graeme bird
Posted: Sun Jan 15, 2012 9:37 am Post subject: lower cowl opening for 914 only? |
Had a sudden panic that I had unnecessarily opened up the lower cowl starboard NACA duct and that it was only required for 914 inlet and not my 912. I cant see what its for for the 912ULS as it would only cool the oil tank (which is already too cool in flight) and possibly one end of the exhaust.
Is it necessary, has anyone filled it in?
_________________ Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY - Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk |
rlborger(at)mac.com Guest
Posted: Sun Jan 15, 2012 9:55 am Post subject: lower cowl opening for 914 only? |
Greame,
Unfortunately, you are correct. That duct is only for the 914 intake air. It should probably be closed up. A couple of layers of BID laid up on the inside with at least 1 inch of overlap onto the cowl should do. Then fill the outer and sand to smooth and match the cowl. Prime and paint. You should be OK.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop.
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com
On Jan 15, 2012, at 11:37 AM, graeme bird wrote:
Graeme Bird
G-UMPY
Mono Classic/XS FWFD 912ULS/Warp drive FP
Just Test Flying to obtain permit
