		Goodone
				 Posted: Thu Jan 05, 2012 10:03 am    Post subject: Tricks For Replacing Bottom Coolant Hose On 912? |
				Any tricks or suggestions on how to remove and replace the 17mm coolant hose on the bottom of a Rotax 912? By taking off the coolant  flange attached to the head on the top of the engine it has made the top job a bit easier. Any good methods for the bottom hose replacement?
  |  | - The Matronics RotaxEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Roger Lee
				 Posted: Thu Jan 05, 2012 9:29 pm    Post subject: Re: Tricks For Replacing Bottom Coolant Hose On 912? |
				I've done a lot of 5 year rubber hose replacements and you shouldn't have to remove any coolant fittings. I can usually pull the hoses off and slide them back on with either a constant compression clamp or a screw clamp. I don't usually have to remove any fuel fittings. If you cause the coolant 90 degree fittings on the top or the bottom of the engine to come loose (swivel back and forth) then you will need to pull that fitting and unscrew it then re-apply some Loctite 648 and put the fitting back in place and let it sit overnight in the aligned position that you will need.
  _________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Home 520-574-1080  TRY HOME FIRST
Cell 520-349-7056 |
