frankd(at)foundrynet.com Guest
Posted: Fri May 26, 2006 12:03 pm Post subject: Anyone got feedback on a Mark 111 Extra with a Jabriu 2200cc |
Greetings,
I'm looking for feedback on using a Jabriu 2200cc (85hp) on the Mark111 x.
Its time to get serious about picking an engine and I know its designed for
the Rotax but I'm looking at all options.
Also, how good is the Rotax 912 S 100HP unit??
Ease of install, reliability, positives, negatives on both would be great
info.
I want to be able to carry up to 230lb passengers and possibly put it on
floats.
Thanks for your feedback.
FrankD
Denny Rowe
Joined: 10 Jan 2006 Posts: 89 Location: Leechburg, PA
Posted: Fri May 26, 2006 1:02 pm Post subject: Anyone got feedback on a Mark 111 Extra with a Jabriu 2200cc |
Frank,
If you plan on floats you'll want the 912, more thrust due to the bigger
slower prop.
Plenty of 912Ss on Mk-3s with happy owners, but the 912UL is also a crowd
pleaser.
The newer Jab 2200 perform fine on the Mk-3 with 62 and 64 inch props but
the Rotax swinging 68 - 72 inch blades will give a good bit more take off
and climb performance.
Denny Rowe, Mk-3, PA
HShack(at)aol.com Guest
Posted: Fri May 26, 2006 3:30 pm Post subject: Anyone got feedback on a Mark 111 Extra with a Jabriu 2200cc |
In a message dated 5/26/2006 4:03:56 PM Eastern Standard Time,
frankd(at)foundrynet.com writes:
info.
floats.
Floats?? No doubt, use the 912S. Check out www.trentonflyers.com then
click on "members" then "Robert Broadwell" if you want to see a nice MkIII with
912S. Includes a very good write=up.
Howard Shackleford
FS II
SC
