richard.goode(at)russiana Guest
Posted: Thu Dec 08, 2011 6:48 am Post subject: Parts |
Hi Doug
We would be interested to get one of the exhaust values as a sample since we have no idea what they are like – could you send to Peter at Aerometal:
Aerometal Kft.
Ipari Park
2038 S�sk�t,
Hungary
Peter Bruller
+36 20 992 6034
For engine mount rubbers – could we have price please
Richard
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of doug sapp
Sent: 07 December 2011 01:18
To: yak-list(at)matronics.com
Subject: Yak-List: What's new in the parts room?
Fellow CJ and Yak Drivers,
This will be the first "What's new in the parts room posting". This posting is designed to keep you up to date on new parts arrivals, mods and specials.
It is the time of year when conditional use inspections are scheduled. You might consider our newly packaged Conditional Use Inspection Kit which contains all of the fuel gaskets, oil gaskets, compressor filter, and felt wheel seals normally changed at this inspection. It also contains a fresh desiccant refill kit. �Price $54.00 per kit.
New in stock:
Engine Baffle pads P/N 14.36.580 (8 per set) and P/N 14.36.581 (9 per set)
400 X 150 tires (nose gear)
400 X 150 Tubes (nose gear)
Rocker shaft crush washers P/N 14.07.511
285 hp engine mount rubbers P/N H2-6400-04 8 each (16 per set)
M14P engine mount rubbers �P/N H2-6400-04-M14P (16 per set)
Exhaust valve 285 hp P/N 604.04.04 These are VERY hard to find, last shipment sold out within a week.
What's NEW:
Mod kit to use 285 hp shutters on M14P engine installation. Huge cost savings over Yak 18 shutters if your converting to the 360 hp M14P.
Mod kit for QL-17 snot valve, stainless steel needle and hardened brass seat solves the rust problems.
What's Coming:
Stainless steel 3 port QSF2A flap and gear valve for both CJ6 and Yak 52
2 Week Special:
Red Silicone rocker gaskets (flat type) normally $4.50 each. �Special price $4.00 each Special price ends 12/19/11 or while supplies last.
Best Christmas wishes from Omak,
Doug and Kathleen
Quote: | [b]������ -- Please Support Your Lists This Month --(And Get Some AWESOME FREE Gifts!)[b]�� November is the Annual List Fund Raiser.� Click on�� the Contribution link below to find out more about�� by: | 01234567890123456789 Quote: | [b]������ -- Please Support Your Lists This Month -- | 0 Quote: | [b]������ -- Please Support Your Lists This Month -- | 1 Quote: | [b]������ -- Please Support Your Lists This Month -- | 2 Quote: | [b]������ -- Please Support Your Lists This Month -- | 3 Quote: | [b]������ -- Please Support Your Lists This Month -- | 4 Quote: | [b]������ -- Please Support Your Lists This Month -- | 5 Quote: | [b]������ -- Please Support Your Lists This Month -- | 6 Quote: | [b]������ -- Please Support Your Lists This Month -- | 7 Quote: | [b]������ -- Please Support Your Lists This Month -- | 8
believed to be clean.
-- This message has been scanned for viruses and dangerous content by MailScanner, and is believed to be clean. [quote][b]
GeorgeCoy
Posted: Thu Dec 08, 2011 7:06 am Post subject: Parts |
MotorstarNA stocks the M14P motor mount kits. They include all new rubbers pieces, washers, bolts, nuts and cotter pins. The kit is P/N 506400KIT and sells for $475. Note that the two rubber mounts that are behind the magnetos are different from the rest of the mounts.
George
It is the time of year when conditional use inspections are scheduled. You might consider our newly packaged Conditional Use Inspection Kit which contains all of the fuel gaskets, oil gaskets, compressor filter, and felt wheel seals normally changed at this inspection. It also contains a fresh desiccant refill kit. Price $54.00 per kit.
New in stock:
M14P engine mount rubbers P/N H2-6400-04-M14P (16 per set)
What's NEW:
What's Coming:
2 Week Special:
Red Silicone rocker gaskets (flat type) normally $4.50 each. Special price $4.00 each Special price ends 12/19/11 or while supplies last.
Doug and Kathleen
0123456789
-- This message has been scanned for viruses and dangerous content by MailScanner, and is believed to be clean. Quote: | -- Please Support Your Lists This Month -- | 0 Quote: | -- Please Support Your Lists This Month -- | 1 Quote: | -- Please Support Your Lists This Month -- | 2 Quote: | -- Please Support Your Lists This Month -- | 3 Quote: | -- Please Support Your Lists This Month -- | 4 Quote: | -- Please Support Your Lists This Month -- | 5 Quote: | -- Please Support Your Lists This Month -- | 6 Quote: | -- Please Support Your Lists This Month -- | 7 Quote: | -- Please Support Your Lists This Month -- | 8 Quote: | -- Please Support Your Lists This Month -- | 9 Quote: | November is the Annual List Fund Raiser. Click on | 0 Quote: | November is the Annual List Fund Raiser. Click on | 1 Quote: | November is the Annual List Fund Raiser. Click on | 2 Quote: | November is the Annual List Fund Raiser. Click on | 3 Quote: | November is the Annual List Fund Raiser. Click on | 4 Quote: | November is the Annual List Fund Raiser. Click on | 5 Quote: | November is the Annual List Fund Raiser. Click on | 6 Quote: | November is the Annual List Fund Raiser. Click on | 7 Quote: | November is the Annual List Fund Raiser. Click on | 8 Quote: | November is the Annual List Fund Raiser. Click on | 9 Quote: | the Contribution link below to find out more about | 0 Quote: | the Contribution link below to find out more about | 1 Quote: | the Contribution link below to find out more about | 2 Quote: | the Contribution link below to find out more about | 3 Quote: | the Contribution link below to find out more about | 4 Quote: | the Contribution link below to find out more about | 5 Quote: | the Contribution link below to find out more about | 6 Quote: | the Contribution link below to find out more about | 7 Quote: | the Contribution link below to find out more about | 8 Quote: | the Contribution link below to find out more about | 901234
billaustin(at)blomand.net Guest
Posted: Sun Dec 11, 2011 2:35 pm Post subject: Parts |
Hey George. Bill Austin here. I am in popheni FSM in the south
pacific.moving a mu 2. Have been out of touch. When is Boris coming back
to the states. Bill
and
magnetos
George
posting
specials.
You
felt
fresh
New in stock:
set)
What's NEW:
seat
What's Coming:
2 Week Special:
price
Doug and Kathleen
by:
* AeroElectric www.aeroelectric.com
www.buildersbooks.com
List Contribution Web Site:
--> http://www.matronics.com/contribution
-Matt Dralle, List Admin.
- The Yak-List Email Forum -
--> http://www.matronics.com/Navigator?Yak-List
- MATRONICS WEB FORUMS -
- List Contribution Web Site -
dangerous content by MailScanner <http://www.invictawiz.com/> , and is
