shinden33
Posted: Mon Jan 09, 2012 10:53 am Post subject: Low Resistance Ignition Wires |
All,
My Russian ignition system gave out a few years ago and I replaced it with an automotive wire kit. Since then the pencil on my left mag has burned through the mag cap twice, once a year and half ago and once two weeks ago, causing the mag to ground to the case and quit. The general consensus is that these are higher resistance wires and thus causing the electrons for find a easier path.
Anyone have any ideas, experience or insight?
Scott
Yak-52
cjpilot710(at)aol.com Guest
Posted: Mon Jan 09, 2012 11:01 am Post subject: Low Resistance Ignition Wires |
Hmmmmm. That has not happen to me.
Pappy
In a message dated 1/9/2012 1:56:36 P.M. Eastern Standard Time, scott.t.glaser(at)gmail.com writes:
| Quote: | --> Yak-List message posted by: "shinden33" <scott.t.glaser(at)gmail.com>
All,
Scott
Yak-52
The Defiant Company
www.defiantco.com
http://forums.matronics.com/viewtopic.php?p=362851#362851
Posted: Mon Jan 09, 2012 11:10 am Post subject: Low Resistance Ignition Wires |
One of the things that has become quite obvious with the M9-x magnetos
is the fact the rotor position is not or never has been properly
positioned once the magnetos are properly timed. When the rotor
position is properly set, the leading finger will be directly under the
tab on the cap. This is the reason there are slots in the 3 mounting
screw holes in the rotors. And it doesn't matter if it's a single
finger or double finger rotor. The leading finger is the key (counter
clockwise rotation). If the rotor is not properly positioned the spark
must "jump" the gap to the tab on the cap thus causing additional wear.
Typically one can see tracks in the cap which show a slightly discolored
mark in the cap just prior to the tab. If anyone wants a
diagram/drawing of how to properly position the rotor on the mag after
it is properly timed, send me an email I will attach it to a reply.
Additionally it is very important to have the spark plug gap at around
.020". Since we are using the same coil as with the old Russian or
Chinese wiring harness, we should not be using plug gaps of .025-.030"
which can occur by not gaping the plugs when they are first installed.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (cell)
Skype: Yakguy1
www.yak-52.com
On 1/9/2012 12:53 PM, shinden33 wrote:
All,
Scott
Yak-52
The Defiant Company
www.defiantco.com
wlannon(at)shaw.ca Guest
Posted: Mon Jan 09, 2012 12:04 pm Post subject: Low Resistance Ignition Wires |
Hi Dennis;
I agree that could very well be the problem in this case but there is a bit
more to it.
It should not be necessary to adjust the rotor finger after timing the mag.
to the engine. It must line up with the index mark on the case which
ensures it is in the correct location relative to the distributor tabs.
If it does not line up (within +/-1mm) the magneto INTERNAL timing is not
correct.
If you are installing anything other than a new or overhauled and certified
mag. the internal timing must be checked and adjusted if necessary.
Walt
Posted: Mon Jan 09, 2012 12:05 pm Post subject: Low Resistance Ignition Wires |
Timing the Russian mag includes more than just checking to see when the
points open. There is also a rotor setting that must be correct. The
reason I mention this is because of the potential to have too large of a
gap when the mag fires the pulse. Either too large a gap between the
actual mag rotor and the cap contact, or the plugs themselves.
So there are a number of things at issue here.
1. What plugs are you using and what is their exact gap that you have
them set to?
2. Have you set the mag rotor correctly in relationship to the mags
timing (See Dennis Savarese's pictures of how to do that).
3. You replaced your Russian wires with "an automotive wire kit".
Who's? Dennis or Barry's, or was it something you picked up off the
shelf yourself, and if so what exact wires were used?
One statement you made is right on the money.... but not quite
complete. You said: "higher resistance wires and thus causing the
electrons for find a easier path."
Yes, electricity will always find the path of least resistance. It is
unlikely to be the spark plug wires if you used the same wires in both
the left and right mags, and only the left is burning up. That said,
increased spark plug gap will "raise the resistance", as will a rotor
that is too far away from the caps spark plug wire fitting.
Other things that could cause more resistance could relate to how you
managed to put the spark plug wires into the cap.... did you use the
screw in sharp pointed piece and did it penetrate all the new wires
correctly to make a good contact? Is it possible that you have the
POINT GAP in the MAG's POINTS set incorrectly?
Lastly, I would really like to see a picture of how the pencil burned
through the mag cap. Any kind of carbon trail that is not totally
removed from a previous incident will cause it to happen again much
easier. So, it would be a good thing to be able to see the damage with
a picture.
Bottom line, you are correct. If the resistance becomes too high going
to the spark plugs, it is possible for the high voltage to "find"
another path, but there are a lot of things other than the wires
themselves that could cause this.
Mark Bitterlich
Posted: Mon Jan 09, 2012 12:14 pm Post subject: Low Resistance Ignition Wires |
That's exactly what I'm talking about Walt. I've seen so many rotor
fingers not lined up with the scribe mark after the magneto is properly
timed, it isn't even funny. I've even had someone call me on the phone
and tell me they were rotating the ROTOR in the slots in an effort to
time the magneto!
All I am saying is it is a very good idea to check this setting once the
mags are properly timed because of how many I have seen that are not
properly set.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (cell)
Skype: Yakguy1
www.yak-52.com
On 1/9/2012 2:01 PM, Walter Lannon wrote:
Hi Dennis;
a bit more to it.
mag. to the engine. It must line up with the index mark on the case
which ensures it is in the correct location relative to the
distributor tabs.
not correct.
certified mag. the internal timing must be checked and adjusted if
necessary.
Walt
Posted: Mon Jan 09, 2012 12:47 pm Post subject: Low Resistance Ignition Wires |
Just a further comment on this if I may concerning "higher resistance
spark plug wires". Both kits that I have seen (both Dennis's and
Barry's) are using extremely high quality 8mm spark plug wires or
larger, and in addition are "racing" types used in very high performance
automobiles. These systems support firing voltages as high as 45,000
volts or more without breakdown. Their resistance values will work
perfectly with anything from systems as small as those used on a
lawn-mower to those used in 2000 horsepower racing engines.
Keep in mind that in any ignition system, what determines the actual
firing voltage that the coil actually develops is ultimately a factor of
the total resistance to ground. While wires do have some resistance, of
course ... the actual HUGE resistance comes from AIR GAPS! Common sense
applies.... will electricity flow easier through wire (ANY KIND OF WIRE)
, or across an air gap?
Voltage will build up in a coil, until an actual spark is achieved at
the spark plug. The larger the spark plug gap (or any OTHER gap, like
at the mag rotor) is, the higher the voltage will be that is required to
JUMP that gap.
The total resistance is a factor of the wire (very low resistance) and
air gaps (very high resistance).
There is in fact a LIMIT to this, which then brings into discussion coil
saturation, where higher voltage does not occur, but current increases
and so does heat... which leads to coil failure.
So if you have electricity blowing holes through things that they should
not be, start checking GAPS ... ALL THE GAPS! Points, rotors, plugs,
etc. If you suspect you have bad spark plug wires, you can always check
them, but make no mistake that racing wires such as are used in these
kits are better and not worse than what was originally there. The
original Russian wires did indeed have lower resistance end to end, but
they also had very poor insulation and BAD BAD leakage, which amounted
to an overall poorer performance than the new wires you have now.
Mark Bitterlich
jan.mevis(at)informavia.b Guest
Posted: Mon Jan 09, 2012 11:17 pm Post subject: Low Resistance Ignition Wires |
What these 8 mm spiro wounded cables also do much better, is transfering the
energy of the high-frequency components in the ignition current.
The low-resistance solid core wires used by the Russians fail to pass these
high frequency currents. That's why at the end Dennis' plug wires deliver
MORE power to the plugs.
To give credit to the Russians: the cables they used originally were always
of very high quality, they were also used in their missile systems. But they
also changed the whole wiring quite regularly.
Jan
