SR-2500 Wing Control Tube Question
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> MurphyMoose-List
jfolkerts1(at)gmail.com
PostPosted: Fri Nov 25, 2011 12:33 pm    Post subject: SR-2500 Wing Control Tube Question Reply with quote
Today, I’ve been fitting the torque tube in my right wing, just in front of the main spar. I built the torque tube bracket per the manual, but in installing the torque tube assembly to the bracket, the manual calls for an AN4-13A bolt, an AN960-418 washer, then an AIL-26 bushing (inner) in the AIL-27 brass bushing that is fitted to the bracket. Then an AN970-4 Penny Washer and another AN960-418 washer between the bushings and the torque tube. OK, the question, the AIL-26 bushing is 5/32” longer than the AIL-27 bushing it fits in. That introduces right to left movement in the torque tube. Should I trim the AIL-26 busing to fit? In addition, prior to final assembly, should I lubricate the bushing with some grease or something?
Jerry Folkerts
SR #093
www.mykitlog.com/jfolkerts/
- The Matronics MurphyMoose-List Email Forum -
http://www.matronics.com/Navigator?MurphyMoose-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> MurphyMoose-List All times are GMT - 8 Hours
