		rvdave
				 Posted: Fri Dec 02, 2011 5:54 pm    Post subject: wiring list |
				Getting back to working on the 10 after remodeling work at home, am getting ready to order some wiring and items for fwf to aft fuselage so I can close things up and have compiled a list of things, wondering if anyone can see what I'm missing.  So far the only thing I have running back is static line.
 18'  #2 cable
 30 ' 7 conductor shielded cable- 1 for servo, 1 extra
 18'  antenna cable
 battery contactor
 starter contactor
 misc crimp connectors for #2 cable
  _________________ Dave Ford
Cadillac, MI |
		nukeflyboy
  Joined: 05 Jan 2008 Posts: 162 Location: Granbury, TX
				 Posted: Fri Dec 02, 2011 6:54 pm    Post subject: Re: wiring list |
				Dave,
 If you mean what to run forward to aft in terms of cables and wires, here are things to consider.
 1. Power and ground to tail light.  This will be dictated by the type of light(s), ie, strobe, incandescent, or LED.  Note that strobe/LED can be synchronized which adds a wire.
 2. Pitch servo - 7 wires
 3. Elevator trim - 5 wires
 4. Some AHRS units and magnetometers go back there.  This could be several wire bundles.  I recommend installing conduit for pulling wires later.
 5.  Remote mounted transponder and/or ADS-B could go back there.
 6. Pos and ground battery wires to starter and engine or common grounding point.
 7. Power from battery to main buss(es).
 8.  Coax for comm antenna(s).
 9. Multiple conductor to ELT.  Shielded 2 pair for GPS feed, power, and phone type cable to control ELT from panel switch.
 10. Passenger headsets
 11. Lights, power outlets, or anything else mounted back there.
 12. Door reed switch wires
 13. Battery master contactor wire
 14. More wires if you are installing 2 batteries or a cross-feed connector
 15. Transponder coax
 If you want to include wing wires, then there are more.
 What about oxygen system plumbing?
  _________________ Dave Moore
RV-6 built and sold
RV-10 built and flying |
		kearney
				 Posted: Fri Dec 02, 2011 7:10 pm    Post subject: wiring list |
				Dave
 Here are the things going to my tail.
 Magnometer wiring  - 2
 Elt wiring
 Comm Antenna coax - 2
 GPS antenna coax
 Nav antenna coax
 O2 lines to bottle in baggage area
 Wiring for vent to rear of overhead plenum
 Wiring for cabin lights in overhead plenum
 Wiring for rudder trim
 Wiring for elevator trim
 Wiring for autopilot pitch servo
 Wiring for tail light
 Wiring to Whalen lighting system power supply and return lines for wing nav lights
 I ran conduit along the sides to aft if the baggage area. One per side. It would have been better to have a couple of lines per side.
 Cheers
 Les
 On 2011-12-02, at 6:54 PM, rvdave <davidbf(at)centurytel.net> wrote:
  18'  #2 cable
  18'  antenna cable
  battery contactor
  starter contactor
  Dave Ford
  RV6 flying
  RV10 building
  Cadillac, MI
  http://forums.matronics.com/viewtopic.php?p=360088#360088
