JSMcGrew(at)AOL.COM Guest
Posted: Wed May 24, 2006 5:25 am Post subject: RV-10 Tow Bar |
My quest for a tow bar that works with my RV-10 continues. If anyone ca n point me in the right direction, I would appreciate it. The only thing mentioned in the archives is one from Coss Aviation from South Africa and a couple general references to Bracket Aircraft and Aircraft Spruce. Does anyo ne have a specific part number of one that works?
The Universal Tow bar from Aircraft Spruce (part #13-02250) does NOT wo rk. I'm sending it back and going to try again...
-Jim McGrew
40134
bcondrey
Posted: Wed May 24, 2006 5:36 am Post subject: RV-10 Tow Bar |
Bogert has one specifically made for the RV-10 that seems to work fine. For some reason Spruce doesn’t list it though
http://www.bogert-av.com/ bogi-bars.php
model #4-RV10; $84
Bob #40105
-Jim McGrew
40134
Posted: Wed May 24, 2006 5:53 am Post subject: RV-10 Tow Bar |
Thank you!
In a message dated 5/24/2006 7:39:52 A.M. Mountain Daylight Time, bob.condrey(at)baesystems.com writes:
| Quote: | < FONT style="BACKGROUND-COLOR: transparent" face=Arial color=#000000 size =2>
Bogert has one specifically made for the RV-10 that seems to work fine. For some re ason Spruce doesn™t list it though
model #4-RV10; $84
Bob #40105
My quest for a tow bar that works with my RV-10 continues. If anyone ca n point me in the right direction, I would appreciate it. The only thing mentioned in the archives is one from Coss Aviation from South Africa and a couple general references to Bracket Aircraft and Aircraft Spruce. Does anyo ne have a specific part nu mber of one that works?
-Jim McGrew
40134
< /FONT> |
Jim "Scooter" McGrew
jsmcgrew(at)aol.com
Posted: Wed May 24, 2006 6:04 am Post subject: RV-10 Tow Bar |
JSMcGrew(at)aol.com (JSMcGrew(at)aol.com) wrote:
| Quote: | My quest for a tow bar that works with my RV-10 continues. If anyone ca n point me in the right direction, I would appreciate it. The only thing mentioned in the archives is one from Coss Aviation from South Africa and a couple general references to Bracket Aircraft and Aircraft Spruce. Does anyo ne have a specific part number of one that works?
-Jim McGrew
40134
| If it were me (and I plan on being there!), I'd look at the ACS tow bar, and since you know WHY it won't work ..... modify it! C'mon now, you've built a whole airplane! How hard can it be to change a tow bar????
Linn
do not archive.
Ray.R.Doerr(at)sprint.com Guest
Posted: Wed May 24, 2006 6:07 am Post subject: RV-10 Tow Bar |
This is the one I use for my RV-9 and RV-10. Works great on both planes. It’s from Aircraft Spruce.
4-RVA
RVA Style with Nose Wheel
13-01811
$78.75
Thank You
Ray Doerr
CDNI Principal Engineer
-----Original Message-----
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of JSMcGrew(at)aol.com
Sent: Wednesday, May 24, 2006 8:24 AM
Subject: RV-10 Tow Bar
Posted: Wed May 24, 2006 6:27 am Post subject: RV-10 Tow Bar |
This is the one I use for my RV-9 and RV-10. Works great on both planes. It’s from Aircraft Spruce part # 13-01811 (RVA Style with Nose Wheel)
Thank You
Ray Doerr
-----Origi nal Message-----
pilotdds(at)aol.com Guest
Posted: Wed May 24, 2006 6:29 am Post subject: RV-10 Tow Bar |
I have been using a tow bar from a c-210.Works great
Posted: Wed May 24, 2006 6:30 am Post subject: RV-10 Tow Bar |
I will get part number this weekend.
Tim(at)MyRV10.com Guest
Posted: Wed May 24, 2006 6:36 am Post subject: RV-10 Tow Bar |
Here's some new Towbar comments:
(Old) The RVA towbar from Aircraft Spruce does indeed work fine
on the RV-10. I have one. When you first buy it, you can use
it on the 10 nosewheel on the axle area. After you add wheel fairings,
you'll cut 3/4" off the towbar pinchers and use it on some other
capscrews. But, it works just fine. I see they now offer an RV-10
version, but I'm sure there's not a lot different...it's probably
just pre-cut. You should ask them.
(New) In search of a nice rudder gust lock, I created one that
works really well. I spoke with Bogerts about it to see if
they'd be interested in making it a product of theirs that
would save builders having to build one. The RV-10 does
definitely need a rudder gust lock. This progressed into
a bit larger project, where we are trying to come up with
a Towbar/Gust-Lock that will do everything you would ever
want...it would be a towbar, and with a couple of attachments
it would also serve as a rudder, AND aileron/elevator gust lock.
I don't have a timeline for when you could see a finished product.
I do have some photos of my rudder gust-lock only that I made.
It works really great, but means I have to have 2 things
hauled in the tail on long trips.
More to come...
Condrey, Bob (US SSA) wrote:
| Quote: | Bogert has one specifically made for the RV-10 that seems to work fine.
<http://www.bogert-av.com/bogi-bars.php>
model #4-RV10; $84
| Quote: | Bob #40105
-Jim McGrew
40134
mritter509(at)msn.com Guest
Posted: Wed May 24, 2006 6:52 am Post subject: RV-10 Tow Bar |
I purchased my RV-10 tow bar at www.bogert-av.com. Works great.
[quote] From: pilotdds(at)aol.com
Subject: Re: RV-10 Tow Bar
Date: Wed, 24 May 2006 10:29:52 -0400
flysrv10(at)gmail.com Guest
Posted: Wed May 24, 2006 8:15 am Post subject: RV-10 Tow Bar |
Here is my setup. It is a Bracket towbar. It works great for me.
Subject: Re: RV10-List: RV-10 Tow Bar
159.24 KB |
381 Time(s) |
