		asarangan(at)gmail.com Guest
				 Posted: Fri Dec 09, 2011 6:27 am    Post subject: Rear tufnol bearings |
				Fellow europa builders:
 I have a question regarding the rear tufnol bearings for the control
 tube. Unwittingly I chamfered the rear bearing's hole, thinking that
 it had to be seated against the flange like the front bearings. Then I
 realized the flange does not sit flush against the rear bearings like
 the front ones. There is no major issue here, except the chamfering
 reduces the contact area with the tube. My guess is the contact area
 is reduced by at most 25%, possibly less. It doesn't seem to have any
 adverse effects or play right now, but I am concerned if this might
 get worse with wear. I haven't bonded these bearings in place, so
 right now it would be a trivial task to replace them. After bonding,
 it would be nearly impossible. I asked the Europa office to send me
 some extra bearings, but I have not heard anything back. I was
 wondering what your thoughts are, and if this is worth worrying about.
  |  | - The Matronics Europa-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		christoph.both(at)acadiau Guest
				 Posted: Fri Dec 09, 2011 6:50 am    Post subject: Rear tufnol bearings |
				Replace the bearing is the easiest and the right thing to do. You want an airplane you feel great about in every building aspect when you hold short of the runway for your first flight, and many years ahead.
 Best,
 Christoph Both
 #223 Wolfville, Nova Scotia, Canada
