sidsel.svein(at)oslo.onli Guest
Posted: Sat Dec 17, 2011 8:02 am Post subject: SV: Re: SV: Oil tank breather catch bottle |
Hi Remi,
I appreciate your comments.
There is some slack between the vent hose and the bottle opening, and there
is also a hole drilled in the neck of the bottle that can be seen above the
steel band in the photo (as you have noticed). The venting hole does not
seem to be as large as 8 mm, however, so I will drill out to 8 mm and add
two more holes around the neck. The fact that the engine has worked fine is
no excuse for not having paid proper attention to this - thanks again for
pointing it out.
Svein
LN-SKJ
