		blb7037(at)cox.net Guest
				 Posted: Wed May 24, 2006 3:00 pm    Post subject: Wiring around wing carry through on 601 |
				Has anyone got any good ideas on how to get wiring and the pitot tubes =
 from the rear fuselage to the front cabin area . Getting around the wing =
 carry through has given me fits. Zenith says they don't want me to drill =
 holes in it for grommets even though AMD did. AMD says they are working =
 on a way to go along the top rail. I don't see a good way to do that . I =
 have the center stick and it and the rudder cable take up the only =
 lightning hole.
 I am thinking about running them along the inside edge of both seats in =
 plastic conduits and hoping the upholstery will be thick enough to =
 conceal and protect the conduits and not be objectionable. There are a =
 lot of wires and tubes to go through there on my installation.
 Brian Briggerman
 Fountain Hills, AZ=20
 90% done and 190% to go
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Wed May 24, 2006 4:17 pm    Post subject: Wiring around wing carry through on 601 |
				Brian,
 You're right, there's few options in that area, but you might consider
 putting the bundled wires thru the hole just above the pivot plate
 using the same lightening hole.  A split rubber hose on the edge and a
 plastic bundle wrap will protect it all.  See the links below
 that show the problems you describe and it does include brake lines,
 fuel lines, pitot lines, all wiring from tail, wings, and battery
 cables. It can be done by adding supporting carry-throughs where needed,
 but you need to start early in the planning.
 http://www.macsmachine.com/images/largeassembly2/full/brakelines.gif
 http://www.macsmachine.com/images/largeassembly2/full/consolecleco.gif
 http://www.macsmachine.com/images/largeassembly2/full/consolecutaway.gif
 http://www.macsmachine.com/images/largeassembly2/full/batterycableroute.gif
 http://www.macsmachine.com/images/largeassembly2/full/bundlbus.gif
 http://www.macsmachine.com/images/largeassembly2/full/bundlsupts.gif
 http://www.macsmachine.com/images/largeassembly2/full/pitobracket.gif
 Hope some of this is helpful,
 Larry McFarland  601HDS at www.macsmachine.com
 Brian Briggerman wrote:
 lightning hole.
 Brian Briggerman
		JAPhillipsGA(at)aol.com Guest
				 Posted: Wed May 24, 2006 4:47 pm    Post subject: Wiring around wing carry through on 601 |
				Brian, I drilled two holes near the left seatbelt connector and ran the tubes
 under the seat area to the center spar. Then I drilled two holes in the spar
 and grommeted both sides and they exited about mid calf. Connected to two "L"s
 and routed both up into the instrument panel. I know ZAC does not want us to
 drill holes in the spar, but they have not designed an alternate method. Also,
 I installed the duel sticks and you have to drill four holes (?) for that to
 attach to the spar so what is two more. Lastly, if you have ever looked at the
 center spar for a Piper Warrior you will see holes you can run your hand
 through and really if our XL's are so fragile (I personally know mine is not) that
 the wings fall off because of two little holes in the spar, we shouldn't be
 flying them. FWIW, best regards, Bill of Georgia N505WP 601XL-3300 70 hours
				 Posted: Wed May 24, 2006 6:49 pm    Post subject: Wiring around wing carry through on 601 |
				I've got to ask: why are there what look like two cigarette lighter outlets
 opening out the bottom of your fuselage?
 -- Craig
		VideoFlyer(at)aol.com Guest
				The 601XL has only one hole in the spar inside the cabin.  And it already has
 rudder cables and the the torque tube running through it.  I looked long and
 hard at different ways to route pitot tubes and wires and brake lines over
 that spar.  A buddy of mine said to me, "Why don't you run them underneath the
 spar?  It looks like there's a channel under there."  And indeed, there is an
 exterior reinforcing channel running the length of the cockpit....right
 underneath the spar.  It's a simple matter of enclosing that channel, and putting
 holes through the cabin floor in front of and and behind the spar.  I am running
 my brake lines, my battery cables and pitot tubes from behind the seat, through
 a hole in the floor of the fuselage, through the newly enclosed channel (of
 course, you wait to enclose the channel until all the lines are routed
 properly) and back into the cabin through a hole in the floor up by the rudder pedals.
  It's clean...keeps a lot of clutter off the side walls, and it's very easy
 to do.  I'll try to post some pictures.
 Dave Harms
 601XL/Corvair
		tonyplane(at)bellsouth.ne Guest
				 Posted: Wed May 24, 2006 8:16 pm    Post subject: Wiring around wing carry through on 601 |
				I also agonized over this, but found that the brake lines and the pitot =
 and static tubes do in fact fit.  I also had previously askedZenith if I =
 could drill some access holes at the center of the center spar webs as =
 this is where the lowest loads occur (neutral axis) but the reply was =
 "not recommended".I enclosed the brake and pitot/static lines in ribed =
 wire conduit and used adel type clamps on both sides of the spar to hold =
 them close to the bottom edge of the center spar webs' lightening holes =
 and to prevent movement.  I have dual sticks and there is absolutely no =
 contact with any moving parts.For electrical wiring, I used both sides =
 of the cockpit rail channel.  I have wiring for the flaps, autopilot, =
 ELT (phone line), cabin lights, tail light, EFIS magnetometer and coax =
 for comm and transponder tucked underneath the cockpit rails. and =
 exiting with ribbed conduit at the end near the seats and then going =
 aft, down to the area behind the seats or in the case for the cabin =
 lights and magnetometer up around the cargo compartment bow.  Somehow it =
 all fit.  I was very careful that there was absolutely no chafing, or =
 proved chafing protection where possibly required.Tony =
 GrazianoN493TG601XL/Jab3300A; 99.8 hrsWiring around wing carry through =
 on 601Zenith-List message posted by: "Brian Briggerman" =
 <blb7037(at)cox.net>
 =3D
 =3D
 =3D
 =3D
 =3D
 have the center stick and it and the rudder cable take up the only =3D
 lightning hole.
 =3D
 plastic conduits and hoping the upholstery will be thick enough to =3D
 =3D
 Brian Briggerman
 Fountain Hills, AZ=3D20
		cmaggart(at)sprintmail.co Guest
				 Posted: Thu May 25, 2006 6:14 am    Post subject: Wiring around wing carry through on 601 |
				Brian, I have the same problem.  Nick at ZAC didn't like the idea of =
 drilling holes in the spar web.  I am running as much as possible =
 beneath the canopy sills.  I am running the hydraulic lines and flap =
 wiring through the holes in the forward, outboard seat bottoms ( in =
 separate conduits).  I was able to get the elevator trim and tail light =
 wires under the l/h canopy sill.  I ran the comm and GPS antenna cables =
 under the r/h canopy sill.  I used spiral wrap or clear plastic tubing =
 to protect the cables and hoses.  I  have not run the pitot/static lines =
 yet, but plan to bring them through the same hole (in the seat bottom) =
 as the brake line uses.  Hopefully the upholstery will cover most of =
 this up.
 I seriously considered making a tunnel under the floor to run the large =
 amount of wires and tubes,  It would have been nice if ZAC provided some =
 means of penetrating the spar.   I wonder how they ran the wiring on the =
 demonstrator?
 Chuck Maggart
 XL, structure done, installations nearly done
		nfivesl(at)yahoo.com Guest
				 Posted: Thu May 25, 2006 7:11 am    Post subject: Wiring around wing carry through on 601 |
				Brian:
 I used split loom and ran it through the center hole
 in the spar near the bottom.  It runs under the
 control parts for the center yoke and rudder cables.
 I was able to use the round, split-loom clamps to hold
 it out of the way of the controls.  I plan to tie-wrap
 the tubing to this also to hold it out of the way of
 the controls.  I have a lot of wires in my yoke for
 PTT, trim tabs, and frequency switch that are
 contained in split loom also and tie-wrapped to the
 yoke.
 I'll try to take a photo of the loom, etc. this
 afternoon and post it.
 Scott Laughlin
 601XL/Corvair
 Finished BRS Harness installation,
 working on Canopy
 http://www.cooknwithgas.com/index.html
  Briggerman" <blb7037(at)cox.net>
				 Posted: Thu May 25, 2006 8:29 am    Post subject: Wiring around wing carry through on 601 |
				Tony:
 That looks like the best way to honor Zenith's request not to drill the =
 carry through. I wondered if I could get by with running a ribbed =
 conduit along the inboard edge of the seat cushions and let the seat =
 cushion hide the conduits? I did see an AMD built 601 here in Arizona =
 yesterday and they drill two holes three inches from the outboard end of =
 the carry through midway between top and bottom for their stuff and it =
 got certified "Light Sport" with that.=20
 I appreciate everyone's response to the problem.
 Brian Briggerman
 601XL builder=20
 Fountain Hills, AZ
				 Posted: Fri May 26, 2006 5:58 am    Post subject: Wiring around wing carry through on 601 |
				Chuck:
 Thanks for your response. I am heading the same way you are. I did run =
 my brake lines in Aluminum tubing and run them along the bottom longeron =
 to get them forward of the wing carry through. That helped a lot but =
 it's amazing how many wires show up in a Light Sport Airplane. I am =
 using the external wire way as a backup plan that several listeners have =
 suggested. I do have access to an AMD built 601 and they had a lot of =
 the same problems we are having. They drilled two holes for a 1/2" ID =
 grommet in the carry through three inches from the outboard end and =
 three inches up from the bottom. They are running right along side the =
 fuel lines which is against 43-13 guidelines. Anyway they got it =
 certified that way.
 Cheers!
 Brian Briggerman
 Fountain Hills, AZ
