riddon(at)sent.com Guest
Posted: Sat Jan 07, 2012 2:24 am Post subject: Leaking coolant |
Further to recent posts, I have now obtained and fitted the spring type clips in place of the jubilee clips on my radiator hoses. On first fitting, the leaks were much worse. I have doubled up the clips on the two lower connections with jubilee clips which appears to have stopped the leak for now. I am guessing that the spring clips may seal better as the engine and hoses warm up and allow them to bed in.
Anyone else had this experience?
Richard Iddon
G-RIXS
paul.the.aviator(at)gmail Guest
Posted: Sat Jan 07, 2012 6:56 am Post subject: Leaking coolant |
Hi Richard,
I have CTC clips on all of my coolant hoses including the big ones to the radiator and they work fine. I believe that Rotax fit CTC clips as standard on new engines these days.
The only thing I can offer is that when I was looking for some odd ball CTC clips that I bought some from a supplier in Canada who imported them from Korea and they were pretty much weaker than the ones I purchased from McMasters here in the US.
Paul [quote][b]
rlborger(at)mac.com Guest
Posted: Sat Jan 07, 2012 7:32 am Post subject: Leaking coolant |
Hi Paul,
Could you provide a McMaster part number or spec for those clips. I'm sure there's plenty of folks who would be interested in them.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop.
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com (rlborger(at)mac.com)
On Jan 7, 2012, at 8:48 AM, Paul McAllister wrote:
| Quote: | Hi Richard,
Paul |
Posted: Tue Jan 10, 2012 7:57 am Post subject: Leaking coolant |
Paul,
Yes, I found the clamps section. There are two styles, one of sheet steel and one of round steel rod. Which style are you using successfully and what size? It will be time to replace the coolant in another 25 hours or so and I would like to convert to the CTC at that time.
Bob Borger
3705 Lynchburg Dr.
Cel: 817-992-1117
On Jan 10, 2012, at 8:14 AM, Paul McAllister wrote:
| Quote: | Bob,
McMasters have reduced the range of CTC that they carry, however what they do have can be found at:
http://www.mcmaster.com/#constant-tension-hose-clamps/=fqtog0
Paul
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa-List
rparigoris
Posted: Tue Jan 10, 2012 9:30 am Post subject: Re: Leaking coolant |
Hi Guys
I too purchased CTC clamps to hold my Silicone hoses in place on my 914. Be aware the clamps come in different widths and tensions, they are not all created equal.
Whatever I couldn't procure from McMaster, I got SELF-COMPENSATING HOSE CLAMPS from Rotor Clip:
http://rotorclip.com/hose_clamps.php
(I forget now, but they may have even sent me what I needed as free samples?)
Although you could probably get away by using something you already have for squeezing and installing, I broke down and bought a purpose pliers that allows for holding and rotating the angle. I probably bought them from McMaster.
No matter it isn't a bad idea to wear safety glasses when installing the clamps, at least until they are held captive on the hose.
Ron Parigoris
