cuss too ???
Terry Watson
Joined: 09 Jan 2006 Posts: 270 Location: Seattle, WA USA
Posted: Wed May 24, 2006 3:35 pm Post subject: AFP Booster Pump and Filter on Firewall |
About using AN fittings in the fuel system, I ran across this note in the
Airflow Performance installation manual:
Apendix A, page A-20, Rev. A. photo:
"Care must be taken to avoid the use of 90 degree fittings on the suction
side of the fuel pump on high horse power applications. The more correct way
would be to use a straight bulkhead fitting and a full flow 90 degree hose
end to eliminate flow pressure drop."
A retired mechanical engineer friend told me that way back when he was in
school, his hydraulics instructor told him that three elbows is equal to a
plug. It was meant to be tongue-in-cheek, but the idea was that elbows
reduce flow in a way that bent tubing does not. Of course it will all depend
on tubing size, horsepower, and a few other considerations, but this is why
I went through a lot of tubing to get the bends right for the fuel valve and
boost pump. I also used a wing root mounted Andair gascolator with my AFP
system, which probably wasn't a good idea in hindsight. I did talk to AFP
about it and he thought it was a wasted effort, but acceptable.
Terry
RV-8A #80729
Baffles finished!
Erich Weaver
