Pre oiling new rebuild
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Continental-List
Jimz
PostPosted: Wed Dec 14, 2011 8:52 am    Post subject: Pre oiling new rebuild Reply with quote
I have a fresh rebuilt 0-200 that I want to pressure oil before the first startup. Where is the best place to hook the pressure line in? The oil filter, oil pressure sender, oil temp sender or one of the plugs in the front of the case? Also, how about 30 weight break-in oil this time of the year in Minnesota? 20 degrees F. Thanks jezim(at)pro-ns.net (jezim(at)pro-ns.net)
- The Matronics Continental-List Email Forum -
http://www.matronics.com/Navigator?Continental-List
BARRY CHECK 6
PostPosted: Wed Dec 14, 2011 9:17 am    Post subject: Pre oiling new rebuild Reply with quote
J:
I use the OIL COOLER threads.
I want to do this but have not had the chance:  Remove one of the Oil Plugs on the front of the engine.  Pump the oil in at the Oil Cooler and SEE if the oil reaches the front of the engine.
As for the type of oil:  20W-50 Multi grade. Are yo breaking in the engine?  If so Philips makes a recommended 20W-50 Non-AD oil.
BUT!  Times they are a changing... Some Mfg. now recommend 20W-50 AD oil for break-in.    And that is the way I went. No Problem...  550+ Hrs since new.
Barry
On Wed, Dec 14, 2011 at 11:50 AM, Zimmermans <jezim(at)pro-ns.net (jezim(at)pro-ns.net)> wrote:
[quote] I have a fresh rebuilt 0-200 that I want to pressure oil before the first startup.  Where is the best place to hook the pressure line in? The oil filter, oil pressure sender, oil temp sender or one of the plugs in the front of the case? Also, how about 30 weight break-in oil this time of the year in Minnesota?  20 degrees F.    Thanks          jezim(at)pro-ns.net (jezim(at)pro-ns.net)
vk3eka(at)bigpond.net.au
PostPosted: Wed Dec 14, 2011 11:12 am    Post subject: Pre oiling new rebuild Reply with quote
Hi,
I used the oil pressure sender line. 30 weight sounds good to me but it is a little warmer in Australia Smile
Cheers
Peter
Wonthaggi Australia
From: owner-continental-list-server(at)matronics.com [mailto:owner-continental-list-server(at)matronics.com] On Behalf Of Zimmermans
Sent: Thursday, 15 December 2011 3:50 AM
To: continental-list(at)matronics.com
Subject: Pre oiling new rebuild
oldernut
PostPosted: Wed Dec 14, 2011 1:50 pm    Post subject: Pre oiling new rebuild Reply with quote
That's amazing. I was just about to ask the same question about my A-65.
Dave
Blue Sky
PostPosted: Wed Dec 14, 2011 3:45 pm    Post subject: Pre oiling new rebuild Reply with quote
What did you use as a pressure source? I am starting a C85 in January.
Lyle
Date: Wed, 14 Dec 2011 12:15:08 -0500
Subject: Re: Pre oiling new rebuild
J:
Barry
_blank>www.aeroelectric.com
/" target=_blank>www.buildersbooks.com
=_blank>www.homebuilthelp.com
=_blank>http://www.matronics.com/contribution
List" target=_blank>http://www.matronics.com/Navigator?Continental-List
ttp://forums.matronics.com
My passion for the landscape has lead me to the sky.
PostPosted: Wed Dec 14, 2011 11:17 pm    Post subject: Pre oiling new rebuild Reply with quote
Hi,
I used an old gas cylinder (5 pounds ish!) with a schrader valve incorporated in the top of the cylinder and a hose connecting to the oil pressure outlet on the engine. I used a small compressor to pressurise the cylinder pumping oil into all engine cavities.
All worked well.
Cheers
Peter
From: owner-continental-list-server(at)matronics.com [mailto:owner-continental-list-server(at)matronics.com] On Behalf Of Lyle Fast
Sent: Thursday, 15 December 2011 10:43 AM
Subject: RE: Pre oiling new rebuild
Lyle
J:
Barry
_blank>www.aeroelectric.com/" target=_blank>www.buildersbooks.com=_blank>www.homebuilthelp.com=_blank>http://www.matronics.com/contributionList" target=_blank>http://www.matronics.com/Navigator?Continental-Listttp://forums.matronics.com=_blank>http://www.matronics.com/contribution
5
6
7
8
9
BARRY CHECK 6
PostPosted: Thu Dec 15, 2011 6:33 am    Post subject: Pre oiling new rebuild Reply with quote
Peter:
Did you remove the remove the front oil plug to see if the oil made it all the way up front?
Barry
On Thu, Dec 15, 2011 at 2:14 AM, Peter W Johnson <vk3eka(at)bigpond.net.au (vk3eka(at)bigpond.net.au)> wrote:
Hi,
All worked well.
Cheers
Peter
From: owner-continental-list-server(at)matronics.com (owner-continental-list-server(at)matronics.com) [mailto:owner-continental-list-server(at)matronics.com (owner-continental-list-server(at)matronics.com)] On Behalf Of Lyle Fast
To: continental-list(at)matronics.com (continental-list(at)matronics.com)
Lyle
From: flyadive(at)gmail.com (flyadive(at)gmail.com)
J:
Barry
5
6
7
8
9
Blue Sky
PostPosted: Thu Dec 15, 2011 7:49 am    Post subject: Pre oiling new rebuild Reply with quote
That sounds about right, I'll see if I can find a clean one.
What are people thinking about ground run ups during break in? This engine has not run since rebuild and won't fly till next summer. I would like to prove it runs, tune it and do some static runs with the new prop out side my shop in cool/cold conditions. I can monitor CHT and have been thinking about auxiliary cooling air for these runs. I understand low rpm running is not good but what about static runs at close to 70% rpm/power?
Lyle
Date: Thu, 15 Dec 2011 18:14:20 +1100
.ExternalClass .ecxshape {;} .ExternalClass p.ecxMsoNormal, .ExternalClass li.ecxMsoNormal, .ExternalClass div.ecxMsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:"Times New Roman","serif";} .ExternalClass a:link, .ExternalClass span.ecxMsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited, .ExternalClass span.ecxMsoHyperlinkFollowed {color:purple;text-decoration:underline;} .ExternalClass p {margin-right:0cm;margin-left:0cm;font-size:12.0pt;font-family:"Times New Roman","serif";} .ExternalClass pre {margin-bottom:.0001pt;font-size:10.0pt;font-family:"Courier New";} .ExternalClass span.ecxHTMLPreformattedChar {font-family:Consolas;} .ExternalClass span.ecxEmailStyle20 {font-family:"Calibri","sans-serif";color:#1F497D;} .ExternalClass .ecxMsoChpDefault {font-size:10.0pt;} (at)page WordSection1 {size:612.0pt 792.0pt;} .ExternalClass div.ecxWordSection1 {page:WordSection1;}
Hi,
All worked well.
Cheers
Peter
Lyle
J:
Barry
5
6
7
8
9
BARRY CHECK 6
PostPosted: Thu Dec 15, 2011 8:34 am    Post subject: Pre oiling new rebuild Reply with quote
Lyle:
Ground Run-Up are NOT recommended.
Engine shops have CLUBS (Small Diameter Props usually made of wood to keep them light) for ground run-ups.
A standard prop will not reach the required RPM and the engine will not reach break-in temperatures.
You also will not cool the engine properly.
More damage will be done ground running than flying for 300 hours. <-- Rule of thumb.
I have installed and broken in about 6 engines - I NEVER ran the engine on the ground for more time than to adjust idle, mixture and movement of cables.
GO FLY!
Barry
On Thu, Dec 15, 2011 at 10:47 AM, Lyle Fast <lylefast(at)hotmail.com (lylefast(at)hotmail.com)> wrote:
Lyle
From: vk3eka(at)bigpond.net.au (vk3eka(at)bigpond.net.au)
Hi,
All worked well.
Cheers
Peter
Lyle
Subject: Re: Continental-List: Pre oiling new rebuild
J:
Barry
5
6
7
8
9
5
Blue Sky
PostPosted: Thu Dec 15, 2011 8:55 pm    Post subject: Pre oiling new rebuild Reply with quote
Barry,
  Nice clear answer, nothing wishy washy about that!
Thanks, Lyle
Date: Thu, 15 Dec 2011 11:31:23 -0500
Lyle:
GO FLY!
Barry
[quote] That sounds about right, I'll see if I can find a clean one.
Lyle
Hi,
All worked well.
Cheers
Peter
Lyle
J:
Barry
5
6
7
8
9
5
PostPosted: Thu Dec 15, 2011 10:17 pm    Post subject: Pre oiling new rebuild Reply with quote
Barry,
No, I just pumped oil into the pressure gauge hole and all worked perfectly after.
Cheers
Peter
From: owner-continental-list-server(at)matronics.com [mailto:owner-continental-list-server(at)matronics.com] On Behalf Of FLYaDIVE
Sent: Friday, 16 December 2011 1:31 AM
Peter:
Barry
Hi,
All worked well.
Cheers
Peter
Lyle
J:
Barry
5
6
7
8
9
5
6
7
8
9
5
6
7
8
9
BARRY CHECK 6
PostPosted: Fri Dec 16, 2011 5:21 am    Post subject: Pre oiling new rebuild Reply with quote
Hey Peter are you VK3EKA?
I'm WB2ZDH
OK, on the pre-oil.  As I said, I never tried it but I think it would be a great way to verify that the oil is getting all around.
Another TRICK.  Install an oil temp probe in the 1/8" NPT thread in the front of the case.  You will get REAL temp reading that really mean something.  They will be of the FRONT bearing.  I have heard of 25 Deg F differences between the front and rear of the case.
Barry
On Fri, Dec 16, 2011 at 1:14 AM, Peter W Johnson <vk3eka(at)bigpond.net.au (vk3eka(at)bigpond.net.au)> wrote:
Barry,
Cheers
Peter
From: owner-continental-list-server(at)matronics.com (owner-continental-list-server(at)matronics.com) [mailto:owner-continental-list-server(at)matronics.com (owner-continental-list-server(at)matronics.com)] On Behalf Of FLYaDIVE
Peter:
Barry
Hi,
All worked well.
Cheers
Peter
Lyle
J:
Barry
5
6
7
8
9
5
6
7
8
9
5
6
7
8
9
5
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Continental-List All times are GMT - 8 Hours
You cannot download files in this forum
